麻烦大神帮忙看一下,PSO在节点定位算法的仿真,运行后只有两个坐标轴怎么办?感谢!9 D) G+ | _0 m' O0 E
4 S0 t! x/ M5 Y$ M" p2 {
function[psoF]=pso_2D% T# a6 N. x0 n* a
clc;
$ }* r" Y8 }9 ^7 a! \clear all;
0 D' ^ k3 N1 apop_size=10;& }. q) A$ t. ~" G$ x0 N6 @# ^3 \
part_size=2;5 I) ^9 K" N( H% g# r
gbest=zeros(1,part_size+1);+ s+ `3 m# A% a9 _
max_gen=300;
) P& A* h2 R8 w; Y' s; jregion=zeros(part_size,2);: K c7 H$ U9 o2 v! c4 ^
region=10*[-3,3;-3,3;-3,3;-3,3;-3,3;-3,3;-3,3;-3,3;-3,3;-3,3;];) g4 D K' C2 t! |& `
rand('state',sum(100*clock));
7 F% H0 H& w& V: X0 zarr_present=ini_pos(pop_size,part_size);
; I6 I' m; S" d9 X" a$ g. vv=ini_v(pop_size,part_size);! P$ V9 I( I5 D0 H
pbest=zeros(pop_size,part_size+1);8 O1 ?/ o9 H3 T+ ~& f
best_record=zeros(part_size+1,max_gen);* y5 o( x& H$ u- ^, _7 W2 {! T
w_max=0.9;1 d0 N4 E% f9 H# f- d% K
w_min=0.2;
5 Y! D+ s5 ]. \, l* {8 Mv_max=3;6 {/ D# j9 o. Z P1 a5 B1 A9 ?
c1=2;
% {: P% x# ]* @6 W3 ~: Y2 yc2=2;$ n- G" `/ q' U8 A; Y
arr_present(:,end)=ini_fit(arr_present,pop_size,part_size);
& G9 g5 n: ^9 Lpbest=arr_present;# [# P. j5 Y2 w( Q' d( B$ ~
[best_value best_index]=max(arr_present(end));
2 N3 {( |% f& U1 ?8 n( r0 ggbest=arr_present(best_index, ;/ k. m" S8 z, |% l/ V
for i=1:max_gen8 t. @2 P+ v# C, I* ?
w=w_max-(w_max-w_min)*i/max_gen;, z3 Z4 v5 p+ h2 x
for j=1:pop_size
( c! W2 ]: Y A1 z+ L$ v$ N; z" L v(j, =w.*v(j)+c1.*rand.*(pbest(j,1:part_size)-arr_present(j,1:part_size));
# y0 i q- T- `! J0 r1 C# I4 a c2.*rand.*(gbest(1:part_size)-arr_present(j,1:part_size));9 t& T4 i- x; F. \
for k=1:part_size
- Y4 ^0 {$ D% B% @& p0 h0 g q if abs(v(j,k))>201 t+ s# n' R3 a! V% z
. w4 ~; m0 |0 M# X. s; @! v v(j,k)=20*rand();. y" W* ?9 c9 }
end
% d9 B5 y' T: N end s- N/ @- D3 Y$ Z3 d
arr_present(j,1:part_size)=arr_present(j,1:part_size)+v(j,1:part_size);4 w: H' D: p8 a# w L0 P% d
arr_present(j,end)=fitness(part_size,arr_present(j,1:part_size));
/ g$ m8 T6 {, J Y. X {9 U if(arr_present(j,end)>pbest(j,end))&(Region_in(arr_present(j, ,region))) w" P7 y( n: g7 o5 F" E+ o
pbest(j)=arr_present(j);. q. ]1 ^4 D/ b' f! T# }# D/ F" P, U g
end
9 @, ^) Z' N7 A; s9 Y" \* O* P end
$ t- j; T+ `$ e( G# u [best best_index]=max(arr_present(end));6 t, \% D9 M8 F: ]4 i
if best>gbest(end)&&(Region_in(arr_present(best_index),region))% U* I* ]! M3 [% z0 Y. @% y
gbest=arr_present(best_index,:);$ Z2 ]( i& [( o6 O- H
end9 d1 d9 b- D* T- m( P5 ?
