序列 x(n)的奇偶分解的公式为:
, U) R) J; w7 e, ?2 ?1 [8 [$ A6 Z
7 `7 D1 m5 k+ X! o
# d0 n7 y) f: f/ O
$ N8 x$ @% h/ w' g8 Z, l+ j8 H0 U- C+ I( d$ y" O& l
& A( [3 ?, H, f$ C! |: I编写一个序列 x(n) 的奇偶分解式 xe(n) 和 xo(n),需要考虑的问题是序列长度,下标的变化。
1 p0 i# R& D) _! x( H* A7 r# ~2 R9 a/ m5 G0 U9 l, b
这里必须做个声明,下面的程序中用到了前几篇博客中的几个函数,这里给贴出来:. @/ x3 K+ o& X& v) @
- U# S2 F+ f; t! p
信号相加:
- s. P1 l* u$ a$ z- |0 }- ~4 |( k8 F! v+ d5 F7 q4 r; n3 y
function [y,n] = sigadd(x1,n1,x2,n2)
/ Z+ H1 ?6 G' m1 o- I" f5 p# O% implements y(n) = x1(n) + x2(n)5 x1 |2 V2 E: P C) z
% [y,n] = sigadd(x1,n1,x2,n2), {& g6 m/ x3 z8 k# U
%____________________________________
- E% t+ H" W0 T, ^% y = sum sequence over n, which includes n1 and n2& ~* D9 H4 R$ d7 \* v7 Y3 g6 c
% x1 = first sequence over n1
/ F3 D$ b, H5 f% x2 = second sequence over n2( n2 can be different from n1)2 w% F V" p; N1 H5 {# z
%/ e6 [3 H/ D7 X6 Y% t4 `. m
n = min( min(n1), min(n2) ):max( max(n1), max(n2) ); %duration of y(n)
8 L3 q+ h2 k" r' B8 xy1 = zeros(1,length(n)); y2 = y1; %initialization+ @$ z; r, P) P/ y: J
y1( find( ( n >= min(n1) )&( n <= max(n1) ) == 1 ) ) = x1; %x1 with duration of y1
6 Y7 ~ s/ ~' J, Q1 p) {y2( find( ( n >= min(n2) )&( n <= max(n2) ) == 1 ) ) = x2; %x2 with duration of y2
% E- ^3 [3 w$ x. Dy = y1 + y2;
% x2 ?- c+ h' G, w+ E
: D: t$ u- h2 `& X+ c* c3 w7 M8 r6 D$ d4 {$ e: T7 i% q
信号移位:( e) F% g$ H, F1 w6 ~( ^8 [# P1 T
9 ]' y6 T3 x1 a) q; r
function [y,n] = sigshift(x,m,k)# M+ K: U: ?$ @9 V4 ^
%implements y(n) = x(n - k)
+ R) j: G! g7 C- d2 s) g& g; P7 V%_________________________! y: y7 d' x8 [$ e% E
%[y,n] = sigshift(x,m,k)( D3 ]; ~, {# L1 U
% ^% T* a/ x! w! D" f1 in = m+k;
2 F0 n9 |! p2 ]# B' f9 h9 _9 F9 J1 yy = x;
; l; N, \- y2 D$ n2 v. M4 s- y
; O9 B$ ]* k7 n# }3 T, Q) r! x; N& Q; h- ?
单位阶跃序列:. p, q7 L2 c1 A2 c7 A8 t1 u
% R; [$ ^2 U8 L5 g/ t
function [x,n]=stepseq(n0,n1,n2);6 a6 d# A6 \( L) L- h( _
% generate x(n) = u(n - n0); n1 <= n <= n2
$ E$ H. g- U/ i' ^6 W1 Y* a%_____________________________________________) p( ~# ~. k/ S7 W5 y3 @
%[x,n] = stepseq(n0, n1, n2);/ R1 w. X; J7 D3 W6 o( |. h1 g4 z
: r" C, X q+ \( k1 F- h! j f6 \n = [n1:n2];
- g) n! Y3 _8 lx = [(n-n0) >= 0];( K# l; e' k4 P
/ W9 o4 v) L; d' ?, K8 V1 t
6 R+ g2 d; P& f' }" d7 Q* r
下面给出函数程序:
1 U# _6 K& F) q4 \3 Q- S: Q, R
8 e5 N! N1 H6 z4 f& Wfunction [xe, xo, m] = evenodd(x, n)
) r; n7 S o F% Real signal decomposition into even and odd parts
# e+ z2 ~6 O ]2 g%__________________________________________________( R0 ?" U& C5 D& m. v2 I+ l7 C
%[xe, xo, m] = evenodd(x, n)7 d. h. l; o4 L6 h6 e( b6 b, q
8 u/ f0 c" ~( F* O4 Z) I; \0 pif any( imag(x) ): Q' L9 i8 ?7 _8 B* Z, Q
error('x is not a real sequence!');! `; M* A* Z0 |* c3 f/ n4 S
end! H: Z0 l3 e# d7 ^4 l
# a; ~0 w, k* r( z/ S3 O% Ensure m of xe and xo
3 K; D% e: Z6 l, u. w, m z/ Tm = - fliplr(n);: K2 |. t) B' C9 M- }
m1 = min([m,n]);! \/ b. C) |7 s
m2 = max([m,n]);
) \9 [1 A5 n. f' om = m1:m2;9 M# E; ~0 M: M5 |# x
, h8 _8 g3 c# F2 p e4 A/ D6 a$ N% Ensure x over m
7 L+ `: q3 a1 u2 T2 pnm = n(1) - m(1);4 i8 j" b9 o( L8 I J
