本帖最后由 sunstar 于 2010-8-8 10:27 编辑 9 A! n+ E) U7 x
2 w7 ^9 [5 U0 P/ k" n9 C如下,提示没有part number,是不是我库的问题?库里面都有号的啊 以下是在package原理图时的出错提示. @8 w# O( {1 u" h; v8 R0 g1 C
5 k y! o4 k. Z& T+ _0 o
Commandline is: "C:\mentorGraphics\2007.5EE\SDD_HOME\wg\win32\bin\package.exe -jC:\MentorGraphics\Projrct\test\test.prj -nDesign1 -i -Block=Schematic1 -k -Add"
% ]) F2 r) e* ]" ?5 _2 n! d* j
+ I# |& ^3 b! c* Q! e The Common Database is at "C:\MentorGraphics\Projrct\test\database".0 l/ ^) S8 L6 X' r& \7 c0 Z0 c
2 a' g5 }, ^/ L% ~ The Root of this design is "Schematic1".2 ~+ G7 M t) P- T$ i( ?
2 E& r$ r, w' [6 L$ \4 l
The Front End Snapshot of this design is "DxD".- }9 ], I3 @- t0 W2 k5 x& X
5 t- @4 ^6 S6 F- a: t
The PCB Design Path of this design is at "C:\MentorGraphics\Projrct\test\PCB\Design1.pcb".
: {, q- X3 t. f0 X7 ~( i& Y4 w7 a/ c; g* s2 Q
The Central Library is at "C:\MentorGraphics\Dx_Lib\Dx_Lib.lmc".
/ r9 ?+ ?4 B9 u+ S* P
, \8 Z8 l M7 |2 C The "-Block" option is not compatible with the "Repackage All" or "Repackage Unfixed" options.
* e: t: B. g! F7 z/ e; S* x1 U: j+ _
/ \" E: O5 R# o% p5 ]
% a+ X8 U& _& [+ O& O以下是在forward原理图到PCB时的出错提示7 F: {% Y4 l/ _" v. v5 W# \3 U
2 a0 ~5 \& A% y
ERROR: There is no Part Number: DEV in the Parts
6 B! a7 D% Z! ^3 A- H+ C2 F+ I DataBase for symbols with Part Name: (null) and Part Label: (null).: I/ z9 ?& ^, r% l
[Please add the Part Number to the PDB either directly/ g- r) J% d5 g# W$ N8 f
or by having the project file point to a PDB that contains it.]
1 l2 m0 E+ P5 l) d. o0 \ The relevant symbols are: |
