查看: 674|回复: 1
用matlab在一张图上同时画bar和plot
发表于 2020-4-23 09:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Uindex=[1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26];
+ Y# T2 G9 s2 y4 W! u# hPandR=[0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 31.3 19.3;...
3 s, `3 t# D* ?* e       15.2 19.3; 0 0; 0 0; 0 0; 0 0; 0 0; 155.0 27.5; 152.2 27.5; 121.4 27.5; 121.4 27.5; ...
- P4 b( A2 a1 l! M       0 0; 0 0; 0 0; 350 0; 350 0; 400 0];
: D: b; e: X) G% l& fFullLoadAverageCost=[27.884 28.027 28.192 28.336 28.478 43.679 43.821 43.972 44.117 15.061 15.104 15.144 15.190 ...
* w& Q/ y- n+ M# q) _                     20.802 20.895 20.986 12.333 12.371 12.407 12.440 24.826 24.930 25.039 11.903 9.043 9.063];
1 i; `) Z. R. V  g' o' ^  K+ n5 `8 {- @9 O
6 |- ]: k$ P8 |8 y/ Z$ I- ~
[AX,H1,H2]=plotyy(Uindex,PandR,Uindex,FullLoadAverageCost);
: U: I) z* W3 X4 T" z( }0 V
4 [# n, K( v7 q; ?set(AX(: ),'Ycolor','k')5 e/ X5 I# o6 |/ B7 h
set(get(AX(1),'Ylabel'),'string','Output Power, Oputput Reserve (MW)','color','k','linewidth',1.0);
$ z8 T: [4 f5 zset(get(AX(2),'Ylabel'),'string','Average Cost ($/MW)','color','k','linewidth',1.0);" v8 N  U. R- _" P: O  `
%set(AX,'Xlim',[0.5,26.5],'xTick',[1:1:5]);
( l; }# n5 w2 }6 g4 z. zset(AX,'Xlim',[0.5,26.5]);
1 s% Z5 x6 C- b' o" `7 p% G3 G0 \xlabel('Index of Unit');- a1 U9 \0 C. \" w. z2 O$ z+ R$ u" D
set(AX(1),'Ylim',[0,500],'yTick',[0:50:500]);& @- Q6 o3 w+ a' j1 i0 l! ~
set(AX(2),'Ylim',[0,50],'YTick',[0:5:50]);
* Z. ]( \4 k& G5 S* Z%set(H1,'LineStyle','-','Marker','s','color','k','linewidth',1.0);
- Z; }+ k  i1 y: l  D; Dset(H2,'LineStyle','-','Marker','v','color','k','linewidth',1.0);
. \- ^* J' O. w; X, olegend('Output Power','Output Reserve','Average Cost');5 L* ?) A% {' y( m# X$ N
$ p& |: ]2 f; O2 \
关键是 画出来图之后,在“figure properties”里对图进行进一步设置。如设置为曲线,设置为bar$ ^. X( R7 Y& W! [/ z
发表于 2020-4-23 13:24 | 只看该作者
GMT+8, 2025-11-6 09:52 , Processed in 0.156250 second(s), 23 queries , Gzip On.