xlhd=gbest(1:part_size);
- u% d9 A& u! S if(1)
2 H& y0 b9 }! Z/ r) r" a. ^ for p=1:253 c. L$ S( {, U2 j
cxl=rand(1,part_size);
3 c$ v. b8 o: e2 f. A/ ~1 e for j=1:part_size c9 q) a+ S3 ` |) J& D" t: g
if cxl(j)==03 v7 w1 r. m0 U1 @& ]9 m* u! A# o
cxl(j)=0.1;
" A0 W4 A: W% S$ x6 y end* g( g: [8 K$ f k ^% l$ D
if cxl(j)==0.25
% m6 } W! Y% n P' [7 W cxl(j)=0.26;
9 i# X5 U: @6 @% k end
" S1 j6 m. `) ^) v9 Z/ R2 ?" K if cxl(j)==0.5
. a# C$ z X5 P8 c9 @ cxl(j)=0.51;
+ C o2 e a* D- G( q& r1 i end
1 v0 a/ o" d s) L- w7 x if cxl(j)==0.75& i8 v) Q- u$ b9 z: Q
cxl(j)=0.76;
6 N( [" O4 o2 [. R end
, s0 `& @$ W0 [+ A" N, F, p ? if cxl(j)==1
$ v" j K, V$ ]$ i cxl=0.9;
! `0 V2 [7 u+ M end
2 L# K, v4 h+ d! b1 T end4 }2 |: U, u. U; J( O' A* [
al=-30;bl=30;/ H0 H& O, Z6 H- f2 N
rxl=al+(bl-al)*cxl;. J+ T% k. D" q3 v
bate=0.1;9 P4 L5 {5 {2 Q' P
xlhd=xlhd+bate*rxl;: ^' ^ I+ b ]0 y. y
if fitness(part_size,xlhd)>gbest(end)
/ G, M2 d4 Y# q gbest(1:part_size)=xlhd;
8 k+ C* m: \* J. ^& c5 }2 F! e gbest(end)=fitness(part_size,xlhd);+ J, J* o4 A6 e9 |
end9 c) z: u4 H6 j! W0 o
for j=1:part_size+ M- Q6 Y; B! r- t, g; ?) }
cxl(j)=4*cxl(j)*(1-cxl(j));
7 _3 O9 r" I$ i) K: `( V end
& |* F& e4 X, ?4 w2 r) b# Q d end E4 B# M, s- C9 R( |3 L; a
end;
& ?! A, G9 ]. g
! C* {1 f+ }7 G" l best_record(i)=gbest(end);+ v# s- P, x/ Q! q, J W( S
end;
n& r9 g8 t0 Y. t9 K {" ipso=gbest;9 f( l: r& V' c; `
display(gbest);7 p: s8 a: `$ q7 {% H
figure;$ W1 y1 V) K+ |& w
plot(best_record(end));6 Q% C: e4 a: ]+ `
best=zeros(part_size,max_gen);
7 N) h$ y+ B6 G$ B" \; k( k9 j- @for i=1part_size=1;0 G% ]% d$ h l
best(i)=best_record(i);, W# v6 |3 ^( F" K
end0 n, g3 ^" D: Q( B# V+ U; Z1 g
pareto1=zeros(1,max_gen);
% t4 o" i( N1 q/ E" bpareto2=zeros(1,max_gen);
: R2 \! p# o; Jfor i=1:max_gen/ Q8 O6 g3 J# l% C3 \
pareto1(i)=f1(part_size,best(i));
; _" U/ I, c" I) o: H pareto2(i)=f2(part_size,best(i));
9 N' i5 E, p$ u# q" U- Vend. u( k6 `2 O9 A0 C8 K3 x7 h& h+ O" A
figure;
; o8 Q% B7 }% s0 Y' V* ai=1:max_gen;* E- Q* V, Y8 X- T7 O
plot(pareto1(i),pareto2(i),'r+');
& Z/ m# \( p5 r1 qxlabel('f1');ylabel('f2');
, I3 g1 J. z" L# U) ltitle('Pareto曲线');
+ \% c* N W0 afunction ini_present=ini_pos(pop_size,part_size)9 D2 [7 O" u P# v6 ]6 k- F" h9 G
ini_present=10*3*rand(pop_size,part_size+1);4 w4 b9 e5 O, P4 w C# T9 ~. p
function ini_velocity=ini_v(pop_size,part_size)
& ~) F' g% L& N8 [0 |ini_velocity=20*(rand(pop_size,part_size));( e2 n+ n! i% l
