TA的每日心情 | 开心 2019-11-20 15:05 |
签到天数: 2 天 [LV.1]初来乍到
MATLAB程序算法
5 k7 R2 ]# b( ?9 C+ fif flag_display == 0 && num_in > num_save_require; / ^5 S3 a" b- ?0 ^
%将前"num_save_require"个时间为正值目标赋值于target_tem / Z) T, K# X+ G- K, z
ii=1; %计数"num_save_require"个目标
; S3 n' U: c% ~1 k4 ~/ X1 L for i=1:num_in
- ^3 l* s" y! U1 \6 d if ii > num_save_require;
& e# u! B D1 ~, q break; " V+ p+ a7 M/ t( M" F" K
end
% s- f$ G) g+ o G' H( c2 e if target_in(i,7)>0;
4 ]) E2 E/ P; O1 J3 r$ U9 w target_tem(ii,1:NN) = target_in(i,1:NN);
5 v. _! x/ o. m! Z+ d8 O" h7 O ii = ii + 1; & h7 {: H) b# n7 |
end 8 o( q+ M: x: c: y+ \' W' r
end
; k7 F/ k( j n( F %target_tem中保存目标的数量
, J* A3 D! s0 R) p0 [& n% K pre_num_save_sucess = ii-1; " Q4 |5 d7 A. `! }
left_num = i - 1;
$ n$ {7 |: ?3 X/ s& i2 m7 Q: Y% Q* k \; V4 y8 e4 ]+ a
%如果”..“正值目标大于"num_save_require"个,则在本轮进行余下比较(此时剩余的目标中也许存在可能“..”更小目标 5 F& B" \; \% W! V7 F
if pre_num_save_sucess == num_save_require && left_num ~= num_in; * N P* Z |: a5 `& d) I: G
2 k( }3 `. M8 G) p4 ~+ s* w$ S %1,target_tem中的“num_save_require”个目标按“..”排序 % W0 k/ N+ Z" f$ V% |0 d( v+ D
if num_save_require > 1; 7 ~' C6 t; J" I/ N
for i = 1:num_save_require-1;
; g5 B+ e$ [" x! s3 k7 V for j = i+1:num_save_require;
5 ^; h( H4 _& |8 C/ T9 t if target_tem(i,7) > target_tem(j,7); * W5 S' ? M$ d# p7 D
tem(1:NN) = target_tem(i,1:NN);
D/ p2 h$ f3 l5 i' z2 C target_tem(i,1:NN) = target_tem(j,1:NN);
: O/ k* J: I+ s4 z; _ target_tem(j,1:NN) = tem(1:NN);
) \0 W( b# @& N9 ?" U end
7 I, x% G J Q: x! A end 5 O. u( E1 B+ |
end . g5 y. l6 z# G. Y0 _- ^# F
end ( W7 i7 O6 X# R; @ P/ L4 G
: b# ^6 q A" p4 M& e
%2,剩余目标与target_tem中目标“..”比较
& c" M9 N! J/ b( ~ for i = 1:num_in; 7 B; G" J! o9 M2 _
for j = 1:num_save_require;
/ b) ]/ X3 r3 C4 H5 g result_compare = target_in(i,7) - target_tem(j,7);
( N% v2 E, b7 e- M) q% U if result_compare < 0 && target_in(i,7) > 0;
* \& f8 r# o8 T8 k8 i) {% j %最后一个保存的目标被输入目标替代 : H- A, s) s: `
%前面“num_save_require-1”个目标中一个被目标替代
/ w% A0 _ t: p" | if j == num_save_require; * f! d- H; ]8 _7 n3 p
target_tem(num_save_require,1:NN)=target_in(i,1:NN);
: v( c$ i$ o+ ]7 Z7 {, d4 }' g! R else 6 v% b: K2 l D) k+ j$ J* H$ X
for k=num_save_require:-1:j+1; 4 [ m, b5 c6 n' T9 H
target_tem(k,1:NN) = target_tem(k-1,1:NN); 2 {% ^! U& H: j6 Q5 n/ D
end
+ Q+ l( m4 o I2 v target_tem(j,1:NN) = target_in(i,1:NN); 9 j9 E7 I1 m7 }* f6 U! M; I
end
m9 @9 D a% h& \" G1 H* r break;
, b+ N: r' S) ` elseif result_compare == 0
/ A9 y. }! ?2 B: S break;
