查看: 275|回复: 1
A20开发板用SD卡烧录系统无法启动,安卓和linux都是不断循环
发表于 2020-4-17 11:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
5 L2 \# y: _3 S. f
* C" J  [: a& R. }先附上log信息,求大神帮忙解答一下  看看哪里出了问题:
& i- M. v' T  t6 J! X: M; s! _MMC:     04 f0 [' E: `4 E
SUNXI SD/MMC: 00 A% s) t% G- L$ R7 N
Man 1b534d Snr 181d555b7 i( Q* m7 {* z/ e. i! l) z4 y
000000 j8 W8 }  M  C) J, x
1.0
, O% y5 e1 R; l---------------MMC version 4.0---------------
% Q+ ]$ }7 ]8 j' w# Z4 N/ C- Q) o---------------mmc->clock 50000000-----------
# H. @: O7 ^# u8 D# o- n4 M---------------mmc->bus_width 4--------------
: U2 D9 z6 Y7 b: [6 O# Tboot0 capacity: 0KB,boot1 capacity: 0KB/ |& H: q' G3 {: o$ ]. F
[      1.812]sunxi flash init ok
) P' ?$ j4 F" J* ?In:    serial
" s* b% G' i0 k% G; F1 a: aOut:   serial" b+ F+ K. j$ z7 f) X, d
Err:   serial
) W( D, L! p+ `# q% e# i+ k--------fastboot partitions--------
6 Y' h/ j3 B9 t; C-total partitions:11-' E: b! _- k" V6 z4 H) x9 T
-name-        -start-       -size-
4 \$ ?& l; R. B7 n: a+ E0 H* d5 `bootloader  : 1000000       2000000
; J! M5 b. k2 }; U. w4 ^- Kenv         : 3000000       1000000
& |) Z: x" c8 @: V) Mboot        : 4000000       1000000     . D% U% E7 p$ |( e: ]
system      : 5000000       28000000
" R( ~# ]4 a" s* `) p/ e; rrecovery    : 2d000000      2000000     4 Y) [" }( }) R
databk      : 2f000000      10000000    3 c2 \- [( ^9 f4 f
misc        : 3f000000      1000000     - |! k1 ^% e7 R8 h  b8 y
private     : 40000000      1000000     / h& X# q) M5 o( j" _
data        : 41000000      40000000    9 N. y/ @1 Y& q, ]0 M4 O$ K
cache       : 81000000      1e000000
4 k: r8 q: M! @! W7 uUDISK       : 9f000000      0
, g9 c% r2 q( `3 @! ~( Z2 N' H-----------------------------------
( m" _' s5 B; _1 y8 N( Sbase bootcmd=run setargs_mmc boot_normal
$ C8 j4 y  `  t+ c. g# i, sbootcmd set setargs_mmc
  l1 m" q' |* A$ m5 {: Gkey 0+ ?2 y1 ]/ o- a7 Q6 ]; J
recovery key high 6, low 4
# e+ m  z. G& X6 F; i7 `1 |cant find fstbt value) w$ @! j" Q! L/ B. X
to be run cmd=run setargs_mmc boot_normal
9 \1 _- l' B# e. mthe user data'magic is bad
2 p) ]) ]  K* k/ s1 }. E* m; {WORK_MODE_BOOT0 P: f( ]/ A4 k' V( O
sunxi_bmp_display
* |7 v# b& ]* Q* H) a  c* H" S+ ^: b! o- z/ w
1 `" n) e1 S0 R** Unable to read "bootlogo.bmp" from sunxi_flash 0:1 **! V1 o# k0 b0 C+ p
sunxi bmp info error : unable to open logo file bootlogo.bmp, S5 R3 @+ M5 m& `0 o; `
[      1.912]Hit any key to stop autoboot:  0
% v: v, F" {  d) [! ?) q  pread boot or recovery all
8 S6 [8 ^7 r! m8 q[      2.402]sunxi flash read : offset 4000000, 11682500 bytes OK/ u/ k( o+ U! Y
[      2.411]ready to boot0 o) r4 L! `( d) g& f
[      2.414]
% l2 i0 z  m, P* u: |6 P8 e, dStarting kernel ...
. z& U5 X5 U. j" Q. C: e' J' S$ ~0 z+ ]; u5 F& ^$ h  J
8 V% f5 U9 p$ q[    0.653836] aw_pm_init: not support super standby. ) y$ ~. g, U6 R+ Z
[    0.693273] sw_ahci sw_ahci.0: SATA power enable do not exist!!
# j) K# k+ g# ^. n[    0.704515] can't get item for emac_power gpio !
0 Z6 M) b" K, i4 N% h1 i[    0.942090] [hdmi]hdmi module init
- F9 H/ m. j. E1 ?2 J# m9 O[    0.948401] ##fb init:w=1280,h=720,fbmode=3
8 E: j7 X/ W. p* R3 G& @[    1.415864] init: start e2fsck listening...[mmc-msg] mmc 0 detect change, present 1
1 A" \/ t6 m" r# l1 a[    2.205233] init: HDMI status = 0, try 20 times!TV status = 0
1 u, k& E/ Y: W2 oHELLO! BOOT0 is starting!2 i" `8 `8 K2 y5 {; c7 k
boot0 version : 3.0.0
4 q) f# O4 A. G; a; f. [dram size =1024' u1 _4 O# j: Q  k: {
card boot number = 0
6 H0 {, B$ n$ w3 I4 S/ scard no is 0& l# f' b$ v' ^6 S$ ]
sdcard 0 line count 0' ]- L% p$ S" `
[mmc]: SD/MMC Card: 4bit, capacity: 30528MB4 j  p, a; |' L
[mmc]: vendor: Man 0x001b534d Snr 0x181d555b
: y, P+ x% D3 {! A[mmc]: product: 00000
: `7 }# L1 i& B' q[mmc]: revision: 1.0* R" n6 i# s; u" o# ?
sdcard 0 init ok5 T& C% \1 j9 x7 L
The size of uboot is 0x000a8000.
# W, N# f* f: Xsum=0x806bd154. G  X. Q( r8 I) r/ \
src_sum=0x806bd1548 l1 H8 G9 u( y8 ?: ^) h
Succeed in loading uboot from sdmmc flash.
. U+ n# f0 a6 B$ m8 a2 c) jReady to disable icache.
