请问:
4 k4 ]8 g6 v( v问题1:用LOGIC画原理图除了用off-page连接网络外,还可以怎么填加网络标号?而且使用off-page经常出现以下的警告呢,好多啊,怎么解决啊?
+ u$ o* A" E/ Y: `Line 36 , Section *DEL_ATTRIBUTE*+ C1 G y6 K6 x% K& y
"Comment"
1 J" J% s! \( E. d, M5 t6 o. z7 ]* WARNING: Processing command to delete attribute "Comment" from Component J11.8 U" q! B l. q9 a' X2 @3 X
* The attribute is also inherited from Decal 302S-60P.8 |( \" |# i( D4 p: [' @
* The change is not fully reconciled for cases where the schematic$ C& h. ?& a& p! u. j# M! }
* does not support hierarchical attributes.
; K* I$ |0 i' k4 c( oLine 38 , Section *DEL_ATTRIBUTE*
4 N- \6 h" ?2 ?$ l5 J/ ~# d"Comment"- t; e. x s8 ?1 I5 T
* WARNING: Processing command to delete attribute "Comment" from Component L1.7 N' g2 X7 }8 ~/ [% |
* The attribute is also inherited from Decal L-9UH/1A(3.5).
( Q, O7 V8 }/ }* The change is not fully reconciled for cases where the schematic" W; O& C5 u# p( _4 W; v
* does not support hierarchical attributes.% {- ~% ^6 K7 ?* O- \9 g6 ?+ z
问题2:在PCB中,某些元器件的某个脚与大面积铜连接(类似于原理图中的总线),该怎么实现呢,是使用copper 还是copper pour?又或者其他的。, z$ X3 i) U: m+ b1 ^2 r! }6 z$ m
谢谢! |
