查看: 1117|回复: 7
OrCAD Library Builder导出封装没有焊盘
    奋斗
    2023-5-4 15:40
    发表于 2020-12-1 17:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    orcad Library Builder导出封装没有焊盘,结合咱们网站上的帖子也看了一遍,但是还是没解决,烦请各位大神出出招。
    : A  O$ {' l0 l) r4 H3 `3 Y! Z8 U前边直接使用IPC1573标准创建了一个电阻的封装,打开allegro以后运行过程如下:0 x( _1 f( a* K
    Loading axlcore.cxt
    , w" [& @- N0 L4 [) O/ g# v; yStarting new design...
    6 J; R, h9 c" Z, O: {+ bReading Footprint XML
    , b: r- Y; j$ P7 y( g! [- HCreating padstacks
    ! U2 f! @# X# jStarting new design...
    1 A& Q! R  v! Z/ _1 g5 nPeRForming DRC...& a7 [& C- m- D; U2 ?& i# v" D3 C
    Multithreaded DRC update (8 threads).
    ' \5 I8 v' D! m3 {$ oNo DRC errors detected.
    3 f* c. a# X2 P' m4 D$ bPerforming a partial design check before saving.
    & }/ Y" F# b# [, fWriting design to disk.0 b1 c) M3 n1 z( |  X" ^$ ~9 _
    'r215_300.pad' saved to disk.) h" ]# Z" K% G, a% a: S& H
    Opening Design "RESMELF7028N.dra"
    . m2 W: e5 ~7 E9 A' XW- (SPMHUT-48): Scaled value has been rounded off." O8 E+ t* s; \; z( o9 p8 J1 d  ?
    Starting new design...- U' B  A- b* J, M+ V1 [/ I* n* A
    Creating Shapes on Package layers' o9 g& N! L! _$ n7 A) a
    Creating Pins
    - w/ _! a4 ?+ P! i" x$ C( w0 p& I# Q% uCreating Vias
    0 d. x' b5 t% U9 LSymbol Created
    2 Q+ }+ X* Y- C2 w5 H% d, mCreating package symbol 'E:/cadence/RESMELF7028N/RESMELF7028N_Allegro/resmelf7028n.psm'.4 |& R6 ~0 `3 T) Y2 {
    Starting Create symbol...+ ^8 {1 @! A* `; p; f  G6 ]" R
    create_sym completed successfully, use Viewlog to review the log file.8 i3 A) b) x2 Y. \3 |
    5 l1 D1 m1 H2 J* v0 lSymbol 'E:/Cadence/RESMELF7028N/RESMELF7028N_Allegro/resmelf7028n.psm' created.
    : @2 ?2 P( I; R3 \# ]! `Loading cmds.cxt / o- d8 L( \7 a$ S5 O! a
    Loading skillExt.cxt
    % U2 @9 m. ?" g# O' uE- (SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file.
    + r) V' p' t* U0 o0 yPerforming a partial design check before saving.
    ! v" l" |/ @. z* K( f' S- c$ E' J8 M: ]) {Writing design to disk." x1 |2 i; g" L5 H( v5 p
    'RESMELF7028N.dra' saved to disk.7 |6 x% W, h6 Y
    Opening existing design...
    - I% U5 F9 s/ j6 z' q# aSymbol Saved& l* e0 Q) U8 \
    t
    3 Z% m0 [- Z; g# l. ICommand >
    # L( S, C6 ^" G# A5 B* |5 u( @) @ 电脑没有安装skill,allegro用的是17.2,OrCAD Library Builder用的是老吴网站提供的最新版。问题出现后,在allegro中设置了路径,还是问题依旧存在; T' d. l! H& G9 U. D/ N1 X- v
    2023-1-11 15:38
    发表于 2020-12-1 18:00 | 只看该作者
    有没有生成PSM
    发表于 2020-12-2 10:06 | 只看该作者
    您确定显示了?