- E* w3 I% e9 IJump to secend Boot.' X1 c& }7 n. ]8 [9 v4 T+ q* Z2 j
[      0.177]& n* p) f  x: I
" s4 R$ j- d: E2 F! M( q  b
3 d7 F1 s, c, S$ `4 d/ J0 |" UU-Boot 2011.09-rc1-dirty (Nov 06 2014 - 20:21:15) Allwinner Technology & r$ |2 K6 a$ M3 j( W/ D
; e. n" G$ A: X: J' r8 N1 }: X" Y6 N5 p
[      0.185]version: 1.1.0  c' n% n% O! j& U
[      0.188]pmbus:   ready
8 d7 N! b1 ?1 H: i' Z4 ^; k[      0.192]PMU: AXP20x found" n9 B4 x6 G9 e  r# X4 e) l
[      0.195]PMU: bat ratio = 1003 |- I" W! @% c% I% J% O' g  {( l8 m
[      0.198]PMU: dcdc2 1400- F3 i# E+ K, j0 f; ]. n
[      0.209]PMU: pll1 912 Mhz
4 C6 y! y! p1 n* z4 E( x+ A; a6 rboot_clock = 912
* \: P1 m  @$ c% V' S$ ]" ^dcdc2_vol = 1400
  |4 j+ r% s) T1 V4 X: bdcdc3_vol = 1250/ |5 v5 \) a. f9 X4 }( r
ldo2_vol = 3000
, F4 j) Q# {0 x, Z7 }7 v" W6 {5 Bldo3_vol = 2800
+ U" u+ G# \1 I, \$ D7 `2 jldo4_vol = 2800
' e6 g" f/ R3 \% @& Q8 G% M- ppower_start = 0/ }- {, b3 {! Y( h# x
storage_type = -1
0 Y. E0 B# h: F# R9 rusb_recovery = 1: d3 C/ L" D3 ~
find power_sply to end
0 d1 ?8 c& o4 ?; P; ifel key old mode
( T! j! n& @" l0 ?1 k1 yrun key detect: [# @  e0 L6 `0 J! Y" g" w. F, [8 d
no key found, ^3 a1 D2 a! u4 @1 ?$ R
no key input5 M, U4 ~" N, r% X- B# {! X% h- B/ N
dram_para_set start9 S) E) K! `% B+ r: |+ m! b
dram_para_set end
8 r7 Z6 w2 j9 q& p! q[      0.250]DRAM:  1 GiB/ R* U0 I8 h, T4 }6 _. V+ ]5 I
relocation Offset is: 35b1c000
3 ?' v4 i0 K+ c1 h, G! N9 K: V  xuser_gpio config
0 k$ U; x2 _; P. B% quser_gpio ok6 ^$ q5 P( G2 K' b. [
DRV_DISP_Init: opened
: T3 M# k& g  M; V* T! `[      0.465]boot_disp.output_type=26 }  V9 ]" Q# M/ V" n1 O
[      0.469]boot_disp.output_mode=5
1 Y0 P& X& V8 N3 s[      0.472]boot_disp.auto_hpd=1
1 J. ^8 X! \6 Gworkmode = 0
; w! ]" H* O# a& Q9 i3 o, wMMC:     0
* y+ q/ R- b: G( jSUNXI SD/MMC: 0
; q7 N1 y; h% t- z# RMan 1b534d Snr 181d555b7 s" ?1 C% J- j2 s; ?# m
000001 F6 M6 A5 v3 l' ~: a# Q# Z
1.0) [: g; o: Y* G8 ~6 t4 M  |
---------------MMC version 4.0---------------. ~, |# I4 R2 r
---------------mmc->clock 50000000-----------1 s+ Y8 p1 H. W% a7 P; _" _
1 D7 s) [. R& _/ l/ eboot0 capacity: 0KB,boot1 capacity: 0KB$ u3 N9 j, i, M. S3 y# ^
/ e" q  D/ y" g; o: g. h1 r7 r$ Z6 u* lIn:    serial( }7 Y$ x8 }4 r# N0 H- A7 ]2 m
Out:   serial
" I# z- q: e! k, ^* ]Err:   serial% O/ w6 l: l9 L: p' e' R
--------fastboot partitions--------! ]4 |9 A' U; M0 Q" t- r2 g1 L. ]
" U5 ]( N" O, d2 v* ?( j3 `-name-        -start-       -size-
, i. o# _/ s( X9 s) X, ~bootloader  : 1000000       2000000     1 W! _# o) `- U$ \
7 A' N  t+ L" ]+ @boot        : 4000000       1000000     9 {% H: k# c4 o% i! D& v% H/ }* _
system      : 5000000       28000000    1 c. c( P# `9 }! E1 |; t
recovery    : 2d000000      2000000     " X/ e) N& d% E0 v/ ?
databk      : 2f000000      10000000    2 W. X# E* q2 j8 p( R
misc        : 3f000000      1000000     7 e4 Y- u* O( k; V. ]
private     : 40000000      1000000     0 P9 `2 |* F9 i$ e
data        : 41000000      40000000    : f" \( u' k% T% _# t- X
( s( y' L6 q- {+ ~9 {$ }6 {* LUDISK       : 9f000000      0
+ ?3 c& E6 [3 E% n. A-----------------------------------: j, @" F1 r& j6 `/ x4 J
, {$ g, w( m, w5 Ebootcmd set setargs_mmc
% [- M2 Y; N1 B5 lkey 0
8 L7 Q4 H- `& N' h* Nrecovery key high 6, low 4
6 i* ~% N% z$ j" ucant find fstbt value
+ X+ E, X3 X7 Rto be run cmd=run setargs_mmc boot_normal( g9 M% H+ ^& y# u
$ T3 ?( d+ K- c; @" PWORK_MODE_BOOT. L0 g, Z) o' u+ E8 r7 s9 {
sunxi_bmp_display  L( R! K& y$ }- z. Z
3 x- `& J' @: T8 g0 \, w; @# ~, j1 V1 b$ ^# U6 `4 w
( m( ]1 D! L, R1 a1 [+ x. {- Y
2 _# [; g# p2 P9 U7 @( U- }& F! I
! @( m/ K) q. C6 z; h0 Q, W9 q
3 |+ M# i6 C/ O5 J
3 I/ C# W: o( K- x; I8 M& U& Z
# ?! E& x( D+ h
2 @9 U1 ^: Q+ T1 @% p8 `
/ r( X* V3 R# v4 W5 R- i3 s. q
/ C% G% V* r% T- M$ sHit any key to stop autoboot:  0
* f+ B$ e5 C9 c+ r# t5 g# Vreading uEnv.txt- ]1 R  e! a: X/ U: f3 A/ p8 |. n
155 bytes read in 17 ms (8.8 KiB/s)
/ `3 t9 @+ n% n$ j& c0 m7 CLoaded environment from uEnv.txt
# [3 r6 [" j- f9 `6 K- M! M5 nreading boot.scr/ Z" U) ?/ n+ @# a, n, t
** Unable to read file boot.scr **
" B' m  O) J& [/ i6 JFaiLED to mount ext2 filesystem...
