1. 导线(信道):conduction (track) 2. 导线(体)宽度:conductor width 3. 导线距离:conductor spacing 4. 导线层:conductor layer 5. 导线宽度/间距:conductor line/space 6. 第一导线层:conductor layer No.1 7. 圆形盘:round pad 8. 方形盘:square pad 9. 菱形盘:diamond pad 10. 长方形焊盘:oblong pad 11. ***形盘:bullet pad 12. 泪滴盘:teardrop pad 13. 雪人盘:snowman pad 14. V形盘:V-shaped pad 15. 环形盘:annular pad 16. 非圆形盘:non-circular pad 17. 隔离盘:isolation pad 18. 非功能连接盘:monfunctional pad 19. 偏置连接盘:offset land 20. 腹(背)裸盘:back-bard land 21. 盘址:anchoring spaur 22. 连接盘图形:land pattern 23. 连接盘网格阵列:land grid array 24. 孔环:annular ring 25. 组件孔:component hole 26. 安装孔:mounting hole 27. 支撑孔:supported hole 28. 非支撑孔:unsupported hole 29. 导通孔:via 30. 镀通孔:plated through hole (PTH) 31. 余隙孔:access hole 32. 盲孔:blind via (hole) 33. 埋孔:buried via hole 34. 埋/盲孔:buried /blind via 35. 任意层内部导通孔:any layer inner via hole (ALIVH) 36. 全部钻孔:all drilled hole 37. 定位孔:toaling hole 38. 无连接盘孔:landless hole 39. 中间孔:interstitial hole 40. 无连接盘导通孔:landless via hole 41. 引导孔:pilot hole 42. 端接全隙孔:terminal clearomee hole 43. 准表面间镀覆孔:quasi-inte RFacing plated-through hole 44. 准尺寸孔:dimensioned hole 45. 在连接盘中导通孔:via-in-pad 46. 孔位:hole location 47. 孔密度:hole density 48. 孔图:hole pattern 49. 钻孔图:drill drawing 50. 装配图:assembly drawing 51. 印制板组装图:printed board assembly drawing 52. 参考基准:datum referan ! T$ d) G. [' I& Z9 }- P1 U0 r
