% Y) r9 X0 O i6 B; D. F1、cylinder函数:绘制三维圆柱图
0 v! x( ^9 L3 E B/ b6 T- ?) h* a5 `% }1 S' v. c) C
2、用法说明:
% r+ x: c# F9 K" @( C7 ]
& i7 e" e7 {! M(1)[x,y,z]=cylinder 函数返回一半径和高度都为1的圆柱体x,y,z轴的坐标值,圆柱体沿其周长有20个等距分布的点
+ c" u3 `5 t. I) I* N
( m6 I. E, V8 x) X# n5 @! W+ }- ]' A(2)[x,y,z]=cylinder(r) 函数一个半径为r、高度为1的圆柱体的x,y,z轴的坐标值,圆柱体沿其周长有20个等距分布的点
( }% C/ O& ]" f K8 Y# v1 U
$ S/ |0 x0 f3 b3 g7 v# _(3)[x,y,z]=cylinder(r,n) 函数一个半径为r、高度为1的圆柱体的x,y,z轴的坐标值,圆柱体沿其周长有n个等距分布的点+ w* c+ I6 ^3 `! J) s
" G1 Y9 O l! a9 U% Y: V# ]" d(4)cylinder(...) 函数只绘制圆柱,没有任何的输出参量。其他参量及结果同上
/ l% s! ]& a; s8 {3 ~% k& [) _6 w, U
2 e& h' ]" f3 i# Z/ z# t3、实例! h% U& K4 o# v( X' ?4 u& f* ]
2 I4 N: I' D% h6 f ^+ _3.1、[x,y,z]=cylinder 函数
6 R( l1 R8 e/ ]; L' O8 F+ g, g; Q4 P- J# n9 v
- O+ x* h c' L( K
>> [x,y,x] = cylinder
/ [! a) e/ ~5 H+ D$ D9 U! g
5 a) O! K% b$ Ux =
8 z& i9 P( l+ @7 \. w
, N4 L5 G& ?8 t- y% k; ?; \ Columns 1 through 17# n% G+ T |4 Y* r: w8 I2 e
8 _. [9 d( H! Y- E) }* A
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 08 Y; r& Q6 c+ U
1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 13 Y8 s- s. Y/ }# ?+ g# N9 @, A( h
8 P, a8 l% f6 |2 }1 Z& h2 H
Columns 18 through 21
+ X+ l. @5 s, R9 [
0 t7 v+ t5 L$ {" ]- @8 F 0 0 0 0
$ Z/ y: E# I0 c- o 1 1 1 12 x" e# R6 \8 t5 K$ S) p! w2 W8 p* u
" h7 b# p( z4 x8 u4 T1 W8 R. l5 q. K& Q% U ]3 i& H4 \- W. F0 B4 X5 Q
y =
( V! E, \5 s; H. W4 x: A4 w$ x2 _; n2 H7 w
Columns 1 through 10
/ ?; G% X) E& _3 s: S: S
' C& y# [8 r0 n7 e4 N% }' o4 A 0 0.3090 0.5878 0.8090 0.9511 1.0000 0.9511 0.8090 0.5878 0.3090
. |9 _' t' A3 w6 B, f 0 0.3090 0.5878 0.8090 0.9511 1.0000 0.9511 0.8090 0.5878 0.3090: K" A; {/ n( x: ~* ?
1 E8 |. M" E b5 T
Columns 11 through 20
' |/ _, {+ y- {9 g N
) ]6 [$ E+ s% g& Z' K 0.0000 -0.3090 -0.5878 -0.8090 -0.9511 -1.0000 -0.9511 -0.8090 -0.5878 -0.3090
# x% `1 P8 m- W; C6 }% A. j 0.0000 -0.3090 -0.5878 -0.8090 -0.9511 -1.0000 -0.9511 -0.8090 -0.5878 -0.3090" A$ T+ }% R' g! ?8 A. O; `
5 N0 S. _& T6 u( s
Column 21# _, f9 R! v+ j, }6 r
, z/ [! E; Y1 j* q! C5 R
03 | {$ E$ N; @ p) i; [0 F
0
' K C; ?; L4 Y/ w7 u4 P* j2 B0 h% U- U* z6 O+ o
) T. M3 I# {* `4 b+ `x =
* g. @) R/ r- P# I. r6 i6 k1 [# \2 e0 w: h/ F- W+ F) m
Columns 1 through 17# |& x4 `1 P3 T; l' B, w( q6 s- j% j
6 v* G) E* G% J 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
& Y- N9 ~ f' o& v6 E6 H4 p 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1) U7 n/ N. i, D N# p/ _
: d( G) P0 E. J Columns 18 through 21
! p) E# M, L" ?" }7 B5 B$ m( w6 v. I( w# D; o1 O$ g
0 0 0 0; s" f! ~& F7 |6 _6 G: H
1 1 1 1
