. p7 y) m9 h: Z4 }- O- q" P: W0 [
h2 ?6 O) P1 C% ~$ _+ i+ S& B9 E5 E8 G%功能:多重xy轴曲线的绘制 %输入:向量x1,y1,x2,y2 %输出:在同一个曲线图中,有两套x坐标轴(可以的话可以做两套y轴) ! V9 ] s8 s1 V" u) t \# v
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% x1=1:10; y1=1:10; x2=1:10; y2=5:14;
- n8 [7 m0 w* c7 P2 |" G9 Y) V6 Bhl1 = line(x1,y1,'Color','r');%第一条曲线的绘制,以默认的主xy轴为坐标
; T+ T! p: Y3 z9 Pax1 = gca;%设置主坐标轴的颜色,用默认的位置,设定颜色 set(ax1,'XColor','r','YColor','r') ! `/ n2 b+ a2 v9 j) \! C
%创建第二套坐标轴,设定颜色及位置 ax2=axes('Position',get(ax1,'Position'),... 'XAxisLocation','top',... 'YAxisLocation','right',... 'Color','none',... 'XColor','k','YColor','k');
0 {$ z& V+ z+ J* t) [1 @hl2 = line(x2,sin(x2),'Color','k','Parent',ax2);%第二条曲线的绘制,以ax2为坐标系
- W$ O9 o- T7 H# N# Z%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
6 _# P7 J/ d4 m) P$ s. R1 S注意:
% n) V5 {# s o* G0 \( K7 w+ Y7 p(1)改变x1y1x2y2就可以实现plotyy()和plotxx()的功能;
9 V, {8 w1 G" X3 [- z* W6 \(2)因为line()axes()为low_level函数,因此都是在主窗口句柄中绘制,不会产生子窗口,所以当想多增添一条曲线时,直接再用line()函数即可,不用像plot()那样还得用hold on语句。
$ Q! d% ?8 i% }; S, S |