5 w- }" x! U- j( K) |  c% a** Unrecognized filesystem type **
5 Y9 r$ F, @) ^8 J3 n1 R0 h% PFailed to mount ext2 filesystem..." T" N/ I6 _1 ~5 j, k
** Unrecognized filesystem type **6 b# {$ P% N4 S: ]' @( z# B
Failed to mount ext2 filesystem...* S+ A5 q9 r% R7 ]+ k
** Unrecognized filesystem type **9 _) o: }6 J+ P  n% I' s4 u
reading script.bin/ a0 A( ~7 t' @7 W/ k
46576 bytes read in 30 ms (1.5 MiB/s)
, {, U7 W) X! \1 Y" {/ kreading uImage# ~. B  D; c& S! H2 F
4600424 bytes read in 233 ms (18.8 MiB/s)/ Q% C: Q, M. m$ B! r" B
## Booting kernel from Legacy Image at 48000000 .... n  ]7 s$ n, K& H& {; e( P4 E
   Image Name:   Linux-3.4.90% \- w7 x, a$ I7 f0 i8 d
   Image Type:   ARM Linux Kernel Image (uncompressed)! S* u+ m' v2 z- O! R* p
   Data Size:    4600360 Bytes = 4.4 MiB
1 a- Y0 [4 E' V% ]   Load Address: 40008000
6 u3 ^& R7 i& D% B   Entry Point:  40008000
7 x# Y+ d7 ?+ _4 {5 _# m7 D   VerIFying Checksum ... OK
$ w$ l' @% J) `$ R   Loading Kernel Image ... OK% E! ~7 u' K4 }6 C( Z( G
( P! O4 e2 L' n9 w
Starting kernel ...* L/ u! x9 W# i: _8 c# m5 G  _
! N; V: l3 ]% V, O$ e* D& H7 P
<6>Booting Linux on physical CPU 0/ n% H% l& s5 [2 \7 u
<6>Initializing cgroup subsys cpuset% {7 A& i) S( d4 T. d: g! ^; M
<6>Initializing cgroup subsys cpu6 u9 K9 z. u5 m7 d
<5>Linux version 3.4.90 (root@avrman-virtual-machine) (gcc version 4.7.4 (Ubuntu/Linaro 4.7.4-3ubuntu12) ) #1 SMP PREEMPT Sun Jul 1 20:14:11 CST 2018
* I& L. A0 X; ^* [CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
/ h. L! }  @9 ^# K$ x5 h% Z* VCPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
4 I+ I9 J  y0 W) U8 tMachine: sun7i4 w& {5 V$ _! O4 M3 k
<6>Memory Reserved:" Y* z; {" ^1 B6 h0 q7 D
<6>     SYS  : 0x43000000 - 0x4300ffff  (  64 kB)0 _0 @5 _& Z, _' t( f
<6>     G2D  : 0x50000000 - 0x50ffffff  (  16 MB)
2 J" H% y9 \# K: h# k- y<6>     LCD  : 0x51000000 - 0x52ffffff  (  32 MB)4 V3 j8 R+ T3 A: A6 e
<6>cma: CMA: reserved 192 MiB at 43c000009 R  R1 o9 j% A8 ^( j
Memory policy: ECC disabled, Data cache writealloc
# U- \% [& A6 T" r0 i! N9 x<6>sunxi: Allwinner A20 (AW1651/sun7i) detected.
8 I" }* X7 u+ I5 W. Y<7>On node 0 totalpages: 262144' P. C6 P+ K2 g& g( `, k
<7>free_area_init_node: node 0, pgdat c08b59c0, node_mem_map d30000008 n* L3 n6 k$ Z+ J2 K
<7>  DMA zone: 512 pages used for memmap+ H5 L) |7 O0 Z8 O6 t9 }; ?! N
<7>  DMA zone: 0 pages reserved
2 z7 I" F$ D) f( t$ k$ @* s0 `, x<7>  DMA zone: 65024 pages, LIFO batch:15; D) h, j/ }/ m- S: a
<7>  Normal zone: 1008 pages used for memmap( O6 Z, r7 k, C. r
<7>  Normal zone: 128016 pages, LIFO batch:31
: x/ `1 \$ L) @1 M8 O# R; N, k<7>  HighMem zone: 528 pages used for memmap
0 s7 t9 a# z5 l$ u6 P" u; ~<7>  HighMem zone: 67056 pages, LIFO batch:15
+ k& z; ]5 C3 l* r( X6 y<6>PERCPU: Embedded 7 pages/cpu @d3808000 s7616 r8192 d12864 u327680 u/ Z7 s) [- L8 p; `) [) t, e& t
<7>pcpu-alloc: s7616 r8192 d12864 u32768 alloc=8*4096<c>
# ~; E7 i& I( j0 Q! W% V8 I5 T* o<7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c>9 `* B" X* Z6 i/ o9 O3 J
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
; |5 Z6 F; ^# D& _<5>Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 loglevel=8 panic=10 console=tty0 hdmi.audio=EDID:0 disp.screen0_output_mode=EDID:1280x720p50 rootwait panic=10 rootfstype=ext4 rootflags=discard
/ D" p# g4 H: p: @  |& C<6>PID hash table entries: 4096 (order: 2, 16384 bytes). ^3 D! _) y; }
<6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)# d' p, q6 r. W: k1 f2 D
<6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)( Q- M+ S/ l) k7 h( @
<6>allocated 2097152 bytes of page_cgroup1 o$ b0 x1 {$ Z  f
<6>please try 'cgroup_disable=memory' option if you don't want memory cgroups5 R+ k0 l( ~. {
<6>Memory: 1024MB = 1024MB total
8 r* P0 z" [+ N2 B4 Q<5>Memory: 780420k/780420k available, 268156k reserved, 270336K highmem' _' ]1 a6 y/ v, e" U" A
<5>Virtual kernel memory layout:
: b1 k% G" s% N7 `    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
* u: D) u' M, N& A    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)! o" c, ~& z0 C$ \
    vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)4 p9 W& {9 a$ o% e3 Y$ ^
    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
: @' @3 n2 I: Y. M) F; F    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
- f% a1 C$ ]2 X% r7 L    modules : 0xbf000000 - 0xbfe00000   (  14 MB)5 ~4 @, U" B- A, x( E( }  r+ b
      .text : 0xc0008000 - 0xc0818000   (8256 kB); a) t9 W6 U3 r% E( A% s) w' I2 a, M
      .init : 0xc0818000 - 0xc084edc0   ( 220 kB)
! t3 ]' y6 \# S9 P# F      .data : 0xc0850000 - 0xc08bd058   ( 437 kB)
  A4 f  B+ h6 B. g& f5 V       .bss : 0xc08bd07c - 0xc0a8f718   (1866 kB)
: e2 Y' j- m6 e* l& J- C' D, Y<6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
0 z9 i9 u7 U2 s* t: L<6>Preemptible hierarchical RCU implementation.