5 `, ?7 z2 Y. D8 M$ |3.2、[x,y,z]=cylinder(r)函数5 ~8 L9 U8 h& [5 p, k. H. h
G+ j8 a, X/ k. o8 y% ^
>> [x,y,z]=cylinder(5)
V- ?# ~) j/ M" K( j% x& @
; `! A5 P) W+ C# w- ~) J8 _x =
, X3 d9 M/ P, L5 P. G/ r: d0 K- Y; Z1 O: a: S Q" ?# h1 b, t2 Z
Columns 1 through 102 D- q7 d, a" P# C# I! o
6 D Q# v" m5 R! k
5.0000 4.7553 4.0451 2.9389 1.5451 0.0000 -1.5451 -2.9389 -4.0451 -4.7553
- k' A0 j) ], V5 Q0 Y" d 5.0000 4.7553 4.0451 2.9389 1.5451 0.0000 -1.5451 -2.9389 -4.0451 -4.7553
* g% R( S8 h, T. R. n
0 \2 s7 q0 B9 P! f5 S Columns 11 through 20
& q0 g" V8 E0 Q6 z, k S8 z @/ H v- [4 l$ z# K* c& l
-5.0000 -4.7553 -4.0451 -2.9389 -1.5451 -0.0000 1.5451 2.9389 4.0451 4.7553& p. [5 y! V) [3 F( F
% N! ?0 u3 h- F8 h/ v T+ w: B6 {4 b2 S
Column 21
7 ?2 b% b/ n. V* p
$ K, i: U3 \ W. M+ Y1 }7 h5 w5 ?5 U$ \ 5.0000! H+ g8 V; h$ k* J& E
5.0000
+ h1 N& |- J3 y0 ?: v
% ], @5 w% e8 i+ ^) u/ x, l K4 Y: Z: D
y =2 ?* h; N; K$ D% i2 I4 p6 z
1 o1 E3 }: r* H" X# E- x Columns 1 through 106 {: A" E/ [* ~ n" Z( c
6 I$ a. q* o$ W9 O
0 1.5451 2.9389 4.0451 4.7553 5.0000 4.7553 4.0451 2.9389 1.5451
5 J: L* V* Y: x) M, G 0 1.5451 2.9389 4.0451 4.7553 5.0000 4.7553 4.0451 2.9389 1.5451
. K9 \* q( k+ }! H" [* ?8 o5 v, i2 u3 ?
Columns 11 through 20) m, K# g2 ^# ?# L C
/ i* j s) i/ ^/ V n7 U 0.0000 -1.5451 -2.9389 -4.0451 -4.7553 -5.0000 -4.7553 -4.0451 -2.9389 -1.5451
1 @7 E; p0 m8 _ 0.0000 -1.5451 -2.9389 -4.0451 -4.7553 -5.0000 -4.7553 -4.0451 -2.9389 -1.5451
F" |' L$ E+ ]5 P$ J
5 k6 i% ?8 a4 }( |6 g. M. _ Column 21& S4 ]) D% R2 Y7 W
: [5 x( ?6 r8 Q* A; x8 o' z0 f' W+ g
0. Y1 h4 i( K4 D+ f
0
7 ^) C. G% \+ T% Y% r6 F! d8 ^8 e5 Z! z6 m; [: x6 H. k
. Z6 R) T1 {0 B, e( ^) u/ U& {
z =
: h+ l) m4 {$ b3 K
- Y" B" A/ {: j: H. H( I Columns 1 through 179 C- Q+ u' z; ^& ~# i
5 I2 ~2 o) B0 f, q# l
) k8 w0 K" C \4 {0 c 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1# X' L7 J# a' C6 \
! k" S2 k I& G9 m5 g; U) E Columns 18 through 21
2 r8 p. k$ i% Q
: z& C) Y6 r. F6 ^* Q# p8 C7 H5 x8 [ 0 0 0 0' r% B" P5 T0 H" C4 h; D# Z) G
1 1 1 1>> [x,y,z]=cylinder(5)
2 i$ f! s; g3 I3 c- a+ S
) Y2 m7 }3 C4 }x =
& t* O% }! c8 n* t1 t- W% S* T. k+ ?( S% }( i
! S0 n( t# B5 A- j/ ?- |$ W# v+ ^) Q$ m# {% j
5.0000 4.7553 4.0451 2.9389 1.5451 0.0000 -1.5451 -2.9389 -4.0451 -4.7553' a9 ^ d, T/ v4 ^
3 |1 y; \; z) J8 V- z
8 H% \1 | o; z Columns 11 through 20- P' q. }- Z8 R- ^" v
% T2 x! _" G @
+ b% h+ B A' H4 J -5.0000 -4.7553 -4.0451 -2.9389 -1.5451 -0.0000 1.5451 2.9389 4.0451 4.7553& S& G' P8 P6 Y! q
- q6 o$ j# ^3 I2 n, g/ m
Column 211 l' H! U4 {( i8 a+ o
