查看: 23371|回复: 218
分享个人下载的17.4的6号补丁网盘链接
发表于 2020-5-4 11:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
链接:
游客,如果您要查看本帖隐藏内容请回复
; f  A: y6 d4 ]4 y4 g8 I, W
推荐
发表于 2020-5-4 21:55 | 只看该作者
Fixed CCRs: SPB 17.4 HF006 04-30-2020 ======================================================================================================================================================== CCRID   Product            ProductLevel2 Title ======================================================================================================================================================== 2194747 ALLEGRO_EDITOR     DFM           Minimum gap DFM error within same polygon not caught 2233051 ALLEGRO_EDITOR     DFM           Copper Spacing: Thru via hole to Non signal shape DRC not working with BB via 2238666 ALLEGRO_EDITOR     DFM           DFF Silkscreen constraints showing DRC even though there is no violation. 1938592 ALLEGRO_EDITOR     EDIT_ETCH     Not able to use AiDT option to length match the traces. 1960535 ALLEGRO_EDITOR     EDIT_ETCH     AiDT does not work for buses with width larger than minimum width 2036229 ALLEGRO_EDITOR     EDIT_ETCH     AiDT does not work on Non-default min Width 2157973 ALLEGRO_EDITOR     EDIT_ETCH     AiDT is not working due to line width constraints 2175464 ALLEGRO_EDITOR     EDIT_ETCH     auto tuning in AiDT fails to tune differential pairs 2223214 ALLEGRO_EDITOR     EDIT_SHAPE    Menus for Shape Operations are missing from OrCAD menu set 2213659 ALLEGRO_EDITOR     INTERACTIV    Last placed component is unplaced in Allegro PCB Editor because cross placement is picking that component 2216410 ALLEGRO_EDITOR     INTERACTIV    Issue with cross place from OrCAD Capture to PCB Editor: placed part selected 2253831 ALLEGRO_EDITOR     INTERFACES    Release 17.2-2016, HotFix065: Some arc segments not mirrored properly on exporting PDF with Film mirrored checked 2254260 ALLEGRO_EDITOR     INTERFACES    Arc lines not flipping correctly in PDF in HotFix004 and HotFix005 when the film is mirrored 2226610 ALLEGRO_EDITOR     NC            Backdrill_pressfit_connector - the bottom side drill passes are not getting excluded 2228366 ALLEGRO_EDITOR     NC            Setting 'BACKDRILL_OVERRIDE' to 'TOP:TOP:BOTTOM:BOTTOM' does not work 2230619 ALLEGRO_EDITOR     NC            PCB Editor stops responding when creating Layer Pairs in the Backdrill Layer Pair Initialization window. 2241339 ALLEGRO_EDITOR     NC            Setting 'Backdrill_Override' to 'top:top:bottom:bottom' leads to incorrect  backdrill analysis result 2236280 ALLEGRO_EDITOR     PAD_EDITOR    Drill tool size reverts to original value 2232567 ALLEGRO_EDITOR     PLACEMENT     Place manually by library takes long time in HotFix 064 2243727 ALLEGRO_EDITOR     PLACEMENT     Allegro PCB Editor crashes on Place Manual 2246145 ALLEGRO_EDITOR     PLACEMENT     Place manually by 'library' as the source takes much longer than it used to in release 16.6. 2215844 ALLEGRO_EDITOR     SHAPE         Route Keepout prevents correct shape update 2234915 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes on selecting 'Trim corner' popup option in Shape Edit mode 2078335 ALLEGRO_EDITOR     SKILL         Discrepancy with axlAddSelectBox() and axlSingleSelectBox() definition 2223446 ALLEGRO_EDITOR     SKILL         Casing of axlDBTextBlockFindName() 2231369 ALLEGRO_EDITOR     SKILL         Invalid option type warning when using "axlFilmCreate("test" ?polyCutLayer nil)" 2235666 ALLEGRO_EDITOR     UI_FORMS      Export parameters window is small and cannot be scaled up in HotFixes 003 and 004 2239984 ALLEGRO_EDITOR     UI_FORMS      Callback function for form not invoked if multiple fields are selected by dragging mouse 2167454 ALLEGRO_EDITOR     UI_GENERAL    Custom commands and HTML XProbe: Triggering actions from HTML files 2227489 ALLEGRO_EDITOR     UI_GENERAL    HTML cross probing in release 17.4 works partially 2222689 ALLEGRO_LIB_CRT    CORE          Edit External Padstack from LC 2233072 CAPTURE            CONNECTIVITY  OrCAD Capture stops responding on transferring occurrence property to instance 2237520 CAPTURE            GENERAL       Issue with CIS toolbar translation in Japanese: Capture crashes 2220792 PSPICE             PROBE         Release 17.4-2019, PSpice: Unable to read simulation messages in summary window 2239253 PSPICE             PROBE         Message summary dialog in PSpice in release 17.4-2019 does not show message 2234913 PULSE              CORE          Data node crash because of going out of memory 2236450 PULSE              CORE          Database syntax error: server out of memory 2222469 PULSE              UNIFIED_SEARC OrCAD Capture Search Providers crash with specific part placement 2233638 PULSE              UNIFIED_SEARC Capture crashes when trying to use Place > Search Providers 1913829 SPECCTRA           LICENSING     Cannot run SPECCTRA with an OrCAD PCB Expert license 2212091 SPECCTRA           LICENSING     Include OrCAD PCB Router license for autorouting in OrCAD PCB Expert suite (PO9205)
推荐
发表于 2020-5-11 20:51 | 只看该作者
thanks                                         : j. V. @$ U+ V9 ^5 i
    2020-3-21 15:26
    推荐
    发表于 2020-5-6 18:21 | 只看该作者
    谢谢分享!
    发表于 2020-5-4 13:13 | 只看该作者
    很好啊 谢谢大侠们的五四奉献
    ! o9 j- W2 t. u) G
    - T( T2 `2 @" b
    发表于 2020-5-4 13:27 | 只看该作者
    大侠们的五四奉献
    难过
    2025-1-20 15:39
  • 签到天数: 100 天
    [LV.6]常住居民II
    发表于 2020-5-4 13:34 | 只看该作者
    大佬真及时
    “来自电巢APP”
    奋斗
    2021-11-23 15:00
  • 签到天数: 478 天
    [LV.9]以坛为家II
    发表于 2020-5-4 14:23 | 只看该作者
    看看好用吗?
    2025-11-3 15:55
  • 签到天数: 1075 天
    [LV.10]以坛为家III
    发表于 2020-5-4 14:32 | 只看该作者
    谢谢分享!更新得真快啊!
    $ Q) ]' ^9 Q3 w% L* Q1 q
    13#
    发表于 2020-5-4 15:48 | 只看该作者
    很好啊 谢谢大侠们的五四奉献
    2024-2-9 15:00
  • 签到天数: 191 天
    [LV.7]常住居民III
    14#
    发表于 2020-5-4 16:44 来自手机 | 只看该作者
    谢谢分享!更新得真快啊
    15#
    发表于 2020-5-4 16:54 | 只看该作者
    很好啊 谢谢大侠们的五四奉献
    GMT+8, 2025-11-5 08:44 , Processed in 0.156250 second(s), 26 queries , Gzip On.