( ^1 r( ~) n( g  a<6>     RCU dyntick-idle grace-period acceleration is enabled.
1 i, D) X6 s/ P- P& g) w( Q4 [<6>     Additional per-CPU info printed with stalls.; G) z+ p- B2 X& }8 Q" [
<6>NR_IRQS:192! S- t) u; W) C- _; ^
<6>Architected local timer running at 24.00MHz.1 ?& L* d5 }# K! Z8 B+ N7 i6 h. S
<6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms; t: \3 @$ I6 A" x$ ]" u, B0 H
<2>start_kernel(): bug: interrupts were enabled early
5 n5 _) }; J3 Y" r/ E  U% B<6>Console: colour dummy device 80x308 @! @6 _; m8 h9 |6 f
<6>console [tty0] enabled
6 I) D* r/ |3 D8 S. Y: v1 `<6>Calibrating delay loop... <c>1915.28 BogoMIPS (lpj=9576448)5 k. a& c. \4 K, i/ C% w: C
<6>pid_max: default: 32768 minimum: 301
$ Z* h4 j- E  h1 Y; b! @: S<6>Mount-cache hash table entries: 512$ a$ d5 ?% l3 G3 d" Y5 {9 i# G
<6>Initializing cgroup subsys cpuacct
* f9 o5 I0 I2 }) A# N<6>Initializing cgroup subsys memory
# G- c9 z  O  f5 s: Z2 i<6>Initializing cgroup subsys devices" _4 E' j! A! Y; g* P, U; f
<6>Initializing cgroup subsys freezer" T& n% N5 m5 ]' b. k
<6>Initializing cgroup subsys blkio
' r- q4 W3 x+ o<6>Initializing cgroup subsys peRF_event
" I* d  ?$ ]* \+ L4 u8 }- p<6>CPU: Testing write buffer coherency: ok
4 t* q$ M/ S' {<6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000/ ^! h2 J+ g; V- F: q
<6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
( U2 L7 H+ M9 ^/ f' g# y<6>Setting up static identity map for 0x405c8da8 - 0x405c8e00$ o' V# `$ s; M4 `$ G
CPU1: Booted secondary processor/ B% a$ L6 R/ y9 y
<6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
3 K7 u- }) J. s# A# n5 W9 {8 ]<6>Brought up 2 CPUs7 |" D% @  O2 `4 u: g3 {# l; P
<6>SMP: Total of 2 processors activated (3830.57 BogoMIPS).- f" S! G9 U( O2 U
<6>devtmpfs: initialized
2 h  `8 |9 W6 @3 I2 C# }<6>dummy:
8 b6 f7 ]. Z# \* j<6>NET: Registered protocol family 16
3 T4 C1 Q0 y! N4 m' X6 v<6>DMA: preallocated 256 KiB pool for atomic coherent allocations
. R" a6 x( M1 }6 y, c$ f6 A<6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
8 N1 Y! j4 _8 i) s1 I<6>hw-breakpoint: maximum watchpoint size is 8 bytes.
3 |5 M1 o, Q* k; A9 x  m  D<6>[ccu-inf] aw clock manager init' l. v& |. x8 R6 r
<6>[ccu-inf] aw_ccu_init5 U) c# F3 v; M* D" k) ~/ s& ?! r
<6>[ccu-inf] script config pll3 to 297MHz, N% V- m" k& W9 {! V
<6>[ccu-inf] script config pll4 to 300MHz. t/ w# W$ `3 d, v3 M: C
<6>[ccu-inf] script config pll6 to 600MHz
. o' c4 O# k. H& o, N<6>[ccu-inf] script config pll7 to 297MHz
7 M+ P/ ^* n1 J2 z% `) N$ e/ n! l<6>[ccu-inf] script config pll8 to 336MHz
/ p/ V  A( x* p# Z  O<6>Init eGon pin module v2.0
* d3 O1 A" n( d) J- M& F<6>bio: create slab <bio-0> at 0
$ c8 r0 O1 e9 }0 o- u<5>SCSI subsystem initialized
' ^0 _$ n) _  C6 c6 U1 T1 D8 d<7>libata version 3.00 loaded.* b4 i2 [, u% _  e" m
<6>usbcore: registered new interface driver usbfs0 ?. P: o2 Q* i" ^
<6>usbcore: registered new interface driver hub4 m- N7 v: D; _  g
<6>usbcore: registered new device driver usb1 O/ s$ S( F# f& M
<6>Linux media interface: v0.10
, b/ D& c( _1 F% `4 Y5 F& v<6>Linux video capture interface: v2.00
: k( o& t4 ?6 \# Z3 f& Q" T<6>Advanced Linux Sound Architecture Driver Version 1.0.25.
5 y* U7 n: M  R- D# r<6>cfg80211: Calling CRDA to update world regulatory domain
1 j8 J8 r! g# i: P/ e3 k<6>switching to clocksource arch_sys_counter
. m% g  s: C; t  e2 ]+ s* N<5>FS-Cache: Loaded0 H' A; {6 y( _+ v
<6>CacheFiles: Loaded
: ?2 U2 F9 \3 b; [[usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG. [3 t7 N' Q$ U6 t4 ?8 [, @1 C3 O
[sw_hcd0]: usb host driver initialize........
