查看: 3784|回复: 3
求助capture原理图导入allegro PCB Editor
发表于 2010-10-27 14:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
求助capture原理图导入allegro PCB Editor  K' c$ @. L1 x9 b3 O
    刚刚学习allegro,请问网表导入allegro PCB Editor时要怎么设置?导入网表之前要做些什么准备?
8 r' u5 k" C' H7 o5 ^, O$ r在原理图中我把原件的PCB footprint都填上了,跟allegro里面的封装名一致。其实令我很疑惑的是,仅仅
9 k" I/ q, ^5 g4 P3 t是在导入网表前设置了网表的路径,却没有具体选择是哪个网络表,加入我的指定路径里有很多个网表,那
" p9 w0 E! Q# L% {( g, ]$ P岂不是很乱,所以我把原理图的名字和PCB 都取同样的名字,而且存放的路径都一样。但是都不能导入,我怀疑是allegro里要设置封装的路径,请大家指教,谢谢
: ~/ O$ {; S! q- D下面是导入错误提示
3 j" c9 p" R. J; g# Z3 D0 z5 hcadence Design Systems, Inc. netrev 15.7 Wed Oct 27 14:42:35 2010
2 ^  T4 y$ y3 Q: }; d% r8 ?# v$ M% L(C) Copyright 2002 Cadence Design Systems, Inc.5 x! X- S' \' l6 C
------ Directives ------" n* _4 D. @, y* ]" L/ b& ~( q4 N
RIPUP_ETCH FALSE;7 t4 N& [& {! _' A
RIPUP_SYMBOLS ALWAYS;
5 Q. K0 N7 }  c  @1 o) ?$ y# w9 bMISSING SYMBOL AS ERROR FALSE;
: C# X/ J/ L; h5 v$ d1 p1 ZSCHEMATIC_DIRECTORY 'E:/Cadence/work/pad';
; p" E+ }& M3 d# v0 i9 N& mBOARD_DIRECTORY '';
. E9 G  j  H! a, A( HOLD_BOARD_NAME 'E:/Cadence/work/pad/MYDSIGNE.brd';
0 k  r# @- ^  B5 D5 FNEW_BOARD_NAME 'E:/Cadence/work/pad/MYDSIGNE.brd';
; @; ^: |& |  I0 |. e! Y/ G  d# V  KCmdLine: netrev -$ -5 -i E:/Cadence/work/pad -y 1 E:/Cadence/work/pad/#Taaaaaa03360.tmp
! h9 W& |" H9 J6 ~# K1 r------ Preparing to read pst files ------
: k8 P' x# D- _3 b2 g  ]. A& S
4 p3 c+ l7 b2 [* J#1   ERROR(24) File not found$ v' M% l# I* g$ j
     Packager files not found  _9 i8 i" D; A
#2   ERROR(102) Run stopped because errors were detected% n0 w7 |2 V# N
netrev run on Oct 27 14:42:35 2010+ d& `: U  A( f5 p2 V% h  R; |
   COMPILE 'logic'- }: I* x$ n. }- ^5 y- S
   CHECK_PIN_NAMES OFF
8 B+ m! z. {# P# O2 i: o   CROSS_REFERENCE OFF4 S3 u) S" G0 w0 I/ r
   FEEDBACK OFF+ C, L0 C% G) y
   INCREMENTAL OFF% K" D6 q% ~' ]+ Q
   INTERFACE_TYPE PHYSICAL6 t' F/ s3 G- ]- W
   MAX_ERRORS 500: ^0 X' {4 d! ?
   MERGE_MINIMUM 5: D8 M- }  A6 L( @8 P/ L$ d
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
/ `7 H2 P! r! g8 s" E/ I/ j   NET_NAME_LENGTH 241 u; S& b6 P/ S1 a2 o& t. t3 z
   OVERSIGHTS ON
- w  L' B* w$ L( t/ ^) m   REPLACE_CHECK OFF; s" k% g3 l' Z+ B# g9 t5 C& ]6 t
   SINGLE_NODE_NETS ON
% J5 j; g* Z. s+ v1 [   SPLIT_MINIMUM 0. f! w/ V6 s' |9 F( P" [
   SUPPRESS   20
6 i9 @1 h0 ~2 }7 ]" f; g   WARNINGS ON! L$ o" g$ u0 a5 X
  2 errors detected
) a) \" B, A$ x- o5 k3 u' a  u No oversight detected
! u% @0 k/ O) C! M4 e/ i No warning detected
4 Q9 |, X, p: N; C' p( C/ _& ~# ~cpu time      0:00:04
4 r" T: q8 ~  {% e! g3 ?elapsed time  0:00:00# W; X3 K& B) E& B* l) C
9 S4 a! f+ Y7 a) H' {6 F
发表于 2010-10-27 21:49 | 只看该作者
英文已经提示你,封装没找到
发表于 2010-10-27 21:51 | 只看该作者
其实可以在capture生成网络表,自动连接到PCB
    奋斗
    2025-7-8 15:48
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2012-8-8 18:11 | 只看该作者
    导入的问题还有点不明白...主要是没自己做过完整的流程
    GMT+8, 2025-11-4 08:46 , Processed in 0.140625 second(s), 23 queries , Gzip On.
