; A4 K# ^0 U9 o+ o, ^% [ U%%%%% 0 q4 @7 d3 J1 T5 \
函数名:
6 E) Z6 D) A7 ]% Q& P# s initialize_variables() %%%%%
/ _$ @5 c) Z7 cfunction f = initialize_variables(N)
* J2 e, p" d- K# p# Wmin = 0.1;
2 A I1 \, z8 m8 `' j# m, qmax = 400; $ Z" m1 a8 F# y
Vmax=1;
9 d( R) Z/ V+ [1 ~ x4 {; FVmin=-1;
! u! M* g3 ^" G" q%come to here
: Y+ n1 O' t# {$ u1 |, W7 [M=7;
4 b' @9 C: O, |0 }( E' s1 dK=8;' Y& _3 [* H' g7 S9 }5 o1 J; @
for i = 1 : N
' C% T- r/ D M5 n4 q0 @) T. @% Initialize the decision variables& T6 m; l$ G+ S
for j = 1 : M
' x- v: R) e6 y' Y; af(i,j) = min+ (max - min)*rand(1); % rand means random
2 ^: ^: `' z3 o. Dend) B9 w+ J' x5 D
% Evaluate the objective function2 a: V5 d2 E, t4 w
f(i,8) = evaluate_objective(f(i, );
) ]! _: ]* r! K gfor j=K+1:K+7 i u9 y v4 D. \
f(i,j)=Vmin + (Vmax - Vmin)*rand(1);
8 t' y2 z* E! Z- O% W2 m n1 Pend9 E- a3 M, M1 L5 d: C7 l' j( n
end" b0 Y& r) T" a" I
5 u) `% b6 }! F0 a9 U
( f- i# E' x/ [/ S% U( Z @ @, J
* C8 w1 B# p( ]& }%%%%%
7 ~; G/ ^2 `5 `0 l; ?# M, Q! q& |%%%%%! M: E/ W8 Z1 \% k- f
函数名:
9 F% Z3 r) w8 n& P8 h! Einitialize_variables()%%%%%
d# M/ n0 k+ I" l+ B, [% Qmin = 0.1;
, f" C0 ^ U O+ R" j! {max = 400;
) C( r! v3 v' z5 F+ EVmax=1;
+ ]; A: F0 X2 O( p) t, F: }9 uVmin=-1; 9 g& B9 ^( h2 F* q5 X
%come to here
& Y! H3 L, ~4 T9 N: iM=7;
6 c& ^ F% C" ~$ N' I6 UK=8;3 A" g0 A8 u: d' {* O; _6 H
for i = 1 : N
. D! }& w: g) o. ~ % Initialize the decision variables
6 P0 f5 n9 i" u: Q for j = 1 : M3 w. c, b9 n! V9 g8 ]
5 \5 n( a! w7 {+ ^) [) n end) e6 f+ s$ t6 P* c6 ]' Z+ n
5 N7 A6 x x8 y' w* r3 Q, W1 w7 |# Q f(i,8) = evaluate_objective(f(i, );
3 v% x; M- A8 ?$ B for j=K+1:K+7) z4 i/ P1 [6 B' L
/ W6 u7 U: e' a* S* h. H end
2 F! U+ a `& L* wend, Y6 X; Q' s4 U( G
& l& j/ j8 W7 O- z
% d- ^4 ~! ]) L0 vfunction f = check_band(x)
. p R: i' Q: B" V5 K[M,N]=size(x);
3 j. r w% F. }, E9 Qfor i=1:7$ v( m8 J! J$ y6 e
l_limit(i) = 0.1;; O; Z0 u' H7 {2 x9 K" O% [. K
u_limit(i) = 400;
- Y# |, s0 n( e5 E T) uend
9 R1 G$ A( Z! q$ Ffor i=1:M4 @* y1 p0 a5 N# Y4 i# F( Y
for j=1:N
" q5 d0 `$ Y- F2 Jif x(i,j)>u_limit(j)* A! ~& X, y- G$ r$ O4 I
x(i,j)=u_limit(j);# G& b% A5 z8 [1 B
elseif x(i,j)<l_limit(j)8 Y4 j, \/ U) l) H, W1 }9 ]2 T
x(i,j)=l_limit(j);
; O' X' t% P" _/ c& P, f6 G7 Bend
/ o6 Z# r. [, v0 n! a% l9 jend! N$ }6 x- H! H6 D
end1 b1 V- M- L9 ^8 G
f=x;
/ s) U# [1 D3 N, k/ L8 v4 |% a
( |! l3 a }. \7 O8 q$ r& \3 l! ?; k* h, n
function f = check_band_v(x)1 u( E+ i6 l" Y" ] {0 g- a
[M,N]=size(x); 8 x6 b8 b1 g2 R E% a& s9 }; ?