! U! n# S3 ~! w" D  {[sw_hcd0]: open_usb_clock$ f% N+ V% {: z5 Y3 d2 `3 [
[sw_hcd0]: host_init_state = 1
5 I2 ~, r8 k5 x3 [0 u+ ^[sw_hcd0]: platform is usb host
. ~7 f4 ?7 ~0 Z! o6 o6 ^[sw_hcd0]: sw_hcd_host0: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
! S  S# g; W8 k1 [: t2 ?[sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 703 v9 w6 ^+ C4 Y7 [( `2 X
<6>sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
* |" x  X7 s. n4 T1 H/ o9 l) q: G' z<6>sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
5 O/ S* b" l' P<6>hub 1-0:1.0: USB hub found
) O# x4 v" e* K<6>hub 1-0:1.0: 1 port detected8 r. [; H* o- y: ?$ b
wrn: hcd is not enable, need not start hcd2 {6 y, W* x0 ~, o4 t9 N; r
[sw_hcd0]: sw_usb_host0_disable start
. x% O" C% ~0 _4 l0 g& v/ b9 P-------sw_hcd0_soft_disconnect---------; e$ t: J* H7 G7 P7 ?6 ]* {, U
is_on = 0, hcd0_set_vbus_cnt = 0
3 i% s5 E$ d: O2 i4 N% g& W[sw_hcd_host0]: Set USB Power Off
3 l5 G. Z; s# x/ t) Y8 ?% E* A# kwrn: hcd is not enable, need not stop hcd: _& i3 K( l  \; m1 Q& I
[sw_hcd0]: close_usb_clock9 M3 Y' M0 a6 p, O# ~
[sw_hcd0]: sw_usb_host0_disable end3 e7 i+ U8 y+ P: O3 }1 ^! R
[sw_udc]: udc_init: version 200804110 u! F. [1 k$ k" m" U
<6>NET: Registered protocol family 2
' x5 Q9 ]+ }" Y<6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes)) y& w0 V( w- |4 C
<6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
% K2 B4 S& T( j! p* o5 w<6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes)$ _. [1 L; x# O  `8 _  c5 e
<6>TCP: Hash tables configured (established 131072 bind 65536)% d  k7 M3 \9 ]; r. C2 b+ |5 W
<6>TCP: reno registered
; w4 c% m: y3 B  J  Z  J( Z<6>UDP hash table entries: 512 (order: 2, 16384 bytes), `- K9 y' z9 p, V& W" \" ^
<6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes), R8 F0 e8 ?" z1 r' L) m9 P
<6>NET: Registered protocol family 13 }: J. e% b9 Q( N
<6>RPC: Registered named UNIX socket transport module.
* ^, @& N8 Z+ B6 b& ~<6>RPC: Registered udp transport module.& e% L# v% S, `9 N0 K+ z8 C. F
<6>RPC: Registered tcp transport module.
' U1 E0 `0 f9 B* t<6>RPC: Registered tcp NFSv4.1 backchannel transport module., o+ ]8 w, ^1 m) J6 g) F; A; |5 w, b
<6>audit: initializing netlink socket (disabled)
6 t  |  o, I( ~  d& w5 G/ b<5>type=2000 audit(0.600:1): initialized7 U. X4 v. ?: @: \) G$ U% I
highmem bounce pool size: 64 pages
: P9 H0 h7 |4 X0 t! v<5>VFS: Disk quotas dquot_6.5.2: e% P, u9 R: O
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
$ Y* E7 @1 V1 I" a8 S<5>NFS: Registering the id_resolver key type7 V" G- N" R1 z) ~! N; x5 J# I  @5 x
<6>NTFS driver 2.1.30 [Flags: R/W].
3 P; S; y  y" g% [4 O( w<6>fuse init (API version 7.18)
: Q- x  K) h6 n' D$ W" I<6>msgmni has been set to 1380" T( f+ G* x$ B- ~- W6 |
<3>alg: comp: Compression test 1 failed for lzo-generic: output len = 57
- s& V  s9 X% P7 {9 G7 V<6>alg: No test for stdrng (krng)
; }4 {- T4 i0 c$ h' T9 N( C1 E<6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)9 H0 d1 H. Z- ?, m! T8 X# m+ z
<6>io scheduler noop registered) v1 {; E& ]4 F: O* P9 N! z
<6>io scheduler deadline registered
0 G8 l/ ]+ J( W* Q' s6 K7 C8 w  w7 x<6>io scheduler cfq registered (default)+ s6 {) t9 F# g' _/ N6 F
<6>sunxi disp driver loaded (/dev/disp api 1.0)
; `5 M9 [& J0 u. {) x/ @$ v<6>Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled" d- I3 C; L4 T: Z! a5 n) R/ L
<6>[uart]: used uart info.: 0x01% Q& p% V) t+ C
<6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000
) \$ Y7 D: Z: y# P<6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A# _' t/ L; A% y! b
( ]. L7 o4 Q$ ~  h$ d' LInitializing cgroup subsys cpuset
5 k$ N: o! @% j% p5 `' p" `, x1 J6 JInitializing cgroup subsys cpu5 l/ ?. Y* T, p( ]% z
2 x% Z" r& _7 q  t$ p0 p7 A+ B# C9 lCPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d7 P- u9 K3 J* }% y# N! L7 M. e: L
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache8 C, A9 W2 p# R( h
Machine: sun7i$ p  g1 }: U4 j
Memory Reserved:
4 F$ a* Z: V+ @        SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
! d( S$ r( [: p7 U3 |- \0 N        G2D  : 0x50000000 - 0x50ffffff  (  16 MB)1 W, ?; W, ?. _& v8 C" c
        LCD  : 0x51000000 - 0x52ffffff  (  32 MB)# P0 V6 }5 Y# P' V+ _8 \' S
: P( m9 q3 V& q1 W3 b* GMemory policy: ECC disabled, Data cache writealloc/ Q% d% d9 x( q0 A. S! {" n* z
2 m2 s" o6 I; o: y' L" nOn node 0 totalpages: 262144$ K/ ^, W/ [' \% h7 H4 P" w; S
$ T& a4 R0 L' K! O0 U% D/ ?" z! ^  DMA zone: 512 pages used for memmap' c8 T! `) n  R7 r
  DMA zone: 0 pages reserved4 [0 C+ @1 O3 {& |2 n5 i. e
- Q( Q  [' U' i  T& ~) e5 H+ B  Normal zone: 1008 pages used for memmap
% d9 ~0 I# B* z: e+ h- T  Normal zone: 128016 pages, LIFO batch:31
7 H) K0 Z9 `; `# v  HighMem zone: 528 pages used for memmap' k! Q4 L9 R9 q$ P& m
