查看: 1187|回复: 3
simulink 仿真出现过零问题
发表于 2020-11-24 16:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
simulink 仿真出现过零问题,部分错误如下:
$ v' h; ~2 `! _0 U& MAn error occurred while running the simulation and the simulation was terminated' H! J0 J5 j6 x0 o$ P3 A
Caused by:
3 Q: O5 T2 N1 f4 vAt time 0.0016915343915627594, simulation hits (1000) consecutive zero crossings. Consecutive zero crossings will slow down the simulation or cause the simulation to hang. To continue the simulation, you may 1) Try using Adaptive zero-crossing detection algorithm or 2) Disable the zero crossing of the blocks shown in the following table.
4 F* W3 v6 p9 r7 m--------------------------------------------------------------------------------# z( D- C/ k, n4 W, O# e
Number of consecutive zero-crossings : 52860
; `+ r0 m  }  b+ `. H           Zero-crossing signal name : MinmaxInput, q4 H' r0 Z6 T* R! E
                          Block type : MinMax
! S1 @# m2 }" `# }6 p$ d                          Block path : 'untitled/Fuzzy Logic  Controller/FIS Wizard/Rule6/impMethod'
6 ~) N+ A- i) f6 l4 }; _8 F8 D--------------------------------------------------------------------------------
' ?4 Z! K  \) [( e--------------------------------------------------------------------------------
5 E9 m2 ?* A4 y+ ~8 K7 h: b, W1 {Number of consecutive zero-crossings : 43358
+ {  w: E1 N; G0 w           Zero-crossing signal name : MinmaxInput
; }2 p; Q: _: X9 T# Q                          Block type : MinMax# D7 s$ }5 P$ ^4 W
                          Block path : 'untitled/Fuzzy Logic  Controller1/FIS Wizard/Rule16/impMethod'
. d0 h8 @4 A6 V- A) G1 M9 W--------------------------------------------------------------------------------( B2 N9 j$ W+ g" i3 @9 A
--------------------------------------------------------------------------------+ i, p' `1 V  u5 n* o
Number of consecutive zero-crossings : 36086
! K! e6 |- F4 r8 [3 {, K3 j2 _$ G- y           Zero-crossing signal name : MinmaxInput
: L9 ~/ Y8 ?+ B: E* U3 e. L2 c. r3 t                          Block type : MinMax
9 q6 n/ k2 o  s4 i- C2 z; R+ O2 w                          Block path : 'untitled/Fuzzy Logic  Controller/FIS Wizard/AggMethod1'/ q& [: J1 y- M" x8 G
--------------------------------------------------------------------------------4 `  F1 D; w7 o
--------------------------------------------------------------------------------5 w/ w' H+ f9 V& ?/ d
Number of consecutive zero-crossings : 34908
& X/ a3 I0 D1 W% E; Y           Zero-crossing signal name : MinmaxInput3 y& l5 m% n# O
                          Block type : MinMax' ?* n# p' G, [6 {; A
                          Block path : 'untitled/Fuzzy Logic  Controller/FIS Wizard/Rule3/impMethod'
2 x! L9 Q! o' G% ^/ Z--------------------------------------------------------------------------------$ m9 ?) q0 @1 |: `$ \* C% o1 E) v
2 o# b. M: N" s# K" ?Number of consecutive zero-crossings : 33500* B6 S6 ^3 J' `, L
           Zero-crossing signal name : MinmaxInput3 A2 Q* R0 i' \* L4 L
                          Block type : MinMax
$ p( a6 m- E3 B4 e                          Block path : 'untitled/Fuzzy Logic  Controller/FIS Wizard/Rule9/impMethod'
! q+ Q/ L3 G" N1 W2 I--------------------------------------------------------------------------------; v  @: o5 V% x- d, n
) @4 H1 b& F- V. ]( GNumber of consecutive zero-crossings : 335006 Z" b6 A5 F; p) C