    4 i3 J! ~  f( R& J0 {
    无聊
    2019-11-18 15:40
    发表于 2021-1-8 16:34 | 只看该作者
    在路径管理添加一下$padpath和$psmpath试一下
    您好,是在哪个路径下添加呢,我在pad/psm下添加了,还是不行,谢谢。  详情 回复 发表于 2022-5-12 17:53
    发表于 2022-5-12 12:08 | 只看该作者
    这个问题得到解决了吗,我也遇见了。
    你楼上是正解  详情 回复 发表于 2022-5-12 14:15
    2023-6-5 15:38
  • 签到天数: 51 天
    [LV.5]常住居民I
    发表于 2022-5-12 14:15 | 只看该作者
    xubf01 发表于 2022-5-12 12:08
    7 M3 q% }! I' t0 |; k9 [& H这个问题得到解决了吗,我也遇见了。
    7 S. o4 k5 K4 q% ?& g$ u
    你楼上是正解
    : l: R, a; p6 D2 c: r. A
    发表于 2022-5-12 17:42 | 只看该作者
    我的错误是这样的# g1 G$ e5 h2 g3 B5 r# ~" I  \
    Loading axlcore.cxt ! {& T) v8 Q, o9 O; M: t
    Starting new design...: K5 c) {: j/ h& h+ j0 `3 G5 y  Q. A
    8 U4 O1 s7 f6 pCreating padstacks
    . v, Y: N5 d5 y; M- @, pStarting new design...3 V8 L7 z. p" k
    Performing DRC...
    ; A' a% C( S* w# [Multithreaded DRC update (12 threads).
    2 F4 L' Q. w1 C  E/ ?No DRC errors detected." w. k9 C/ @' Z0 g- ?
    Performing a partial design check before saving., ]# V1 s; T. d' W2 I
    8 b: @! t# ^2 z/ D3 u0 S3 S; G, ?'r172_60m192_80.pad' saved to disk.
    , X1 A: ~) H4 Z# o: ]7 ]% W  xOpening Design "SOIC127P1031X140-16N.dra"
    3 {; S" w1 n! _- @& H% i: VW- (SPMHUT-48): Scaled value has been rounded off.
    : @2 o2 F. K( |: S6 l% u* GStarting new design...
    $ h1 [4 [, M* K0 j, P" N  g, BCreating Shapes on Package layers
    * |  g1 i7 O% y+ ^2 M( N. n( U) w2 GCreating Pins
    2 H, f# U1 V4 l4 i: h2 yCreating Vias
    # u  I" O9 d+ Y( ?: fSymbol Created& [( a; C1 D1 G0 z4 T
    Creating package symbol 'C:/Users/xbf/Desktop/SOIC127P1031X140-16N/SOIC127P1031X140-16N_Allegro/soic127p1031x140-16n.psm'.
    $ G' q2 y7 {7 S' t4 o0 d# QStarting Create symbol.... h  ?1 L% T9 ]6 H+ M
    create_sym completed successfully, use Viewlog to review the log file.+ J& U2 \/ I% N2 q( C
    create_sym completed successfully, use Viewlog to review the log file.' g# `; O; h3 w( P/ y
    Symbol 'C:/Users/xbf/Desktop/SOIC127P1031X140-16N/SOIC127P1031X140-16N_Allegro/soic127p1031x140-16n.psm' created.
    ! h  Z; x- I1 L& aLoading cmds.cxt
    / f0 ^) M, k9 |( Q4 K) q2 DLoading skillExt.cxt
    ( x$ o9 m0 f# d# K# DE- (SPMHA1-161): Cannot open the design because of database problems. Run the dbdoctor command on the design and try to open again.+ t+ s5 }. D  y; ^
    Performing a partial design check before saving.( t' F5 D2 |' f& L8 ]! _3 A
    8 t& F* ?6 l/ a1 Y( m9 Y'SOIC127P1031X140-16N.dra' saved to disk.
    6 \1 d$ G. e  \; ]Opening existing design...( ]3 q" q1 b( F
    Symbol Saved$ [7 p* F! `3 D8 P( N9 n. M) d
    t
    5 l7 r# Y1 u# w" E6 P0 X4 j% oCommand >
    发表于 2022-5-12 17:53 | 只看该作者
    不期而遇 发表于 2021-1-8 16:34) i- x) R( ^0 N) `9 w
    6 k& s! l4 f: a- y' X# n% D您好,是在哪个路径下添加呢,我在pad/psm下添加了,还是不行,谢谢。
    + P7 \2 J. B% C$ H% _
    GMT+8, 2025-11-5 15:39 , Processed in 0.171875 second(s), 27 queries , Gzip On.
