查看: 668|回复: 0
5A输出同步降压ZCC3605A替代LTC3605A
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2020-12-21 15:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    n High Efficiency: Up to 96%
    n 5A Output Current
    n 4V to 20V VIN Range
    n Integrated Power N-Channel MOSFETs
    (70mΩ Top and 35mΩ Bottom)
    n Adjustable Frequency 800kHz to 4MHz
    n PolyPhase®Operation (Up to 12 Phases)
    n Output Tracking
    n 0.6V ±1% Reference Accuracy
    n Current Mode Operation for Excellent Line and Load
    Transient Response
    n Shutdown Mode Draws Less Than 15μA Supply Current
    n ZCC3605: 15V Absolute Maximum VIN
    n ZCC3605A: 22V Absolute Maximum VIN
    n The ZCC3605A Is Pin Compatible with the
    ZCC3605
    n Available in 24-Pin (4mm  4mm) QFN Package
    GMT+8, 2025-10-9 14:59 , Processed in 0.140625 second(s), 28 queries , Gzip On.
