查看: 292|回复: 1
u-boot移植时出现inline function 'coloured_LED_init' cannot b
发表于 2020-11-2 13:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
9 {6 C# o3 P7 `& V) B- T# J0 i
board.c:127: error: inline function 'coloured_LED_init' cannot be declared weak
4 Z8 _  J5 e. Tboard.c:129: error: inline function 'red_LED_on' cannot be declared weak6 p. m, I7 |; ?3 c2 h" V9 Z
board.c:131: error: inline function 'red_LED_off' cannot be declared weak
7 v# g6 k( ^* Uboard.c:133: error: inline function 'green_LED_on' cannot be declared weak
/ N' X. w- N; `6 s' C4 D$ {+ \board.c:135: error: inline function 'green_LED_off' cannot be declared weak
4 B9 Q. O9 [% h4 xboard.c:137: error: inline function 'yellow_LED_on' cannot be declared weak- e( z8 d' Z% A4 h3 m; C3 x  w: `
board.c:139: error: inline function 'yellow_LED_off' cannot be declared weak
, E1 y* y2 x$ L3 ], d" V7 @# o+ qboard.c:141: error: inline function 'blue_LED_on' cannot be declared weak
1 `( l8 ~0 O, `  ?6 C. ^board.c:143: error: inline function 'blue_LED_off' cannot be declared weak6 o. ~2 g% R: i; f6 f9 [
make[1]: *** [board.o] 错误 1
% k+ G. o: L! Y- K; j& Omake[1]: Leaving directory `/root/workspace/u-boot-2009.08/lib_ARM'6 I% G/ ?8 S; F
make: *** [lib_arm/libarm.a] 错误 2
' T5 y0 l7 H9 @" A* R4 p/ K# k[root@localhost u-boot-2009.08]#' h. Y5 I* A9 Y7 Q) F! U
6 e! y! ]+ q  A# O$ I- q出现错误,内嵌函数不能被声明为weak属性,打开lib_arm/board.c,定位到127行开始,将其注释掉,修改后结果如下:
3 D+ e, m0 x: a8 H
, E% m4 a6 X+ F8 d' I. T3 G' @# avoid inline __coloured_LED_init (void) {}
1 u. \: c2 z! D0 S# H//void inline coloured_LED_init (void) __attribute__((weak, alias("__coloured_LED_init")));
( d& J/ ]' U" R2 ^, X7 ^void inline __red_LED_on (void) {}; E+ i" q4 y2 p4 ~
//void inline red_LED_on (void) __attribute__((weak, alias("__red_LED_on")));# S( s: ?. q$ O' [; A  r
void inline __red_LED_off(void) {}
( w3 ~3 g, M) c7 [$ R//void inline red_LED_off(void) __attribute__((weak, alias("__red_LED_off")));2 w0 q8 v; T- t$ I: r
void inline __green_LED_on(void) {}- ]) P& x/ Q% Q) {) J9 K( u
//void inline green_LED_on(void) __attribute__((weak, alias("__green_LED_on")));
+ r3 K5 S+ U7 O' P. v' wvoid inline __green_LED_off(void) {}" `, r. c- {6 C1 J
//void inline green_LED_off(void)__attribute__((weak, alias("__green_LED_off")));
+ z, f7 I! }4 Avoid inline __yellow_LED_on(void) {}3 L0 T- {5 ?, l7 q1 a6 q$ a2 L
//void inline yellow_LED_on(void)__attribute__((weak, alias("__yellow_LED_on")));
8 u4 X3 Y+ Y, h" X+ U) A) s0 ivoid inline __yellow_LED_off(void) {}
. R- O4 C" G& V0 n5 T4 l//void inline yellow_LED_off(void)__attribute__((weak, alias("__yellow_LED_off")));
0 d. e0 L; b3 |6 Z, V* ?8 |" {void inline __blue_LED_on(void) {}* C1 a4 k1 _0 n' {
//void inline blue_LED_on(void)__attribute__((weak, alias("__blue_LED_on")));
/ b! g* p" n. X0 Evoid inline __blue_LED_off(void) {}9 V: Y' r) s5 {. K3 ^9 h
//void inline blue_LED_off(void)__attribute__((weak, alias("__blue_LED_off")));5 q* b) w" g8 _. {3 o
2 l2 p3 M1 g; D! C. @8 k* B
[root@localhost u-boot-2009.08]# make clean+ ?$ v, m/ V# q2 V
( Z3 ^9 O( f! V. C[root@localhost u-boot-2009.08]# make
    2019-11-29 15:37
    发表于 2020-11-2 14:18 | 只看该作者
    GMT+8, 2025-7-18 11:00 , Processed in 0.109375 second(s), 23 queries , Gzip On.