  HighMem zone: 67056 pages, LIFO batch:157 v. I7 T# T) ^) a, ^) {% Y/ J
. {7 ^5 a5 S2 Q1 C- {) p% vpcpu-alloc: s7616 r8192 d12864 u32768 alloc=8*4096
7 r  o5 h" B) c2 F' ?! Epcpu-alloc: [0] 0 [0] 1
' J; v. R4 F! Y( z& ?9 VBuilt 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096- G0 U" F' }( g* ^
Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p2 loglevel=8 panic=10 console=tty0 hdmi.audio=EDID:0 disp.screen0_output_mode=EDID:1280x720p50 rootwait panic=10 rootfstype=ext4 rootflags=discard) U: }) q; O" U
. G3 o+ v+ y4 u9 qDentry cache hash table entries: 131072 (order: 7, 524288 bytes)0 I' @% @/ h) Z  P& T
/ t/ K  ^" C7 X5 j# |7 ]allocated 2097152 bytes of page_cgroup+ w( w3 V3 ?5 r$ y* N  R
2 P4 M! M+ P8 g& [  {/ L% sMemory: 1024MB = 1024MB total
  @9 M  E$ [$ n, RMemory: 780420k/780420k available, 268156k reserved, 270336K highmem
! x/ m- j: u& T  Q7 f0 xVirtual kernel memory layout:
) l1 ^$ V- K  r% `) }    vector  : 0xffff0000 - 0xffff1000   (   4 kB); C% G' V  m! \
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)" N2 d/ g, {; x* R% {- H! s
$ @3 g1 h7 S. z' q# N4 v& ]! S    lowmem  : 0xc0000000 - 0xef800000   ( 760 MB): ?. H/ r+ ?0 O. x) c
* T. B! G$ p6 m8 Y. m    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
2 N0 c" _( \$ C      .text : 0xc0008000 - 0xc0818000   (8256 kB)
% a$ S% b& T0 w( K; t" g* }      .init : 0xc0818000 - 0xc084edc0   ( 220 kB)' O5 h1 G" w4 y% [7 B1 ~- A: @
      .data : 0xc0850000 - 0xc08bd058   ( 437 kB)5 O2 L. C: d5 e, ^7 A5 w
6 ^. n0 X4 x: Y! C& U* Z1 dSLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
- U1 `2 F2 p; s) PPreemptible hierarchical RCU implementation.7 t8 o# h/ K! o2 ?" U' h1 d3 S5 s
        RCU dyntick-idle grace-period acceleration is enabled.: H) i/ t6 U( \1 M7 m
        Additional per-CPU info printed with stalls.. R0 c6 ~: y( u
NR_IRQS:192! ~& h4 d  Y$ x. `# Y
Architected local timer running at 24.00MHz." d% f6 |0 O6 z/ T" y
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms' N4 i& c  H$ ?6 g' ?& n$ ^
: D! V, q8 M+ r  ~9 [# w. jConsole: colour dummy device 80x30
8 v& p- M2 @* Uconsole [tty0] enabled9 Y) `( x* f/ t$ Z
Calibrating delay loop... 1915.28 BogoMIPS (lpj=9576448)) p8 z4 J5 L5 F5 |! a- @2 o
  d+ T) q0 o' J; V+ NMount-cache hash table entries: 512# w4 I1 I* t. Q# }" F
Initializing cgroup subsys cpuacct; i# J' L' d/ _- y* M8 o$ C
. Q2 H8 O9 d& {2 T2 @* v+ G7 MInitializing cgroup subsys devices
- T' l$ j/ u6 E/ B9 CInitializing cgroup subsys freezer
3 g% y1 |1 k4 g% V1 k- HInitializing cgroup subsys blkio
, @; b/ J6 u* O9 a: t9 J, QInitializing cgroup subsys perf_event  R( G( m% e' B" i; V& y& R
CPU: Testing write buffer coherency: ok& E7 q. c8 d- T7 `
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000/ j. N( x+ }& x/ m, g2 G. v
hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available6 G$ ~& U0 Y7 r1 V6 S. o: o
Setting up static identity map for 0x405c8da8 - 0x405c8e00- C* @- o0 T  B5 t: c1 R% G) n
CPU1: Booted secondary processor/ a* {  E% J* I1 B" _" B' \
" r( Q7 N/ L5 N. u) jBrought up 2 CPUs
" J  G! {9 B4 M0 x7 I+ O# ]+ {, mSMP: Total of 2 processors activated (3830.57 BogoMIPS).
6 L) o, C7 U( [  g  pdevtmpfs: initialized
' Q2 w: }: J+ @/ J! B2 K) g8 Ydummy:
5 Q6 r1 U- G2 n0 J1 nNET: Registered protocol family 16
5 V) U/ P* {3 c! _, H7 w5 xDMA: preallocated 256 KiB pool for atomic coherent allocations
% J# f. O% [& K: m: H4 Qhw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.5 ]" B: k) u! o3 n7 h3 J! l
7 X2 n& q0 `; `! c- E[ccu-inf] aw clock manager init$ z8 D  c9 c! ~" |* H
2 C+ U8 y, w- \) G- K. H[ccu-inf] script config pll3 to 297MHz
: }3 I. D/ X: V[ccu-inf] script config pll4 to 300MHz* f) w/ X1 A& Y. a) m6 S
1 b: W8 ]0 j+ y- C! l+ x[ccu-inf] script config pll7 to 297MHz: j5 h. {* F# ]0 u* F% c) Z) s& c
, ^) N+ q1 L, R' H( OInit eGon pin module V2.0, U7 k8 }' Y7 b2 i
bio: create slab <bio-0> at 0, ^& [( t$ ]2 k' J, }0 ?5 P* ^: u% \
SCSI subsystem initialized  V) m- o) h/ L9 V- I
8 B7 X6 u) p- Vusbcore: registered new interface driver usbfs
0 t7 I8 q# t5 ^9 O2 Jusbcore: registered new interface driver hub
/ h3 K' H) R6 p: ]usbcore: registered new device driver usb
& ~$ V9 z* r7 J  ?( s' dLinux media interface: v0.10
( b* d  M& y( s0 B* v+ k' ^Linux video capture interface: v2.00
  m+ D- S  ?8 j, k' x" gAdvanced Linux Sound Architecture Driver Version 1.0.25.. u: F" i7 {0 H
cfg80211: Calling CRDA to update world regulatory domain5 v  `4 [8 ^, f1 s+ B0 B0 [( g/ V
Switching to clocksource arch_sys_counter
6 d# W/ ^- Q& q7 U6 P' \% FFS-Cache: Loaded* R5 f: G* H6 h& y, b' l
CacheFiles: Loaded
# ^( U- W, ~. ~$ s* ^5 N2 ?[usb_manager]: CONFIG_USB_SW_SUNXI_USB0_OTG7 F/ C  E! Q/ w, i$ v
[sw_hcd0]: usb host driver initialize........& @4 n2 S( I# J
