查看: 484|回复: 1
生成FSBL失败
发表于 2020-8-24 13:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
synthesis、implementation、generatebitstream这三个过程都成功了,在launchSDK后需要生成FSBL的过程中出错,出错结果图片显示出来,信息也贴出来
% j2 l7 w* b1 G9 r
% b8 N! l4 A7 W16:19:36 INFO        : Registering command handlers for SDK TCF services
4 F: h8 ]8 J" ~% ?7 b16:19:36 INFO        : Launching XSCT server: xsct.bat -interactive F:\Task\0and4\0and4.sdk\temp_xsdb_launch_script.tcl0 a/ e' ]# N8 h8 F
16:19:40 INFO        : XSCT server has started successfully.5 @; x& c9 I2 ^! P! u
16:19:46 INFO        : Successfully done setting XSCT server connection channel  ) `2 l! }  b% [& r
16:19:46 INFO        : Successfully done setting SDK workspace  6 v& o9 D+ @5 Z' Q
16:19:46 INFO        : Processing command line option -hwspec F:/Task/0and4/0and4.sdk/system_wrapper.hdf., x6 r, n* A( F
16:20:53 ERROR        : (XSDB Server)ERROR: [Common 17-161] Invalid option value '' specIFied for 'of_objects'.
( i& Q2 h+ t* l/ DERROR: [Hsi 55-1545] Problem running tcl command ::sw_axiethernet_v5_7::generate : ERROR: [Common 17-161] Invalid option value '' specified for 'of_objects'.
3 G* t0 @1 F) _' J( b) h) W; M3 y. S7 f
    while executing
6 c; s$ Z: G& }"get_cells -of_objects $conn_busif_handle", }% y! U1 r3 q8 N8 L" b4 }" s+ M
    ("foreach" body line 4)( g% D4 t2 Z, C1 j6 d+ A1 P# t
    invoked from within4 E+ U% W; J! G$ Z4 P* {' E& b
"foreach p2p_busif $p2p_busifs_i {, x2 z# I% A2 i
      set busif_name [string toupper [get_prop# b  w: l& F; s& C. r+ V  u9 s
# d3 q9 ^7 }& Y6 ?0 ?      set conn_busif_handle [::hsi::utils::get..."" f, H1 n) D) O& C; l7 x  {' Z
    (procedure "get_targetip" line 3)7 v& ]: g+ v, h
    invoked from within
8 E& T# E* J; Z7 f  q: n"get_targetip $connected_ip"
$ G! W1 R2 k9 \8 L$ p/ U' I    (procedure "get_connected_intf" line 30)  P0 p" T& p; B4 N
    invoked from within0 V; y  Y! V; k  x: k4 w! w5 ~
"get_connected_intf $intf"" r9 P8 d- h5 T; l& M1 S. U
    (procedure "get_connected_ip" line 11)
6 P  u) D/ V0 J- y2 `+ ]# R' H; ]7 d    invoked from within
# o7 s! u. e: I' s% P1 _( r; V"get_connected_ip $periph"  D* o: a9 W( r: [
    ("foreach" body line 5)& R* k9 x" U" z9 P! |
    invoked from within; I# k! h" a/ [% X5 z
"foreach periph $periphs {' d$ g9 u6 {3 }, ]6 e  w& P, [
                set periph_name [string toupper [get_property NAME $periph]]) L3 ?7 _! P' b
        puts $file_handle ""
# R4 Y8 `  H9 ?        puts $file_handle "/* Ca..."
3 Z$ a6 d. d# @2 x# @0 r! D5 U) ]    (procedure "xdefine_axi_target_params" line 18); }+ Q. V6 r7 D, |# X. _/ ^
    invoked from within
8 @8 a& F9 X' ]: B"xdefine_axi_target_params $periphs $file_handle"
6 u& O# r4 t8 K( U    (procedure "xdefine_axiethernet_include_file" line 48)
7 w7 @; v: @( U0 S" X/ S) L    invoked from within
$ c; J3 x1 C9 w' K' p+ Y"xdefine_axiethernet_include_file $drv_handle "xparameters.h" "XAxiEthernet""
! {* \4 L* b' c) g! w- i    (procedure "::sw_axiethernet_v5_7::generate" line 3)
% U, m8 U. H% o- W8 I: ^    invoked from within, a  u$ ^9 g( T% [8 |
"::sw_axiethernet_v5_7::generate axi_ethernet_0"1 d& W- _$ H# G2 H6 j. T
ERROR: [Hsi 55-1442] Error(s) while running TCL procedure generate()
) {/ T6 P4 T# E3 c5 @% r3 ~' y) A7 M. i! X% L
16:20:53 ERROR        : (XSDB Server)ERROR: [Hsi 55-1450] Error: running generate_bsp.' w, |) C+ }$ o1 i6 R. R$ l: A4 v  J4 u
8 W. x+ X* z* b. S: ?% L16:20:53 ERROR        : Error generating bsp sources: FaiLED in generating sources
2 d8 t/ {  |* {6 q3 p
9 |3 P, C' E0 z, C/ L" F
发表于 2020-8-24 14:22 | 只看该作者
GMT+8, 2025-10-11 16:41 , Processed in 0.171875 second(s), 26 queries , Gzip On.