function flag=Region_in(pos_present,region)
0 B1 F( l( S$ o( L& ^$ l[m n]=size(pos_present);: E% f5 F/ u8 j# U( r! N# E
flag=1;
1 P2 f M9 @7 V. jfor j=1:n-18 ]+ C; |2 O, L7 y- d
flag=flag&(pos_present(1,j)>=region(j,1))&(pos_present(1,j)<=region(j,2));
; K& v0 t( U4 w6 ?/ \$ m6 n! rend: [6 g/ m: a* f. m- |) I
function arr_fitness=ini_fit(pos_present,pop_size,part_size)) ^ l5 C% b( ]/ g. G# f& B+ `
for k=1:pop_size( I+ w! }- f9 K% Y
arr_fitness(k,1)=fitness(part_size,pos_present(k,1:part_size));( h$ J) Y0 R' b( n7 |
end
; c& o( j) \" J1 U. z" Zfunction fit=fitness(n,xp)
; [. v4 P7 r8 Iy0=[-9.9907,-7.7507];
_7 G: w% n% o$ iy1=[f1(n,xp),f2(n,xp)];
% d+ v! y) s" i2 s" Wfit=graydegree(2,y0,y1);4 E7 t. k% X$ F- k7 A# `+ M2 S$ O" ~
function r=f1(n,x)# k. D/ j8 {, V5 `9 d ~* X7 K) |8 E
r=0;
5 R/ ~% I. y, B2 w2 cfor i=1:n-1
- q. ]+ |, n. P( M% j! _ r=r+(-10)*exp((-0.2)*sqrt(x(i)^2+x(i+1)^2));
" p9 c. K- z0 {3 Qend
0 x+ F9 g8 Z) _7 M9 Kfunction r=f2(n,x)
; g( S+ S& y/ `; W$ u) f8 Xr=0;7 j2 Y- A) e: q1 p
for i=1:n
) G! e0 n( c6 B" k [8 Z1 J+ @; j r=r+(abs(x(i)))^0.8+5*sin(x(i)^3);( Y# D& Z- N# V# z: g/ F
end
4 l; E: x7 Q$ J6 Rfunction r=g1(n,x)
C+ J- L' g0 t/ xr=0;% R( u2 L8 `/ |4 {5 F( e/ P# C! O7 x9 ?
for i=1:n
0 N* B6 l! \' E2 G, n! B$ D r=0;
2 d% A5 A3 {9 k; v1 v& R8 Mend {9 Q' G1 c* z8 Y! L0 }# L' b
function r=g2(n,x)% \2 h1 S7 z; F6 d; Q( k: c$ p. w
r=0;$ s% I5 b" z6 T" Q! N
for i=1:n4 y4 r) H. ]5 O% S
r=0;. `8 r- N. K6 b, V+ x9 E3 h) I
end
) g- d3 Y( _0 J# F5 Ifunction gama=graydegree(tn,y0,y1)
, q5 z* M6 Q- p# a! z* ngama=0;4 W4 v# T+ ^& e' K+ N
rou=0.5;
* k" g# S. m9 `# Lkesa=zeros(tn,1);
, M9 x8 Q6 w+ [$ s7 Um1=abs(y0(1)-y1(1));
" F8 C: j1 D% r. A) \3 a/ cm2=abs(y0(1)-y1(1));
" w7 A( `( @6 s: B" @$ G/ {2 nfor i=1:tn9 q8 _3 y9 y0 F/ S3 z
if(abs(y0(i)-y1(i))>m2)
$ W" D7 w! u4 X; ^. j2 ^% C m2=abs(y0(i)-y1(i));
. t$ P( M5 W* n! V& L: ` end
~6 x; l6 h2 M' L7 t$ Y/ {. Z2 ~' pend6 N+ o$ w" N7 Z' j% f+ H
for i=1:tn
) r6 I/ ]: C+ e# H' m* V kesa(i)=(m1+rou*m2)/(abs(y0(i)-y1(i))+rou*m2);
1 ?: J) I' i0 X; f6 d! d! G gama=gama+kesa(i);
7 z/ j* ?0 l _0 |. i( d! Hend! P% J1 a; ~# `( t z
gama=gama/tn;
' Z4 Z7 }& F& o, Kfunction bool=feasible(x,n)
7 d2 O$ {1 a+ [: [7 i, ]/ z- sr=0;
! O, b3 f. G- m4 A* ]' A. T3 |r=max(g1(n,x),g2(n,x));/ |0 \; K: x! F: s
if(r>0)
2 Y% ?" P l. n2 Z/ N9 W; K7 K bool=0;- |/ X1 `# \# \
else
7 N# L2 W4 j% d( a( t bool=1;8 S+ f5 }. c/ U% m
end |
