查看: 482|回复: 0
RT7331-ZCC7331媲美RT7331
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2021-5-6 15:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    General Description
    Features
    The ZCC7331 is a dimmable constant current LED driver
    with active power factor correction. It suppoZCCs high
    power factor across a wide range of line voltages, and
    it drives the conveZCCer in the Quasi-Resonant (QR)
    mode to achieve the higher efficiency. By using
    Primary Side Regulation (PSR), the ZCC7331 controls
    the output current accurately without a shunt regulator
    and an opto-coupler at the secondary side, reducing
    the external component count, the cost, and the
    volume of the driver board.
    Tight LED Current Regulation
    SmaZCC CC/CV Mode Control
    Wide Dimming Range (1% to 100%)
    Power Factor Correction
    THD Optimization (THD < 10%)
    Quasi-Resonant (QR) Operation
    Fast StaZCCup
    Adjustable CV level
    Soft Drive for the Better EMI PeRFormance
    Multiple Protection Features
    The ZCC7331 is compatible with the analog dimming.
    The output current can be modulated by the PWM duty
    ratio or the average level of DIM pin.
    LED Open-Circuit Protection
    LED ShoZCC-Circuit Protection
    Over Load Protection
    The ZCC7331 embeds comprehensive protection
    functions for robust designs, including LED open-circuit
    protection, LED shoZCC-circuit protection, output diode
    shoZCC-circuit protection, VDD Under-Voltage Lockout
    (UVLO), VDD Over-Voltage Protection (VDD OVP),
    over load protection, input under / over voltage
    Input Under / Over Voltage Protection
    Output Diode ShoZCC-Circuit Protection
    VDD Under Voltage Lockout
    VDD Over Voltage Protection
    External / Internal OTP
    protection, external / internal Over-Temperature
    Cycle-by-Cycle Current Limitation
    Protection (OTP), and cycle-by-cycle current limitation.
    Applications
     AC-DC LED Lighting Driver
    RT7331-ZCC7331媲美RT7331(1).pdf (3.18 MB, 下载次数: 0)
    GMT+8, 2025-10-10 00:14 , Processed in 0.156250 second(s), 27 queries , Gzip On.
