查看: 3348|回复: 0
网表生成的问题
发表于 2011-4-3 08:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#77 ERROR(SPCODD-77)! w# J: |8 T% X8 S
: Could not open file d:\cadence\mysch\allegro/pstxprt.dat.$ c% U7 e' V# r: E
You might be trying to reuse a design with an inaccessible state file. To reuse a design, ensure that the design being reused is treated as a subdesign and the subdesign state file is accessible and readable. To create the subdesign state file, use the GEN_SUBDESIGN directive.3 f- {1 }6 ~5 z- U4 ]: `
ERROR(SPCODD-382): Error at line 1 in file d:\cadence\mysch\allegro/pstxprt.dat. Error loading the parts list file
4 r& }! a" V8 Y6 s7 S) |+ k7 U- P! @5 l2 Q1 J' i9 n1 N+ R+ L6 Q3 }
这个是什么错误???原理图里只有一个电阻,测试用的
  t- ], c' @# p, f9 F  N6 V5 d9 {
GMT+8, 2025-10-10 10:49 , Processed in 0.125000 second(s), 24 queries , Gzip On.
