外贸应急灯专用锂电池升压恒流芯片
+ W7 e9 n) i/ s& i% D/ `简约台灯专用升压恒流驱动芯片; X" s9 E+ X6 R% y4 h, U
可调光台灯专用升压恒流芯片
5 @0 W# S2 H# B$ `礼品台灯专用升压恒流芯片4 [/ l" Q5 O. K8 j/ B
LED智能台灯专用升压恒流芯片" c7 h& y# @4 ~ k
输入2.8V-30V升压恒流驱动芯片内置MOS大2A输出
' K* V d `: K k. @AP92356 @# A# @3 r: S% R6 P3 N% k9 { |0 O% b
General Description
, [% n1 o& v( A( H2 m GAP9235 is DC/DC step-up converter that deliver an 8 V8 L/ U1 _+ a: `
accurate constant current for driving LEDs. Operation
5 ]# T2 O1 O$ z$ i6 r$ Uat a fixed switching frequency of 1MHz allows the
$ n S+ v9 i* }! S& h4 _3 _device to be used with small value external ceramic . V& T' q- }0 l5 T- p
capacitors and inductor. LEDs connected in series are
5 s! Y& p, e o( r0 r* V# Y1 g4 Idriven with a regulated current set by the external
3 m$ R% C% H+ c( \4 ^0 ]: b& \. a" _resistor. The AP9235 is ideal for driving up to eight / l2 y" Q( M0 E& h$ d: }& i
white LEDs in series or up to 30V. 7 o% R& j- x& \4 u3 J
Ordering Information
$ ?" p- u# I+ o7 ^( W5 f$ a HPackage Code 7 O, h; i* G5 [; ^
Temperature Code
/ i, g' K' r6 W% F, gOptional Spec Code: y: g$ {- h6 z# h9 m, X
AP9235 □□□□(□□□□□□□□)□□□□. t, ]9 |) u$ c% s8 l7 e
Temperature Range: -40°C to 85°C
/ P7 A2 I. |: y F3 U% }' ^* n/ aFeatures 4 I+ m3 b- G6 a6 w
• Input voltage range: 2.8 to 30V
2 P$ Y3 ~- y9 ~* @4 j• Switch current limit 2A 4 [# `7 f5 v0 Y- c Z& i
• Drives LED strings up to 30V
+ x9 _: M" O# y• 1MHz fixed frequency minimizes the external P1 P: g% v J
components
( w& M1 o/ z- ~• Dimming frequency for EN/PWM pin:
9 e/ a/ S5 j7 ?5 a* z; _20kHz~1MHz
2 f$ f/ r8 Y% M' l0 O" ~• Internal softstart limits the inrush current - {6 z6 E4 ?% U" [
• Open LED over voltage protection + `2 Q7 O9 m5 B* E F5 x. x! | g- K
• RoHS Compliant and Halogen Free
# M( K7 c$ b: s$ u1 h% [- |, uApplications 1 N* M b0 s4 p k4 D
• GPS Navigation Systems : x: v0 _+ P6 f
• Handheld Devices ) E% F& E1 k. Z) g
• Portable Media Players 6 ~; c0 Q' U4 V# F
Typical Applications+ O; P) G$ s3 G1 a2 @
8、样板申请联系: * o. D9 D) A0 c9 H' Z7 V
深圳市
5 L/ \0 @* W J' \& l如需要了解可以联系欧阳: 18811874036 13714437124(微信)QQ:2355558464 6 @% X# R, G* Y/ S/ z* B6 n/ B: ]
深圳市宝安西乡街道宝源路名优采购中心B座1区326
! W# g0 v0 W% X3 b# F3 V/ h' `' e7 |2 h" \3 O7 k" e
; A8 j6 i% U! n& d& M# j |