n1 = 1:length(n);0 i- Y0 r" K* B$ D" g) h' _4 _# l
x1 = zeros(1,length(m)); % initialization/ \3 M3 h+ E' a: m
x1(nm + n1) = x;
+ L+ ]/ ~2 O/ }* A5 E3 ix = x1; % new x which enlarge index n7 I' |6 d# U" E) r1 I$ n H
! M# m; s8 T7 ~. D$ ?' x
% xe and xo3 l7 q7 L8 y& R* `' E- U
xe = 0.5*(x + fliplr(x));) s) h' b2 k* s9 [& Z# L7 g( j# k# n
xo = 0.5*(x - fliplr(x));
; U7 E9 {- q* j! z# V; E" m
. |$ ] N+ d7 K, [1 O8 V7 n" p0 E$ x( F5 _# W, b; B/ p
序列和及其位置分别装入 x 和 n 数组。首先确认是否已知序列是实序列并在m数组中确定偶部和奇部分量的位置,最后将所得奇偶分量存入xe和xo数组中。
3 d& @5 m2 i8 Z ~; }' E
, c; ?. A! A5 O& s下面以一个实例来验证上述函数:: o Y8 S- O' P% U" g
6 m; F( g d, @4 M
0 t' S) h4 r' m
; y3 U; j; c/ V0 y
将x(n)分解为奇偶分量。# v# Q, U: R+ c8 \
% }1 \% k' h, T$ Fclc
2 h1 s+ d! o6 Nclear) y$ T: R0 m% l+ M- s
close all
- v5 ?/ b8 j0 Y
: n" z' k6 _4 z, o( T$ J. d/ E; P+ Un = 0:10;2 ~2 {9 Q* K0 b1 Z8 P p, ]
x = stepseq(0,0,10) - stepseq(10,0,10);2 O5 Y( l' j5 H1 d5 f, u9 }, F: l
[xe, xo, m] = evenodd(x,n);0 g" ?# r4 [ s; n4 N% I& p* C0 z
7 g3 q; N& r8 w7 V
subplot(2,2,1);& r4 P* i" t# H% n5 @" {: Y( _+ O
stem(n,x,'filled');
& Q5 ^* t" X: ~$ htitle('Rectangular pulse');
$ Q j$ U5 D! Y% |- ]xlabel('n');ylabel('x(n)'); - s% Z( b: K/ u
axis([-10,10,0,1.2]);" f2 N5 C& h, a) E
2 h) o: }/ {& T3 f6 |0 G
subplot(2,2,2);1 j; _9 G% u( A$ x' F, R8 _
stem(m,xe,'filled');4 F* n& Z1 i/ {( K7 I
title('Even part');
( z% N5 a! Q% c% X* Y0 D. z; Wxlabel('n');ylabel('xe(n)');
- M9 W0 `0 N% }6 ~7 j! Vaxis([-10,10,0,1.2]);
& t7 O J _( U/ m+ i5 J% w7 m# K" i, ` l6 j# `- @
subplot(2,2,4);0 I, |" Z! ]: H# p4 W
stem(m,xo,'filled');! } |" N/ a6 [
title('Odd part');0 P4 I8 D' z7 F8 Q& U
xlabel('n');ylabel('xo(n)');! y9 X ?& C, T( T7 I4 E& e
axis([-10,10,-0.6,0.6]);: Y* d' O5 i" c( \2 h
; R& z6 C. R: V0 @6 v
! x3 v& b+ v. m7 ]- X0 s5 i* T k; @: e( a; q; ]
事实上,这篇博文到这里已经结束了,那我还想看看序列x(n)= u(n) - u(n-10)的合成过程:
/ m$ I( l/ F( F0 c! t9 {& M# @/ \& d2 q N
clc" L% q z+ ]# P; m
clear* I, _+ m6 ?4 m5 e/ i
close all
( @9 }/ z. `) y/ f! I! u6 f
: V+ R& J5 P! P' M- {: Q2 w" }[u1,n1] = stepseq(0,0,10);5 C# A* M. Q* M8 j3 j( k4 }
6 i j! R) Y) {3 bsubplot(3,1,1)
' R2 [9 a3 n- Tstem(n1,u1,'filled');
7 q5 Z4 C; W8 ~) F3 Gtitle('u(n)');
4 J" H" j4 T! Lylabel('u(n)');xlabel('n');
9 H3 s- Y |5 B$ }. ?# e5 Gaxis([-10,10,0,1.2]);
- J2 I# k9 P/ o6 \/ `
) P: L6 i* X3 Q: L[u2,n2] = sigshift(u1,n1,10);! s! G9 x" M( D8 H3 a/ w
subplot(3,1,2)
8 I+ W" l; q! I. R1 b" i+ Hstem(n2,u2,'filled');0 X: \+ |9 a0 V0 B5 I$ V& C. s
title('u(n-10)')
; c- [8 T7 l/ J# p- fxlabel('n');ylabel('u(n - 10)');
" i6 |) e% _: W# k' y- ]( F9 [ ]% laxis([0,20,0,1.2]);
4 ?8 m5 j6 B% l( d) m$ ^, y% J: F8 [" K W7 X$ ~
[x,n] = sigadd(u1,n1,-u2,n2);
1 m$ r( Z! c2 U# H* i8 q2 f4 B: W2 b% N) A% s- P4 H. a
subplot(3,1,3)$ s J. m, s+ P& m8 a
stem(n,x,'filled');
' \, b Z3 |5 m, n* N( ztitle('Rectangular sequence');
' @& z, Q. K' \# Nxlabel('n');ylabel('x(n)= u(n) - u(n -10)');9 f _0 ]4 c4 o
& v' \* D1 ]9 _. m
+ J$ S3 u& y1 F
) e% C1 o# _, B- v; [# \* e$ ~+ `8 h: }
1 v# Z9 _) k! t" X2 J# I& R |