/ z, f: O- Y* T. ^1 L, v[sw_hcd0]: host_init_state = 1# O; `1 ]5 _% j) h1 ]+ s
[sw_hcd0]: platform is usb host% u0 w* Y! Q& a/ R* b) w2 B
9 D2 N# c* q/ u- O  S8 H[sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
- P9 n; ]7 F: D7 p+ `$ W# ~sw_hcd_host0 sw_hcd_host0: sw_hcd host driver  ]4 F( L( C) r; E% ?; n
8 j: X. O4 K& _0 U9 G  @1 M) ~# ghub 1-0:1.0: USB hub found
( H2 C0 c3 [  \* @hub 1-0:1.0: 1 port detected
4 ]  N+ s: y- ]2 ~7 Uwrn: hcd is not enable, need not start hcd
* A. M% U6 t3 s[sw_hcd0]: sw_usb_host0_disable start6 B! ^) B$ P: x4 d; J. D
-------sw_hcd0_soft_disconnect---------' k: ]+ q1 Y/ l9 d9 F" M, k) `' E
3 u; c) y4 p1 P[sw_hcd_host0]: Set USB Power Off
! D6 v# ?/ t5 n; v9 C- C6 J+ @wrn: hcd is not enable, need not stop hcd! O4 L3 {1 b. C7 {) b* @
[sw_hcd0]: close_usb_clock. |- h) f, }' S
, o& r( k) t4 m2 a8 l[sw_udc]: udc_init: version 200804118 A: _! e8 a- C- b! @
NET: Registered protocol family 26 \+ t3 Q/ }# Y) k; O5 i7 h# L1 V( t! X
4 d! y9 v5 s9 A$ k. OTCP established hash table entries: 131072 (order: 8, 1048576 bytes); Z9 a' Y3 C. ^7 c
5 Q: j; w; |  G2 `* J- c% A! `7 @TCP: Hash tables configured (established 131072 bind 65536)  y* |, v: Z5 M8 J/ B0 }4 l
TCP: reno registered) U8 v. F/ [7 l3 V) X; D* y
/ F$ k. o1 }/ E( U7 H2 E" u9 G9 hUDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  [2 K6 Y& D) j6 Z  s) v" eNET: Registered protocol family 1
& \( r1 l2 E: g' r4 n$ tRPC: Registered named UNIX socket transport module.. z, w  ~, p; j( }& E% G. V0 \
  T3 [. _0 q7 g1 Y2 i7 TRPC: Registered tcp transport module.! W# e0 g! ~8 |4 d
RPC: Registered tcp NFSv4.1 backchannel transport module.# ^4 I4 j  S0 |5 T( b
4 g+ I* N1 n) p( o7 Q7 V4 z: s& Ntype=2000 audit(0.600:1): initialized2 h; E/ M/ @, J
highmem bounce pool size: 64 pages/ {2 a3 O* U2 n$ A% n& ]
$ v6 i  W& r+ ^% t! h+ h: ~Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
- a; x" H/ c) _* Q% L3 `NFS: Registering the id_resolver key type
0 @  `: ~6 _& H/ ^# BNTFS driver 2.1.30 [Flags: R/W].3 ?, L0 c5 y7 o$ t  W
: [) c: k# h6 ], ]msgmni has been set to 1380
2 R: L# a7 k) s6 v( lalg: comp: Compression test 1 failed for lzo-generic: output len = 57* |' J+ L+ {' ?, K1 Y
1 @4 y! @* ~/ u6 c" n, W$ A0 vBlock layer SCSI generic (bsg) driver version 0.4 loaded (major 252)! W% o0 c7 e' K7 A) H
. U. ~- U/ T8 S" N. a$ dio scheduler deadline registered
% s3 P: r( A5 k# i6 Nio scheduler cfq registered (default)( Y9 H8 P# ]4 m! Z3 ^
) b2 F+ b% [: T% s8 {Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled  ~% j2 J: b# X+ L$ W, O
8 [! W+ O7 B$ a1 [7 d[uart]: serial probe 0 irq 33 mapbase 0x01c280000 N/ M' D) r5 _2 E" K
8 _- y" N4 z7 X0 l' U7 L<6>console [ttyS0] enabled5 {9 I" c1 b' n% R8 X
console [ttyS0] enabled- j$ I2 D' R* Y2 _9 ~( v4 F+ X
<7>G2D: drv_g2d_init
. G4 g* T' |7 R, H2 vG2D: drv_g2d_init8 F& A: O5 x7 @* @4 H3 @% {
<6>G2D: g2dmem: g2d_start=50000000, g2d_size=1000000
  Q# n0 k7 F- WG2D: g2dmem: g2d_start=50000000, g2d_size=1000000) j0 b! I% O) ~" \* {" `
<6>G2D: head:d0000000,tail:d1000000
! J* k1 s: E( G7 f1 r, XG2D: head:d0000000,tail:d1000000
. ]# k! }/ y) Y6 N<6>G2D: Module initialized.major:2503 j; V7 N; `& A8 T
* _/ V3 V5 A  o<6>brd: module loaded
9 n5 e( i6 N; B8 v, o$ m7 vbrd: module loaded1 `# i6 M5 A/ k+ K
<6>loop: module loaded2 w( X/ r4 ^0 ?
loop: module loaded
# W8 p. Z2 e: T4 U! o2 @" wnand driver is disabled
; ~2 K) j0 U% `/ mnand driver is disabled
9 A2 K0 c! D- B9 j3 k# T4 J<6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
% u( ^: V: H5 ^7 Dsw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP) _6 x: ]0 Y$ o+ b
<4>sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1# g$ j8 c/ H( Q. \
! B& [5 Y  n5 J6 }& X, p<6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode" S; J: h& ^1 e0 |; k! k! `! {
0 s: I$ t7 _& V" L1 x0 \$ k8 a/ g<6>sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc 6 ~$ t- K$ k" s
& {' T+ Q- M/ O7 S$ w; @" q<6>scsi0 : sw_ahci_platform
; t2 S( k' j* p* i, T) \% Vscsi0 : sw_ahci_platform
/ `) \( k; Y* {; f<6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88. D9 [+ s; i! g; u) S; y8 T. v
ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88) ~/ w4 \* S: |
<6>sunxi_emac Using mii phy on PortA
7 H9 A) p0 E4 `( v5 Nsunxi_emac Using mii phy on PortA
1 @+ _, u5 j7 l+ Q: h& n! ?<6>sunxi_emac Using MAC from SID: 02:cb:03:41:71:2bsunxi_emac Using MAC from SID: 02:cb:03:41:71:2b<4>emac_init fetch emac using configuration failed
# K( k& v1 W& s; o- [
1 b5 f; ]" K. r: P5 U- e$ uemac_init fetch emac using configuration failed
& Q( r- n( C2 a<6>gmac driver is disabled0 y5 k& j7 P! B+ D7 |
gmac driver is disabled+ i; q- T8 M( V; T2 B$ l- |
<6>PPP generic driver version 2.4.2+ D+ ~: C2 H* N6 d$ V
