查看: 2942|回复: 4
2010 DesignCon 获奖论文
发表于 2010-6-30 14:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本帖最后由 stupid 于 2010-6-30 14:56 编辑 # n% s" t1 _  W3 P8 F- w! t0 S
& C9 \* m/ X: a+ N0 CChip-Level Design
; s) n! M; O: D( U* }7 Q! y% w1 [( ~8 }- M$ Y* e4 {* ]9 q
Creating C++ IP for High Performance Hardware Implementations of FFTs
5 d! ]9 q. @: c. `6 x1 a0 h4 T, A- K- x! ]
Strong Encryption and Correct Design Are Not Enough: Protecting Your Secure System from Side Channel Attacks
  j" F3 w# f" y2 f( x* `& t$ p0 K# ~( C7 v
Board and System Design0 z0 v. X+ g3 Z4 e! B/ ~$ F
. L& L- ?$ J0 J7 REffect of Conductor Profile on the Insertion Loss, Phase Constant, and Dispersion in Thin High Frequency Transmission Lines5 }4 s. ^  Z3 m4 r" @/ W8 w
" N% p2 j& W- a+ G5 j8 Z
Introduction and Comparison of an Alternate Methodology for Measuring Loss Tangent of PCB Laminates
9 j2 y/ |% Z: T$ O# d1 M5 c/ o- C. o2 P. e4 p4 X, {, F+ e3 c
Interconnect Design$ u; S$ q. z" c+ d
" b, j) Y' p. L' D% Q$ F  w8 ~Frequency Dependent Material Properties: So What?
2 Y, d5 g8 S7 W9 |6 W4 {# Y7 c  `9 }
Additional Trace Losses due to Glass-Weave Periodic Loading
+ L0 q) v4 s3 M; I( `- d
9 Y3 s. q0 A  ZHigh-Speed Design and Test Category8 z+ B  D2 s$ j  U8 F' f+ Q
" E4 Z0 B  f$ j$ X  r: F& u8 E
A New Method for Receiver Tolerance Testing Using Crest Factor Emulation
  r/ c: @6 F( @* z0 r+ \+ w- b5 K
Accuracy Improvements of PDN Impedance Measurements in the Low to Middle Frequency Range
" z9 y% M$ g$ R, U7 ]
9 _: Y# E1 @( m1 m+ P1 \8 d6 DPower and RF Design Category4 J- s7 u/ v( n; C
: x8 H' x4 D" G# Q4 COn-Chip PDN Noise Characterization and Modeling
0 Q9 I) `# P1 |
: j9 V- a7 H+ R! Q9 g; {/ D0 cFast Physics-Based Via and Trace Models for Signal and Power Integrity Co-Analysis
发表于 2010-10-3 01:55 | 只看该作者
哪位有账号可以下载,给大家分享一下啊
发表于 2010-10-5 00:35 | 只看该作者
回复 1# stupid 3 \0 i- t/ h6 b7 f
' A% g7 z% l7 T- c: o
" F: w4 f2 ?4 x6 Y9 {1 o% m1 Q    Thanks!!!
发表于 2010-10-12 15:46 | 只看该作者
谁有帐号啊,试着注册结果到了第三步就刷不出来页面了
发表于 2011-9-4 13:20 | 只看该作者
等待DX们。
GMT+8, 2025-7-22 08:49 , Processed in 0.125000 second(s), 24 queries , Gzip On.
