查看: 1809|回复: 1
artwork出现的警告是否可以不理会(急等回复)
发表于 2008-4-24 09:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.================================================================6 f6 X7 m& H6 D  U
     PROCESSING FILM < TOP.art > ...
1 t# `' c3 Y/ D4 @; M================================================================. B9 T+ U* |" p: Z3 s
  FILM PARAMETERS :, G( q3 l# s. W0 O. `2 i. D
9 r) w. r- ]# k# H  Undefined line width                6.00
1 _$ w3 x: [, n  Mirror code                         NONE
$ `/ B, ?5 v  k  Rotate angle                        NONE4 Z9 ~) h; a4 o9 D, Y
  Offset x:                           0.00
: u0 P. L4 n# E* k  Offset y:                           0.00
0 _" t& i8 m! f9 ?& i' O  Plot negative                       NO
1 Z: j2 {  I! Y; @4 O" |7 Q  Suppress unconnected internal pads  NO
$ q% X5 V4 y% Y: J2 K; sWARNING: 0 width line found at (50.00 0.00)
0 E2 f% y" I2 y$ ]5 Z# \
0 z* v: ~! x% P# a+ C4 e9 M! b2.FILM PARAMETERS :
1 _$ ^, N* Q; `* `$ g& `  ---------------------------------------------------------
5 g+ z" b, w, I" m7 `  Undefined line width                6.00# @+ n; d; \0 Z5 s7 N% n
  Mirror code                         NONE  d4 u, P. F) e; F. o
  Rotate angle                        NONE
3 p1 R8 n9 ^$ P9 R( S/ u6 `  Offset x:                           0.00# O& k" \  @  z. W" a: J, {
  Offset y:                           0.00
7 }; g/ w3 W1 g& l" R" @+ u  Plot negative                       YES, l* N& W. t" ^4 c5 k: j9 X; \6 r
+ \/ u4 R/ W0 r; {) f: k- A    WARNING:  Layer polarity of class ETCH subclass VCC does not
; l( |9 R4 w" D- v* h$ \              match film polarity of Negative.  DRC may be unreliable.: h% A& \8 [% t% }
如果要改正,针对以上两个警告,该怎么改正啊.谢谢回答
5 a$ H0 A! @- L. `
) U/ u& Z& f" V% f# w[ 本帖最后由 elmma 于 2008-4-24 13:12 编辑 ]
参与人数 1贡献 +3 收起 理由
kxx27 + 3
 楼主| 发表于 2008-4-24 10:53 | 只看该作者
NC-drill Legend时出现一下错误,如何改正
5 y* z7 E" |' ], V$ \Begin processing drill holes.. ?3 ]. t/ a- M2 T8 e
Warning : Hole 32.00-0.00-C-P-0.00-0.00 uses multiple drill figures.% h  q2 K' I$ h: ]
Warning : Hole 38.00-0.00-C-P-0.00-0.00 uses multiple drill figures.* k2 u8 q0 M0 ^4 {# D! M
Warning : Hole 100.00-0.00-C-P-0.00-0.00 uses multiple drill figures.
- J; [$ F; Y) CEnd processing drill holes.
GMT+8, 2025-11-1 06:36 , Processed in 0.140625 second(s), 28 queries , Gzip On.