( X9 Y  q# L' k6 w                          Block type : MinMax4 U3 F* a' f+ c5 C" q' ~( e% K9 ]
                          Block path : 'untitled/Fuzzy Logic  Controller/FIS Wizard/Rule2/impMethod', D  L+ }  a$ r' F0 {  ~
3 d- k( N! H  r$ v/ j--------------------------------------------------------------------------------/ C* }; g0 g+ Z9 C3 `
Number of consecutive zero-crossings : 30500
8 T' h: [+ s% w( o           Zero-crossing signal name : MinmaxInput
( i; S4 t6 T9 \0 g0 l) r0 [' [7 D                          Block type : MinMax
- }! ?: ?" G4 E2 |# k" o% V% H' S                          Block path : 'untitled/Fuzzy Logic  Controller1/FIS Wizard/Rule1/impMethod'
( i! G" H9 ]& h--------------------------------------------------------------------------------% O$ t  u: S: w* y" F+ |: Q
/ e: X" p( r6 Z" l6 Z1 R
( c5 X( h3 f1 z$ x9 K% s
7 R# E5 |6 I: `3 p& g1 H+ v(中间错误省略: O/ ~, T6 ^  q' l
--------------------------------------------------------------------------------& Z. z2 ~4 k- w% |$ C. m& K# z
Number of consecutive zero-crossings : 2  J$ C# G+ G3 O& C$ G9 z( W/ k
2 U( G8 k. C1 ~  c. c, G2 e" V                          Block type : MinMax7 `% B! J9 t( v; G& M
                          Block path : 'untitled/Fuzzy Logic  Controller/FIS Wizard/Rule6/andorMethod'
) d& S; f+ a* \8 q  H. o) Y+ N--------------------------------------------------------------------------------
$ h+ t& J& O# c+ n! L; ?--------------------------------------------------------------------------------
- i  K  g( A( ]: {$ e, }% |Number of consecutive zero-crossings : 2
- @6 A- e+ Y' F" c0 }9 r# ~9 j: V           Zero-crossing signal name : MinmaxInput' k/ _, e) E  ^; l
                          Block type : MinMax9 A& F- [  U% I; A7 T
                          Block path : 'untitled/Fuzzy Logic  Controller1/FIS Wizard/Rule23/andorMethod'& ?1 y! X" o9 h8 ]( W
--------------------------------------------------------------------------------# X- s  ~* {+ t. c2 D" ]* [
--------------------------------------------------------------------------------% |$ E  h# F! Z) ~0 g- h) }! R  [
Number of consecutive zero-crossings : 2- p" ^' M& d5 F" X2 f1 `
           Zero-crossing signal name : MinmaxInput+ f+ Q% g# ?5 y, J: y
                          Block type : MinMax
; y' p* d/ g- {" D" |) B                          Block path : 'untitled/Fuzzy Logic  Controller1/FIS Wizard/Rule24/andorMethod'& Q5 Z5 S' H7 v
+ W% E+ R0 v. T9 V1 H" N8 K: C--------------------------------------------------------------------------------
7 O9 Z6 y, k: ~; bNumber of consecutive zero-crossings : 2
& r& a" H7 J7 t& T+ ]3 ~* s           Zero-crossing signal name : MinmaxInput
' Y8 f# {9 S2 B8 {" ]$ R                          Block type : MinMax5 T9 A; a0 Z# m7 I
                          Block path : 'untitled/Fuzzy Logic  Controller1/FIS Wizard/Rule25/andorMethod'
7 U5 h& v+ |% i3 y! v+ r! n* G--------------------------------------------------------------------------------( I0 B) b7 e# l5 I
You can turn off this message by using the MATLAB command:
. p5 K8 |& m  k9 Oset_param('
untitled','MaxConsecutiveZCsMsg','none');
9 A9 a: r+ P* O7 r6 N/ V
发表于 2020-11-25 13:35 | 只看该作者
楼主你解决了吗
发表于 2020-11-25 13:40 | 只看该作者
帮你顶一下
GMT+8, 2025-11-1 06:54 , Processed in 0.140625 second(s), 23 queries , Gzip On.