6 Z* [! \( R# ^0 S end & W1 o2 [5 I0 l/ {
end 6 L0 a) c: Y# u$ F; H: J ^3 }
end
* B F5 K- Z5 w. [ Q7 Y* u+ a$ l$ S
" m% z$ j+ f: ]* F* A% |
%3,target_tem和target_in中所有目标间差值在max_differ_..以内的比较,如果 9 X4 j% ^( R( i& C, b% L# a
%max_differ_..=0,则严格按大小排序。
" d( O3 |$ Q5 V if max_differ_time == 0 " G6 e+ w+ [8 q; Q
flag_display = 1; %此时已经有(num_save_sucess)个目标成功保存
# y+ H) d* G* v9 T4 u: @ target(num_save_sucess_sum:num_save_sucess_sum + pre_num_save_sucess-1,1:NN)=target_tem(1:pre_num_save_sucess,1:NN);
; d/ M) @" d# i$ o; \& f else ( W2 F2 V& k0 h- }/ W" T
if num_save_require > 1 - e* @3 _9 Q9 B h2 }
target_compare = 0; %比较值
0 B! p# \$ M+ e: T. ?' n- { for i = 1:num_save_require-1 2 K: M4 Q+ q; Q# z8 p$ w8 ]/ d7 t
if target_tem(num_save_require,7) - target_tem(i,7) < max_differ_time; ! y+ V' w) B# J' G6 } m
target_compare = target_tem(i,7);
3 P! T" a+ ~: _ break; % e7 h/ P; A9 @. f# E" ~
end 0 I8 {& v/ Y, k, L$ V7 M
end 9 k9 ?$ f7 E0 k2 c
if target_compare ~= 0; %此刻由于target_tem保存的目标需要比较的数据太相近,所以需要在下轮比较中进行相近数据比较
# i% w& j7 G! [, c3 k+ T' B! [1 d9 k num_save_sucess = i-1; %成功保存的数据也因此减小
5 y5 y& x0 [. Z& y0 c! m( Z% k. s" O9 i else
/ i' U; x- _4 |) O num_save_sucess = i;
/ j0 Z/ ^: T& O target_compare = target_tem(num_save_require,7); % n. e0 N) g8 o$ f3 @
end / ]" z, A7 Y% t# P
else ( P" d8 A' L* \. O t9 W y
num_save_sucess = 0; : \; O5 y* V" E8 r" J
target_compare = target_tem(num_save_require,7); : M$ d8 ]) N3 W: ?
end 3 e$ j' m4 f( Z
ii = 1; %计数下轮比较的输入目标数 / n3 K$ C: F3 P; ]9 m+ N% z1 q6 A
for i=1:num_in;
! F' ]" }* A8 `- Y if target_in(i,7) - target_compare <= max_differ_time && target_in(i,7) - target_compare >= 0 && target_in(i,7) >= 0 - j' u1 c1 v P$ _8 X
target_in_tem(ii,1:NN) = target_in(i,1:NN);
8 K& R# h* x2 C! G/ [4 p ii = ii+1;
: N% g8 J+ y$ d0 }$ @ end * _9 M% B' M. ]7 Z* s& }& Q6 G0 [
end
; r6 U, O& G% O# L: {- A# v
0 V# |9 B, V, v- ` %target_tem经小范围选择后需要写入目标的剩余的目标的数量
" F1 ]+ l3 U9 L0 e3 ? num_in = ii-1;
5 J% F# F n" R: d% S2 H: i# k- k% _* v
%如果经有差值比较后剩余目标数 与 成功保存的目标数 ) ~" \/ r( X( D3 |
%等于需要得保存的目标数则不用再进行比较了 9 L: x4 i H _( o
if num_save_sucess + num_in == num_save_require; 7 [# I8 _0 @9 ?/ N+ O7 [6 H) ] i
flag_display = 1;
2 ~# R n/ e. p, n8 t2 M/ [8 i. R num_save_sucess = num_save_require; ! f7 y: W+ b$ ^8 v
target(num_save_sucess_sum:num_save_sucess_sum + num_save_sucess-1,1:NN)=target_tem(1:num_save_sucess,1:NN);
% o* y' r n I4 G; }) z/ M num_save_sucess_sum = num_save_sucess_sum + num_save_sucess; % x6 m% _0 d- g) V) B3 S
