查看: 1427|回复: 11
Matlab辅助激光光学分析与应用(2014年 第三版)
发表于 2020-10-12 09:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Matlab辅助激光光学分析与应用(2014年 第三版), E: b' |2 h& O
; F+ Q1 R+ k# e& K4 _/ i目 录6 M3 O) [' }# @; b
MATLAB辅助激光光学分析与应用....................................................................................................I
8 u$ V. h0 A  r! W: QMATLAB辅助激光光学分析与应用...................................................................................................II
8 v% v% O7 k2 ~" {7 {; ^作 者:刘良清..............................................................................................................................II' Q! @  B8 a2 S0 C, F0 ?
第一章 光的波动性和衍射............................................................................................................... 1* l4 C( s: {* c# N% M9 `
1.1 MAXWELL方程组和电磁波........................................................................................................1+ n7 T5 [% C3 v  v! Q: m: ]0 f
1.2 波动方程.......................................................................................................................................4
$ \  f  {" A. D6 m1 f& |9 c, g1.3 衍射...............................................................................................................................................59 P( b1 r; U2 k% u0 k* |! z( {
1.3.1 小孔衍射................................................................................................................................6
+ r0 i0 I+ S! i. o+ g( C. y1.3.2 双缝衍射..............................................................................................................................14: k$ Q5 \2 @! l. S$ K7 F1 X
1.4 波前畸变.....................................................................................................................................17
5 Q5 ?# j  g) @2 X) G$ |( J0 e& K1.4.1 Zernike多项式......................................................................................................................17! @& B/ `" _% a
1.4.2 畸变光束的衍射..................................................................................................................20
% q! l4 V4 b1 z0 ~5 X, L; i1.5 光束通过光学元件的变换.........................................................................................................247 d5 y+ M6 Z; q+ s+ t/ [( s) @
1.5.1 平行光束通过透镜的聚焦..................................................................................................24
% A' Q  j# s0 U" [( d* f1.5.2 高斯光束通过透镜的聚焦..................................................................................................30
$ r/ A7 s) Z) i& H/ s+ C) D. b1 f1.5.3 自聚焦透镜..........................................................................................................................32
! r0 h. m* W8 ?$ |- q1 g1.6 高斯光束.....................................................................................................................................36* E4 \2 ?- c7 E9 d7 |" l* M9 [
1.6.1 高阶高斯光束......................................................................................................................36* J4 N5 T  o) o; I3 Z! L3 d' ]4 N
1.6.2 高斯光束的传输变换..........................................................................................................41
" W. Z! }1 ~2 r! s9 O7 o+ ^& u) X1.6.3 高斯光束的干涉..................................................................................................................45
& D) t4 I% z$ p1 k- ], R/ G  U第二章 激光谐振腔......................................................................................................................... 60/ z9 ^- m3 i& t' D
2.1 激光谐振腔的本征方程.............................................................................................................60
0 G+ M- r( b+ a* ?6 q' R; {/ U  Q0 \2.2 无源腔的FOX-LI迭代方法.......................................................................................................602 O4 c# G/ r1 w% Y2 ~
2.3 无源腔的矩阵特征向量方法.....................................................................................................66
3 m, _' L3 ]7 I2.3.1 平行平面腔..........................................................................................................................676 X) j9 q* H$ |" N# e: p6 P% J
2.3.2 双凹腔..................................................................................................................................71
3 L% n) L9 Q+ y! S2.4 基模谐振腔.................................................................................................................................78
+ S0 c0 r8 b2 Y2 \1 w2.4.1 高斯光束的ABCD定律与谐振腔.......................................................................................80
4 [2 t1 i! H" C, O2.4.2 基模谐振腔的稳定性..........................................................................................................91+ J' ]& X+ y. n- s/ W5 t; r
2.4.3 基模谐振腔设计实例..........................................................................................................97
1 ]. V7 I! L$ s* g$ ?2.4.4 基模谐振腔设计的逆向方法............................................................................................107
: ]5 E. Z* p6 v. e第三章 激光工程设计................................................................................................................... 118
# [7 B4 x$ @) |  @; a3.1 速率方程的求解....................................................................................................................... 118
% u% o' O: f; |# `+ T. D- o3.1.1 主动调Q速率方程的求解................................................................................................. 118
* L  s  G  T- S4 ~3 m; `8 m3.1.2 被动调Q速率方程的求解.................................................................................................125
) \* X% D- m% m* }3.1.3 脉冲泵浦速率方程的求解................................................................................................132+ C: E# _; `# z" K0 B. v' d9 u9 j
3.2 非线性激光光学.......................................................................................................................136) X9 h  c" I3 H7 [4 g5 i2 v7 @4 _; x
3.2.1 非线性晶体........................................................................................................................136
& e2 s' \. h+ h3.2.2 非线性晶体相位匹配........................................................................................................1617 _( `! W3 x1 h. B9 c5 k; c5 a
第四章 MATLAB数据与图像处理............................................................................................... 171# i" I6 f. t$ B! N. B
4.1 MATLAB图像处理应用...........................................................................................................171
% ?4 E3 \- @- y4.1.1 自制特殊图形....................................................................................................................171: n" `' O& g2 ^* G
4.1.2 图像数据处理....................................................................................................................179+ n/ z0 ]( s: p7 s( e# I
4.2 MATLAB数据处理应用...........................................................................................................197
* W& p+ y) F, ?: u/ u) Q# l8 d4.2.1 批量数据处理....................................................................................................................197
! R. M' ?! c. e4.3 MATLAB方程求解应用...........................................................................................................211
1 v2 u( B* E$ a9 t+ V8 u: |; U" U4.3.1 含参数非线性方程组的求解.............................................................................................2119 V; _/ L( z# s( P# ?  f- ?
游客,如果您要查看本帖隐藏内容请回复
参与人数 1威望 +1 收起 理由
grand + 1
发表于 2020-10-12 11:25 | 只看该作者
Matlab辅助激光光学分析与应用,收藏了。
发表于 2020-10-12 15:09 | 只看该作者
谢谢楼主分享!!!!
' _& E: e3 p+ \" m9 _3 q* K
发表于 2021-5-20 14:23 | 只看该作者
谢谢分享,非常需要,感谢楼主
发表于 2021-6-7 12:09 | 只看该作者
Matlab辅助激光光学分析与应用(2014年 第三版) [[url=]修改[/url]
2 f7 u# f" Y9 ~4 g7 u
发表于 2021-6-16 22:15 | 只看该作者
多谢,值得一看
发表于 2021-7-13 03:03 | 只看该作者
谢谢 学习学习
    难过
    2021-4-9 15:31
    发表于 2021-7-13 14:40 | 只看该作者
    感謝大大無私分享
    发表于 2021-10-5 22:32 | 只看该作者
    thxxxxxxxxxx
    . n2 n1 D: y8 ~& @0 L7 J9 B
    发表于 2021-10-6 14:14 | 只看该作者
    谢谢楼主分享
    发表于 2021-11-17 16:39 | 只看该作者
    年烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦烦4 z. W. L$ }& t
    GMT+8, 2025-10-28 20:20 , Processed in 0.171875 second(s), 30 queries , Gzip On.
