pads 9.2 Update 1 is designed to correct issues in PADS 9.2 and: m+ V9 C: D; r; ^5 `& I
overlays an existing PADS 9.2 installation. PADS 9.2 Update 1 does% n7 L9 I4 N1 w$ |. N
not install standalone versions of mentor products; it must be. n" Z q! k/ k) Y
installed after PADS 9.2 is installed on your system. Installing
$ a Q: s0 V4 x1 D3 a PADS 9.2 Update 1 replaces only necessary files; it does not
/ T9 |! u) }1 W- G3 e, p* r4 } modify your user settings.. t& M$ _1 K! Q+ K, n( q5 k* O
B+ Z7 D( a5 VI N S T A L L N O T E S
: d! n) B2 s a0 s+ D5 [Install FIRST the PADS 9.2 ESDM skipping license install.
' Z) E: ]* d: j8 ~' Y) Q Second, install the PADS 9.2 Update 1.
7 B, i- }& {5 b: } Run the program, it should work, at least in demo mode, even if you+ _4 O4 B5 m$ }( D5 q
do not have any valid license. If not, try rebooting first.7 @' m L7 O: Z' B
If you still is having troubles, better check with Mentor.2 }* i: e& N$ F# V/ }( i$ R
After this have worked, run the MentorKG and save the generated K- [- G8 u+ L' X! a
file to some place you remember.
9 _& u" [/ W t1 g Use the Mentor Licensing utility to update/replace your license.
' S5 j5 h. B" @3 \( n$ k6 udownload:0 [4 V* \: m2 K" R0 m. B. W
http://u.115.com/file/f6f07cc7b9
Q) N2 U6 b7 i; I) b( P: C( O/ AMentor.Graphics.PADS.9.2-EFAupdate1.rar |
