查看: 259|回复: 0
ZCC66099同步升压加LDO 替代SGM66099
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-5-27 09:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    The
    $ s5 e9 z4 G- L8 \6 p0 {ZCC66099 is a synchronous step-up converter ( m1 e! f3 \& ?1 g! n
    with
    ; v6 u; z. x1 f% M% e" T0 T0.65μA ultra low quiescent current. It is designed , ?  |5 p) a% D' L) h, V
    for
      l+ `( \9 D5 g1 }8 }; M1 xproducts powered by alkaline battery, NiMH ( b& x  T! o6 ^
    rechargeable battery, Li-Mn battery or rechargeable Li-
    * e! j9 |: ?1 Q" HIon battery, for which high efficiency under light load
    / M' U$ `- F; Tcondition is critical to achieve long battery life operation.
    0 a  n: @7 a1 v) g/ r6 N/ }The ZCC66099 step-up converter only consumes
    * u7 l  ~; U+ B0.65μA quiescent current under light load condition and
    ! W2 W5 Y7 _! S- @/ E/ U* Xcan achieve up to 75% efficiency at 10μA load with
    / B' h3 z6 G8 Vfixed output voltage version. It can also support up to 1 v) q1 w$ Q5 _: A( ]! o: `) E
    300mA output current from 3.3V to 5V conversion, and
    5 ~& f" a: W5 g4 bachieve up to 93% at 200mA load. ) T  e0 p" _) j. m- \
    The ZCC66099 also offers both down mode and 2 I& b1 m* A% q; P0 F+ l! P
    pass- 9 E7 a8 y$ q: \
    through operation for different applications. In ) B8 C" X3 C2 _4 b( H- Q9 ?% [! A
    down % D5 F' E& i: G: z
    mode, the output voltage can still be regulated at
    7 s6 |7 e# K# i' m; B% C+ ltarget ) ^8 \' o  S$ u7 ~9 I1 H9 x
    value even when input voltage is higher than output
    ! e. b  x* ]* Z$ w; d5 fvoltage. In pass-through mode, the output voltage 3 L2 D7 c! ~9 i
    follows input voltage. The ZCC66099 exits down mode - |+ E6 D/ w, b8 i
    and enters into pass-through mode when VIN > VOUT + * @% u6 ~7 [, z0 `
    0.3V. ( [  m# {1 \) z$ Z& v1 J: P3 ~4 a
    The ZCC66099 supports true shutdown function when
    6 s- H5 Z) Y$ D  f1 c$ S9 |it is disabled, which disconnects the load from the input 1 Q: N# ^; h9 L+ C
    supply to reduce the current consumption. 5 i; N' X2 l; P& M6 n/ D
    The ZCC66099 offers both adjustable output voltage ' Y0 A0 n- y1 n+ @: z5 o& Q6 Y
    version and fixed output voltage versions. It is available ; \, L+ u! U* C0 h3 q1 ~% w8 n( j1 u8 z
    in Green WLCSP-1.22×0.83-6B and TDFN-2×2-6AL ) s3 i6 |/ a. V2 c& h
    packages. ) g/ ]7 u0 p, N! _9 l
    TYPICAL APPLICATION
    8 K& l9 y; {) z! s* m! ]1 _●Operating Input Voltage Range: 0.9V to 5.2V
    / e- `  D9 Z, @7 t6 H●Ultra Low Quiescent Current
    4 @$ ], l( d2 x* E% v" O 0.6μA Ultra Low IQ into VOUT Pin . X" @0 H) A' t0 c4 B+ v) {
     0.05μA Ultra Low IQ into VIN Pin
    : Y' m3 u- M3 j5 }" d( A●1.2MHz Fixed Frequency Operation 5 M- g  l* |  `) G* r  B* P
    ●Adjustable Output Voltage from 2.5V to 5.2V
    7 t" j9 ^/ E6 i) M3 r●Fixed Output Voltage Versions Available
    2 Q: D9 }) q, u3 S8 `- Z9 I; u2 X- g●Power-Save Mode for Improved Efficiency at Low * m; ]8 b5 H' N& g
    Output Power 4 C3 V+ e, p9 G/ }& K
    ●Regulated Output Voltage in Down Mode 0 x7 t  F  Z; O$ U! r; n9 P5 x
    ●True Disconnection During Shutdown
    6 g5 |& c2 G! ~' a! e●Up to 75% Efficiency at 10μA Load with Fixed 7 n4 `- J5 n: Q
    Output Voltage Version & e( c# W' b& U, K5 w8 O
    ●Up to 93% Efficiency from 10mA to 300mALoad
    0 Z: x: |- Y: Y' X9 P●-40℃ to +85℃ Operating Temperature Range
    8 J2 o: ]4 H6 b/ o6 B, W●Available in Green WLCSP-1.22×0.83-6B and
    7 b& I; e, N6 X1 z" p5 g0 UTDFN-2×2-6AL Packages * l' {7 k' e' f( Y: S/ m
    APPLICATIONS 7 t' T* j7 a' C! W% @4 O
    Memory LCD Bias
    , l3 K! W# F' R. R& g# QOptical Heart Rate Monitor LED Bias 7 G2 q& E/ ~. P* L
    Wearable Applications / ?7 o$ p' T0 k" `6 r. Z
    Low Power Wireless Applications
    ' F  \9 S& e" @9 L+ e% {% xPortable Products
    / a& f( ?5 n3 |: A9 n' A' iBattery Powered Systems8 d* r% x/ C, t7 Z; a. Q" O
    / e/ |0 K$ n# @) V# l$ n; R) v* V, [
    GMT+8, 2025-10-12 03:27 , Processed in 0.125000 second(s), 24 queries , Gzip On.
