以下摘自美国WBDG对于IPD的定义:$ T8 @4 p% ^& D! L
Integrated Project Delivery (IPD) is an approach to the design and construction process that is based on shared risk and reward, and open exchange of information that is intended to optimize project results. IPD unifies the Project Delivery Team at the beginning of the project with the shared goal of project success.: D' N2 a( j( M- U t9 K# b
# h4 d- l; N) Y* \# \The principles of IPD can be applied to a project in two ways—IPD as a Philosophy and IPD as a Delivery Method. IPD as a Philosophy occurs when integrated practices or philosophies are applied to more traditional project delivery methods such as Design/Bid/ Build, Design/Build, and CM at-Risk. The degree of collaboration may vary with IPD as Philosophy, but most or all elements are not contractually binding. IPD as a Delivery Method occurs when an Owner signs a multi-party contract with key members of the Project Delivery Team that incentivizes collaboration, team risk-sharing, and other IPD principles and practices.
' p' q) S# V. e8 [% `, Z9 _$ k5 F. m |
