查看: 1416|回复: 1
skill语言中文件备份的函数是什么?
发表于 2010-9-29 14:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如题,在用skill进行版图修改等工作前想让其自动备份,用哪个函数可以实现?
发表于 2010-9-29 16:24 | 只看该作者
回复 1# leibluefish
    axlSaveDesign
axlSaveDesign(
?design t_design
?mode t_option
?noMru g_noMru
⇒  t_design/nil
Description
Saves the design with the name specified (t_design). If t_design is not specified, the
current design name is used. If t_design is provided but the value is nil, you are
prompted for the name. If t_option is "nocheck", the database “quick check” is not
provided. Use this option only when there is a very compelling reason.
GMT+8, 2025-8-20 09:16 , Processed in 0.109375 second(s), 24 queries , Gzip On.