u_limit=1;
" F8 p8 J# [1 ^2 H( _/ D5 Il_limit=-1;
: q& X& ~2 M0 ]; }for i=1:M4 C( W, ?5 w j- V2 x, o) n; u
for j=1:N
) Q$ b: j3 V( B( Y# S+ @ if x(i,j)>u_limit
% c' Q! y7 U+ E x(i,j)=u_limit;5 Q! t8 p" ?# b; _+ ]
elseif x(i,j)<l_limit# V" Z& p: y/ d
x(i,j)=l_limit;& l. U4 N% ^7 _3 ?: ?, d9 D, l
end; S& w5 h/ n4 l2 h" L) p& ^, n
end
9 V# Z& D$ e* R& r, Dend
- y' Q: M9 V& v$ v \! G; Tf=x;
( {! R) j( {3 w" r" M- ]/ p
" B+ J$ c8 Q( o- _8 i- e& e
9 D- U" r/ {7 v) o* H- ^ [function f = evaluate_objective(x)
& S% B2 {; }. y" p7 ^/ mf = [];$ | t, n" A9 N, G3 |7 x; E
A=[0,0,0,1,0,0;0,0,0,0,1,0;0,0,0,0,0,1;0,0,0,0,0,0;0,86.69,-21.62,0,0,0;0,-40.31,39.45
9 D% ~3 B! C' Y7 H,0,0,0];
# Z, f) W1 v; l$ A C3 I' Y: Z7 iB=[0,0,0,1,6.64,-0.088]';
% A* V7 p2 j& ~5 k a7 O* D- `, cC=[1,0,0,0,0,0;0,1,0,0,0,0;0,0,1,0,0,0];) t) a8 S0 z/ z z/ b9 z+ p ?
D=0;
% D4 U. e: x4 ]3 \H=ss(A,B,C,D);0 [( o) }' s( I$ o! T' C
q=[x(1),0,0,0,0,0;0,x(2),0,0,0,0;0,0,x(3),0,0,0;0,0,0,x(4),0,0;0,0,0,0,x(5),0;0,0,) U2 C+ A- g0 b: b; p( a
0,0,0,x(6)];8 q4 I( S. [ [" ^7 A+ Z- z+ R$ {
r=x(7);+ g# ?% h0 G- ~4 U! Z' f
k=lqr(H,q,r);
7 m4 e& Q% \6 Y. Q+ D# o, l6 ya=A-B*k;
6 n: V# W3 k3 i$ r" f3 k( n1 uh=ss(a,B,C,D);
$ A! D, a: @8 X0 LT=0:0.1:7;
+ Z( t: V; e$ T[output,time,stat_vect]=step(h,T);' E% n4 e1 e9 Q# h( Q
%output+ f% k H+ C7 V8 z; o
%stat_vect2 p7 x# {5 }6 Y, ~/ s) c" a
sum_1=0;
/ Y$ B* P5 V# P o M. G, H% Ifor i=1:1:718 w1 ~/ E2 E, G; ]$ O' W
sum_1=sum_1+stat_vect(i, *q*stat_vect(i,:)'+k*stat_vect(i,:)'*r*k*stat_vect(i,:)';: i2 |, G9 `* d" T
end/ V" l/ F2 \* F" w B E. E
f=sum_1;
) S+ t) e" z9 t
9 W" k4 b( E h1 P0 R: o
+ s9 N! u1 y: B6 E6 h E! |
- X. Z) Y; T" ^% [9 m4 d, @1 v7 K# k附录
+ }' t; t5 U0 C, B0 R4 R0 `C: m" g9 u8 {5 B: B. N, }
粒子群算法程序:
$ G: r o$ @+ r3 r4 Q9 `3 J3 _
+ x: C8 \1 @% M e: S4 U7 s%%%%%
- X8 j" p# @. V+ X& V$ q x被调函数2 Q" t" p" ^! x
$ c: a4 E$ A+ ~' r- s' T1 C:
- x% R5 v) p! ?9 \! ]- \0 cinitialize_variables()
: O) q! O! U6 M& ^种群初始化函数
: e0 H, R9 l) @+ k2 T( l; y% `0 c8 X& B, V%%%%%8 v( h+ a2 E, i4 \
" Q4 ^2 @& b, C% J被调函数
. M2 z$ n( M$ k9 c; q, f4 m22 q4 E. y2 A/ s/ u2 ?! b# @: s
:$ ?% Z- ], K4 ^3 x
evaluate_objective()
1 c7 ~' ~4 e. ^, l1 f计算个体适应度的目标函数7 C. u) k# V7 h( o% O1 i
: T. H0 `* ]! Nclear all
5 y' I- W: {+ ], ?: |- Yclc
8 |" k9 B3 x9 G8 }! wpop = 30;%30. t2 G3 Y# _* b1 Y
gen = 50;%502 r, _' y$ w( {: e
M = 1; %the number of object 目标函数的位置6 Y# ~( h- i ~; z9 o. c: y
V = 7; %the number of chromosome 染色体的条数
! T7 s, w7 u$ _3 y* U; mwmax=0.9;1 c. Z9 C- S' ^' u+ C
wmin=0.35;
4 M5 q. x) Z% V. }/ E: Zc1=1.3;
+ |% G4 Z" Z) M4 d0 X: V: I, Fc2=1.3;
3 P) N" ]# G4 J5 q7 Nfor iter=1:gen) ]4 {1 `$ Q1 A8 y
