查看: 1492|回复: 10
17.4hotfix011
发表于 2020-10-5 00:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Fixed CCRs: SPB 17.4 HF011 - Date: 09-30-20205 A) ]7 E# ~* w
5 `1 h3 M6 J6 e1 @2 G/ k
=============================================================================: H0 K6 m. X% B: ~1 P6 A
CCRID Product ProductLevel2 Title! [: ~- k$ v9 S" A% t5 J
5 L' B  I1 S' j7 J2 P9 @2313464 ADV_PKG_ROUTER OTHER APR fails to route because no routing path exists between pins
0 n( K. h/ A, |6 l7 n, y; I2321955 ADW COMPONENT_BRO UCB with SSL and variable CDS_ENABLE_UCBCLIENT_DOWNLOAD$ K2 R* U1 \5 J+ \& F: M. U# u
2295605 allegro_EDITOR DFM Pin to shape same net DRC is not working
) j" z! v! i; s+ z" |0 |2325628 ALLEGRO_EDITOR DFM DRC Browser 'Layer Visibility' function is not working
/ D5 a5 l8 t# l& n" W2142093 ALLEGRO_EDITOR SHAPE Shape not updating automatically due to issue with cline void oversize: Manual "update to smooth" required
) a1 f1 ]" \1 N% c: Z# T4 I2300747 ALLEGRO_EDITOR SHAPE HotFix 008: 'Shift' cancels add shape: O" l; z/ J$ w7 [: x9 D* V
2312838 ALLEGRO_EDITOR SHAPE Unable to use 'Shift' while using the command 'shape add'
. F1 C' a: K. d% I& G2324592 ALLEGRO_EDITOR SHAPE When adding shape, selecting the 'Shift' key ends the process( ?0 K" t7 ^1 h; g
2234999 ALLEGRO_EDITOR UI_FORMS Weird behavior of license usage log functionality in release 17.4: Cannot see complete report and error on closing
  D; a" Q! o3 ~8 `+ g! d- R2304892 ALLEGRO_EDITOR UI_GENERAL 'File > Save As' does not prompt for confirmation to override file! g( M: K8 `$ B# ~# }
2309890 ALLEGRO_EDITOR UI_GENERAL "Save As" command overwrites existing files without warning.! J# T* t9 }( h, q8 Y. b. l
2317739 ALLEGRO_EDITOR UI_GENERAL DML model does not load in SigXplorer
' f- k  @* c  b. W) _7 i7 x2297096 APD DFA The Minimum Shape Width check may not report an error.% p$ W8 C( P: Z+ d3 S5 _! L
2197727 CAPTURE PROJECT_MANAG 'Save Project As' to UNC path does not work properly: Saves directory locally
: L4 }6 v" g; q2306341 concept_HDL CORE NetGroup member removed/lost after 'Save Hierarchy'  e- P7 m  \2 A5 Q/ ?  ~5 ]' G' L
2319615 CONSTRAINT_MGR CONCEPT_HDL DE-HDL CM-defined Region Class to Class Spacing constraints not exporting to Allegro PCB Editor+ m  [* D2 k) B9 H# G9 c
2226706 CONSTRAINT_MGR UI_FORMS Release 17.4: Constraint Manager font not sharp (appears fuzzy)
0 v# w* V5 j. u$ m0 m2299543 CONSTRAINT_MGR UI_FORMS Analysis Mode Electrical Form distorted0 |% A) h% S. L0 h: y, r
2305020 CONSTRAINT_MGR UI_FORMS Text is overlapped on the Electrical Constraints tab of Analyze Modes form of Constraints Manager with light theme.
- D# Q/ x! g0 r' ]2230544 PULSE R2PLM Publish to manufacturing does not launch if project path begins with an underscore2 n  k. D/ {5 M. x- T. r
2308952 PULSE R2PLM Generate button inaccessible if there are many utilities on the Generate page# a! Q* ?5 A& a3 u" u! [! G
2323902 SIP_LAYOUT INTERACTIVE Rotation occurs randomly when copying objects multiple times.
) Y+ Q- |7 W9 {- X2325542 SIP_LAYOUT INTERACTIVE Function key rotate of copied part does not show preview correctly  G5 C! R6 e% y9 z' }6 j
2328253 SIP_LAYOUT INTERACTIVE Rotate setting not being applied when copying and pasting symbol2 m# ~2 c' K1 x- o. V
2305709 SIP_LAYOUT ORBITIO_IF APD crashes when selecting the 'Help' button in the 'Orbit import' dialog
8 x( b3 T3 C, M" P0 n5 g) G. x2310340 SIP_LAYOUT OTHER SiP Layout - Die Properties - adding shrink to a die at design coordinates other than 0,0 results in change of origin# j( E' k1 N9 R0 v! r
1962599 SYSTEM_CAPTURE NAVLINKS The $XR property placeholders are not honored and orange dots appear at their locations& n* c. N1 f9 G, V
2037440 SYSTEM_CAPTURE NAVLINKS NavLinks location is reset after moving offpage body. }; ?: [& q" B6 l) W: z* S! [
3 O; _- H2 [3 D
) O' r+ W9 Z* M6 A7 L
7 n7 E% a3 q2 h/ h, d, W
; h$ v' ?) Y# U4 a/ b网上已流出9 z' l; x  E4 n8 ~2 q) t
    2022-9-26 15:32
  • 签到天数: 30 天
    [LV.5]常住居民I
    推荐
    发表于 2020-10-5 09:15 | 只看该作者
    请教一下,这个补丁哪里能下载,给个下载链接
    发表于 2020-10-5 09:27 | 只看该作者
    真的即时啊!谢谢
    发表于 2020-10-5 10:42 | 只看该作者
    难过
    2025-1-20 15:39
  • 签到天数: 100 天
    [LV.6]常住居民II
    发表于 2020-10-5 13:10 | 只看该作者
    我刚下好还没有传百度云
    “来自电巢APP”
    发表于 2020-10-5 13:19 | 只看该作者
    盼望早点有连接
     楼主| 发表于 2020-10-5 13:39 | 只看该作者
    靠大家上传了
    发表于 2020-10-6 21:46 | 只看该作者
    给个下载链接
    2024-6-2 15:34
  • 签到天数: 120 天
    [LV.7]常住居民III
    发表于 2020-10-27 17:00 | 只看该作者
    能给个链接吗 。。。。。。
    发表于 2020-10-31 20:51 | 只看该作者
    谁下了?帮忙给传上去吧!
    发表于 2020-11-1 20:26 | 只看该作者
    https://filecr.com/windows/cadence-spb-allegro-orcad/
    GMT+8, 2026-5-7 20:07 , Processed in 0.140625 second(s), 24 queries , Gzip On.