- q U3 P* R1 M2 l0 b4 { 5.0000. V/ a& T! X8 j L0 [
5.0000
8 m/ m: R6 H& k; h7 x) ]' v/ I6 L0 [4 Y; k( w
0 q2 K7 E" O7 Q
y =# Y* f5 @! w4 D2 x9 i
* o G0 q r+ Q Columns 1 through 10; }& y; n+ h0 a. D2 G: L
' T6 @5 e- l* A' U" V 0 1.5451 2.9389 4.0451 4.7553 5.0000 4.7553 4.0451 2.9389 1.5451
; o9 Z2 A |9 v8 i, x% Y! s5 k A3 Z2 } 0 1.5451 2.9389 4.0451 4.7553 5.0000 4.7553 4.0451 2.9389 1.5451& t1 S1 o6 t* A$ ?1 `
* l/ i/ y& \$ U Columns 11 through 20! E' D* }. R) | O
. g5 U5 g! f* Z% m! u- V" L5 `
0.0000 -1.5451 -2.9389 -4.0451 -4.7553 -5.0000 -4.7553 -4.0451 -2.9389 -1.5451. v) T+ m6 h- v! ^
3 q. L1 i$ L/ f4 v: L9 @' l- I6 e
Column 21
0 w+ v! f) g5 h- @9 ~% J2 U" x) M4 W1 L3 s
0' a/ Y$ P% m# S }/ x
0 M8 W. n8 R6 v2 q2 I
5 v" H& l& a8 l9 U2 N4 O5 v1 b
, U3 p3 D6 ?+ l& {z =
* {3 Y7 h9 r( F" G6 s8 O
9 m* a3 }, F2 {: h* u Columns 1 through 172 m4 w1 w S) }3 o5 o) G
$ f. H5 G& R! E- B# {3 g2 ^' |
2 V1 J [; x! Q6 d$ n [0 @+ A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
" m' U/ G/ s% z. k6 O' }5 h5 t# h
5 ?. T* `2 f" c
, h4 T x, r# ]- h! v4 a- z 0 0 0 0
" U% l$ Z% j# d0 U* q 1 1 1 1
& c& l4 k2 o' q- ~1 J! j) i# [3.3、[x,y,z]=cylinder(r,n) 函数
& P2 w. H" k% H4 r1 `
; b n c7 l# U' Z>> [x,y,z]=cylinder(5,10)1 z7 k% X! W3 y1 ?% I4 C' g
- N4 Z8 U0 o l% ]4 `8 kx =
8 O. R. h' C: [4 h; k! h
( T8 {3 e" D' }4 z Columns 1 through 10
& U, }) s% U) ^/ l6 g% A4 v6 U' Q$ T# e& q/ T n
5.0000 4.0451 1.5451 -1.5451 -4.0451 -5.0000 -4.0451 -1.5451 1.5451 4.0451) v/ M: ~$ h2 w
7 @1 R D o L% W
1 I7 v, c$ @) X3 Z/ f# Q) n Column 118 |( b: @7 w8 c$ F" w
7 _4 ] K5 o. w, ~) j' J
5.0000
9 X0 q* `# a8 A e* f% C 5.0000
; x- O. e6 m8 k% r T7 ^. s# |, w( Z) C% h2 c! W6 F
3 c* e5 O8 k7 [
y =
! |3 O8 w! Z4 z! X, f
, m2 _! r& J B6 i9 X! }; P6 W Columns 1 through 100 E0 F* j1 l; j- K. U
8 R& h. T8 l% E 0 2.9389 4.7553 4.7553 2.9389 0.0000 -2.9389 -4.7553 -4.7553 -2.9389
H# p5 ?6 c* x$ C9 m. U ~6 l7 i 0 2.9389 4.7553 4.7553 2.9389 0.0000 -2.9389 -4.7553 -4.7553 -2.9389+ g! f6 {' ~! g( w( D) @% f3 h
5 K1 a. {. X- r- Y9 k$ ~& P- ?+ I; \ Column 11. z; N% u- \, }- I6 O$ f: t
9 z3 V9 ?+ J' [% @- I! }- d9 y4 K 0
* ^2 D) c$ B2 g* f 0- _& L& M5 `" _2 h; \+ V/ h
* D: W% |/ l" ~0 D3 o. X0 b0 y5 L6 j4 S+ ~( }5 t
z =
% {* H$ k6 f' R0 Z- U: t# H8 U
' Q0 x. m$ F( j y$ Z% I0 H 0 0 0 0 0 0 0 0 0 0 0/ R: G9 b. L6 K# Y% L
1 1 1 1 1 1 1 1 1 1 18 ~8 r7 r1 y" ]3 z6 e6 i
3.4、cylinder(...) 函数
! o0 x; s+ T# K( j2 b) g% \: { C$ W' x; _7 @
>> cylinder(5)' z1 R6 q0 c2 f
绘制的圆柱图. W% p2 f+ c3 M) |1 P
' R$ n% o+ e4 x" ^
6 X N$ `4 Y0 A& h6 P( W* ]
: t: U$ X. Z9 m# q) p4 n' \ |