W(iter)=wmax-((wmax-wmin)/gen)*iter;
4 y. F# f/ Z/ b5 j& pend %计算惯性权重 inertia weight
4 h9 @: Z9 C0 k2 ?' ~9 r1 B$ q+ qchromosome = initialize_variables(pop); %变量chromosome是一个30*15矩阵,里面包含30个个体的信息
A) W' h. L: y4 |! nfor i=1:pop1 a0 k+ t% c$ w! S5 H$ g8 _+ _
pbest(i,:)=chromosome(i,1:8); %初始化个体极值pbest pbest为pop*8的一个矩阵
n+ R& q1 y# [, F! @end
, z: V$ U! v4 e" T$ ~) C2 M%初始化gbest
" _( H: t3 C" |" @) m[temp,index] = sort(chromosome(:,M+V)); %以低M+V列为升序把数组chromosome排序
- \) Y+ q1 l: W1 X Bgbest=chromosome(index(1),:) %index也是一个数组,index(x)表示temp数组中第x行的元素在原来数组中的位置
4 Q# V* _0 Y/ rfor i = 1 : gen* Z/ w E7 A# O( {/ c
x_temp=chromosome(:,1:7);7 j: Q8 W3 \0 B* E4 a8 X! J2 @
v_temp=chromosome(:,9:15);
! s8 T/ ^1 s: k; Q# X pbest_temp=(:,1:7);0 V7 W) [4 S! _+ K* b
for j=1:pop
" h k) J5 X7 y9 _, {( L7 u% @ gbest_temp(j,:)=(1:7);; ?7 d# _8 p; r% [
end
$ K- L. w ?$ y
( q. ]/ o0 |* Z2 W2 p4 G8 W! z. s9 a) P4 v# [) `3 z( R3 b
. x( r L* Z, C/ w% N
new=W(i)*v_temp+c1*rand*(pbest_temp-x_temp)+c2*rand*(gbest_temp-x_temp);$ e' d3 m3 X8 E/ [* j$ R
x_new=x_temp+v_new;$ v8 A- `" `! m' H0 e( c5 l, v( U
x_new=check_band(x_new);: {. w, _" Y% d; h
for j=1:pop) M! q! m+ D, c! A, H0 j
f_object(j,:)=evaluate_objective(x_new(j,:)); %f_object为一个pop*1的矩阵: t% V# {( c. W. i! v' \0 a0 M
end
& t6 @" R$ y; c' K" i" o: O x_new(:,8)=f_object;
- A( U9 k9 v- | w1 T chromosome = x_new;
* i6 o7 b6 s3 B W5 {' q2 P6 N% c chromosome(1:pop,9:15)=v_new;
2 t$ i8 w! P0 }+ ^/ A1 r chromosome(pop+1:2*pop,1:7)=pbest;
: [, X7 U! d4 {% i1 ?! a for j=1:pop
# I" M' x& h4 p) Y if chromosome(j,8)<chromosome(j+pop,8)
: h. p( l2 U' w* d, S pbest(j,:)=chromosome(j,1:8);2 ^2 b8 J) W3 X) P
end
' t, S9 j% I, G4 ]2 L0 f0 @+ l end
$ I5 P: ~6 k2 {5 r) G9 N chromosome=chromosome(1:pop,:);+ U p; K5 u2 q
chromosome(pop+1,1:7)=gbest(1:8);
) O& f. u) ^. h! [ [temp,index] = sort(chromosome(:,M+V));
9 M9 Y* @. S, U+ Y gbest=chromosome(index(1),:);
6 X# ~2 t% k, x4 ~6 _" M chromosome=chromosome(1:pop,:);
( L) i U6 b, [ q" [ solution(i)=gbest(8);4 l. h( Y" W: I& V; S
generation(i)=i;
, w1 i. M% O7 A& k if ~mod(i,10)& x* \6 [: l7 Y2 j8 J7 U! o7 h
fprintf('%d\n',i);8 V2 l ?+ G4 |8 S# I% M' \4 u
end( d7 ?' H% D \$ v& N& C
end0 I: O0 H, N7 i
figure(1)
5 Q$ \% L8 M! S0 ]* b ABC_object(chromosome(1,1:7));
0 P& e8 \) e# A" D/ f+ } figure (2)) Y- x7 n7 u: z1 [$ ^- s$ u
plot(generation, solution );3 E8 V* H' U p5 F; p
title('QR op using pso');7 I4 V; G% v% U1 ?$ s5 d
xlabel('generation');
. c# j5 ]8 z9 L3 k* I ylabel('solution');# C. ]! k9 j, Y) s( U
以上是粒子群算法优化LQR的matlab程序,运行时出错了,请求帮忙!
, ^! m7 e& Y. {' h( Q' l4 X' i" z+ A |