% L/ q2 ^, g$ N- ~<6>PPP BSD Compression module registered( u! g2 [$ z' V0 N/ r1 y6 e0 x
PPP BSD Compression module registered: \% F  T' t" j" u/ \/ a
<6>PPP Deflate Compression module registered
8 |/ f, V/ \' Q# \1 d. OPPP Deflate Compression module registered
2 H7 w  ~- ^  v<6>PPP MPPE Compression module registered7 Y/ c4 ?! L+ w9 q
PPP MPPE Compression module registered$ Z4 A1 ~( R& E! V" e7 o
<6>NET: Registered protocol family 24
, S+ h, ]7 r8 M' f1 d3 [6 fNET: Registered protocol family 24
4 F  k& f; I4 u( X! M<6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver" G0 s2 p+ z3 X: _+ C; `$ l1 Q
# [5 p6 a+ \4 E$ _( u# u: N; e<6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver, ^; W( R3 m5 E
' u* t$ {0 ~% b1 x$ z- v( u3 R8 u[sw-ehci1]: open clock
% A+ O' e7 p0 N* s$ |% h! b( Q[sw-ehci1]: open clock3 Z+ K% U1 y2 c. X
[sw-ehci1]: Set USB Power ON1 i3 _' n; g+ F' k4 l  g
[sw-ehci1]: Set USB Power ON) x9 k$ _% ?% T( g
<6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
! E' e8 W* `$ f2 N" R2 p; W8 o$ nsw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver4 K6 M# W. h+ a0 K. e( U5 Q
<6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
; `. a& A6 }, n) [sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
3 I/ r# r: C  H* w4 n- I3 t0 |<6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
. d: C4 F& U' B3 Q3 Z, ^& Rsw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
" w: a; r1 r* E0 F6 U1 r<6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
% c2 ^$ I6 @8 esw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.004 |4 I) N" n( _
<6>hub 2-0:1.0: USB hub found9 n: l% m+ H% o" g" I4 t
hub 2-0:1.0: USB hub found* ^, \2 R& G" O4 l) W' r$ r( b
<6>hub 2-0:1.0: 1 port detected
0 t4 _% F. C0 b0 vhub 2-0:1.0: 1 port detected
$ V! i" B( f( x! f; D[sw-ohci1]: open clock! R! I  j  e. m+ `; x( `0 v/ L
3 [4 W8 l! H% M$ F7 \$ M<6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver9 t& d2 A) p* n" |9 g
sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver0 a" K+ f1 \9 Y7 T1 O+ M) @* n
<6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
7 n1 |4 i5 X9 v% k) Xsw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3# m) }: c4 M# H3 m/ x8 s
<6>sw-ohc+ Y* x, E9 d% c: }/ T5 r/ U3 z) @
U-Boot SPL 2014.04-10734-gfec9bf7-dirty (Jun 29 2018 - 09:49:10)
; f; w( r$ v7 XBoard: MarsBoard_A20
( B+ |! H! H, t9 o8 `DRAM: 1024 MiB
, K3 i8 M5 G( n5 |CPU: 960000000Hz, AXI/AHB/APB: 3/2/26 ^8 e, u+ H8 |) O. ]& X
auto detect MMC0 or MMC2 boot9 n9 c/ m9 K4 D1 t: f, ]* e! w
MMC0 card boot
4 o3 I" l: d  {2 }/ a* B' v5 Xspl: not an uImage at 16006 o( E0 n/ n: x5 l; O& v
  E6 j0 ~% f8 G. s3 |+ \( G/ A7 F+ A, \/ Y% }/ E
U-Boot 2014.04-10734-gfec9bf7-dirty (Jun 29 2018 - 09:49:10) Allwinner Technology
' ?7 ]5 l3 A7 t5 y) k  T1 B1 s) [
/ {8 N6 _) X$ k& ?CPU:   Allwinner A20 (SUN7I)
; |( ]( T$ _5 E1 K0 }# GBoard: MarsBoard_A20
4 ]+ H4 r5 O3 j! XI2C:   ready
7 T: [! ~9 r4 I0 b2 iDRAM:  1 GiB
! `" S' J2 T7 H  wMMC:   auto detect MMC0 or MMC2 boot! [5 K7 s8 \) B7 {8 B
MMC0 card boot
% p! O6 W6 l+ l' O$ LSUNXI SD/MMC: 0: w# g( X8 D9 \2 P& j( s1 b6 p
*** Warning - bad CRC, using default environment
% ]. o5 H1 l0 L9 m2 W7 j& a: m) R1 \
In:    serial
4 R3 R' W0 k! D  oOut:   serial; \" ]% ^& Z$ C# X& P& e
Err:   serial
$ z( C4 [7 }' H) PNet:   dwmac.1c500005 r- s( o9 {% {( X$ e
Hit any key to stop autoboot:  0 ; g  E/ Z: d- K+ j' u
reading uEnv.txt
/ W" T( q! v% H# {3 \4 v- S' o9 C155 bytes read in 17 ms (8.8 KiB/s)8 q" a, I. D  r: D
/ ?/ l& z+ {3 a& O) F7 Dreading boot.scr
( t& \( o. x" o  N! o( w9 F** Unable to read file boot.scr **
: ~+ i5 V; F1 ?Failed to mount ext2 filesystem...9 k' B$ \+ T) `
8 g& j. [4 g& _Failed to mount ext2 filesystem...
, @- j9 m, J+ V( m4 b** Unrecognized filesystem type **
5 u6 \6 z2 x! Z& d6 xFailed to mount ext2 filesystem...
. G% d& o- c- x2 R7 W) S; F** Unrecognized filesystem type **; E1 j; K  R) g  g$ f' p9 l+ x: R
reading script.bin4 z8 S0 u1 E: h, p! z
46576 bytes read in 30 ms (1.5 MiB/s)2 C& N$ ]) p! r% R7 i1 C4 O
reading uImage
8 V  _( _* p" o' F( s4600424 bytes read in 234 ms (18.7 MiB/s)
; @0 \- J( l  F0 K4 f( Y- ~# W0 `## Booting kernel from Legacy Image at 48000000 ..." |; d; L* T1 c, n9 g
/ p% r) j2 S3 w2 J   Image Type:   ARM Linux Kernel Image (uncompressed)  u! C* G) i" f4 }3 v6 M# H% |
+ h) c( L, v% [% e   Load Address: 40008000
/ \$ D1 }. `2 L) r& W2 F% h   Entry Point:  40008000
3 N: r5 F8 K+ Q$ ]   Verifying Checksum ... OK
7 r( d; H. r' a; f/ _" g" z   Loading Kernel Image ... OK1 l* K. `) `2 \, }; a9 e
8 \& A( O; X% S* Y1 \, {Starting kernel ...
6 F3 Q4 Y: ~& l4 R  x, V4 `/ k. y: i0 g# `9 ]1 P
* |8 F6 G/ I2 W! B6 e+ t$ U<6>Initializing cgroup subsys cpuset$ E, ]& ]" I8 T$ `) }# J$ M& j
GMT+8, 2025-10-26 02:18 , Processed in 0.171875 second(s), 23 queries , Gzip On.