else
# O3 `4 N% x' u& Z' Y. M8 Z target_in = zeros(num_in,NN);
( l& ]1 I, l3 }5 h8 u/ O target_in = target_in_tem; " b0 z% u$ i: [ o ]
% |, O6 K% K1 ]0 C- T" z
num_save_require = num_save_require - num_save_sucess; * {/ P* y7 ^0 q
for i=1:num_save_sucess; ; N5 V& O" ^. Y, ^) V/ d4 g; a* j% Q
target(num_save_sucess_sum+i-1,1:NN)=target_tem(i,1:NN); 9 j. j3 C9 @: B7 F* O
end
% H' x% V( Q' c0 v1 @* [, } C num_save_sucess_sum = num_save_sucess_sum + num_save_sucess;
4 y( j4 b' T& k7 m1 t9 {( Q: j l1 K
$ T" h3 {: _: M target_tem = 0;
i3 B# X8 G: K2 Y* h( p- n- R target_in_tem = 0;
7 y5 k/ |: v+ P; r- s end
" ]; B. ], `4 M( D/ r end 1 R9 K0 i2 v$ M- @# k! G) o" O6 T
; K$ N+ @+ S2 U- P; g %输入目标中的“..”的正值数量刚好等于需要显示的目标的数量(此种情况仅存在于比较数据中存在负数) 5 {- o% t% V; p' @6 x6 Z7 W1 d
elseif pre_num_save_sucess == num_save_require && left_num == num_in;
: \ a( A b# V- ^( K flag_display = 1; + g9 \$ }" B; o; |: w
target(num_save_sucess_sum:num_save_sucess_sum + pre_num_save_sucess-1,1:NN)=target_tem(1:pre_num_save_sucess,1:NN); }* u2 \5 s8 `- Y2 O( x( m+ p# P
, z- A. s$ [" _; m* x9 b1 u9 @
%输入目标中的“..”的正值数量小于需要显示的目标的数量 (此种情况仅存在于比较数据中存在负数) 6 [8 v( H8 [7 }
elseif pre_num_save_sucess < num_save_require && left_num == num_in;
( L& N" l. a9 L flag_v_compare = 0;
; W& u9 t' P& J, Z9 ]* y flag_display = 0;
# M# R9 O! |& u" d3 e ii=1; 8 Q9 h( e! U' D8 {, b7 Y
for i=1:num_in
) P5 t4 I" `6 J9 k$ F3 i+ A$ z if target_in(i,7) <= 0; " F5 _7 [) c% O/ c" c* r
target_in_tem(ii,1:NN)=target_in(i,1:NN);
* n- j' t2 t* G v7 V ii = ii + 1;
^( l6 j m% v end - u, F1 H. [: E" I( `/ H, M
end 4 n' j w5 T, A2 B: z
num_in = ii - 1;
1 v0 _4 K: R( z target_in = zeros(num_in, NN); / s4 u: y1 J! |! @1 G/ t$ ^ p
target_in = target_in_tem; " q4 ]2 ]8 y/ h6 x: k
num_save_require = num_save_require - pre_num_save_sucess; # h; }' J/ }2 Y, D
if pre_num_save_sucess > 0; 2 Z* }3 B$ a0 i; S! j; s: i! T" p
* ?7 g i$ a6 H2 ] end ; g. n! g# k' Z4 x h2 r+ K
num_save_sucess_sum = num_save_sucess_sum + pre_num_save_sucess; . K3 E: e0 E" _9 Z' j$ b* W
target_tem = 0;
2 l+ {/ N; l* [- M% h! r target_in_tem = 0; ( z# f$ l l. H% f
end # n2 J6 V4 e: j3 C; z& W4 }6 f
elseif flag_display == 0 && num_in <= num_save_require; 0 ?. \! {4 w* ], k0 n! b9 A, h1 D
flag_display =1;
: U% X/ ^! X; r& e$ D" E target(num_save_sucess_sum:num_save_sucess_sum + num_in-1,1:NN)=target_in(1:num_in,1:NN); ; h1 T$ n; O% C3 L- d( T
end
8 j( z/ ?" u3 Z- v8 o |
