第三讲
0 P) p( K1 k! b( w' k. b( `7 W
4 [& T! ^' k% V8 W2D场求借器--用来求传输线的RLGC距阵模型,s 参数等....0 H* v( d7 N" X9 \
以下的例子为求单根微带线的RLGC模型。
* n4 r# n( s- H9 K$ u3 @' ?------------------------------------------------------------------------------------------网表如下:. P$ P0 M# ^5 ]& d T; F) \6 y+ x
*Micro Stripline
; C0 [3 S. v4 x( t& Z5 v: A*Stripline.sp : caluclate Micro stripline's s parament&rlgc model[*.s4p&*.rlgc]
7 r% S1 q, S1 z, M+ c3 Q9 Y*created by Li Liming5 ]) \4 z3 i5 m. q* P" P
: w+ Q& r& q/ L' O% k; X' [5 ]* Material FR-4 单微带线截面图。2 C- f3 n7 M# |( H' X) z
* Stack layer. M! p, o9 _9 W2 }+ `# ?) [0 j% P
*////////////////Width//////////////////Thickness
" }& \! F# M# I5 {6 u! P*///////////////////////////////////////dHeight9 A( U% e- T. o! H& L$ j+ P1 o
*---------------------------------------Thickness0 Q. ~$ {" M" [( B, W; Y+ g" t3 U" v
****************************************************** ]; W; {! R1 ?
.param dHeight=8mil
& E+ f4 Q0 q( d, Y5 y3 z.param Width =5mil5 }; X+ v& L/ ]$ Z6 X
.param Thickness=1.2mil
# Q' ^, p% s3 F% W7 L.param Length=5000mil, Q) i9 L7 m3 _! n: w
5 s7 d7 o+ L' S- L- q1 M; S*******信号源*******
# G9 z O1 A9 P/ v5 \6 G. Q' |vimpulse in 0 pulse (1.8v 0v 0ps 25ps 25ps 450ps)
. q o! y3 }: ~1 Q; _wline in 0 out 0 fsmodel=strip N=1 l=Length9 _8 X @, j+ A6 l
. H$ I! Z( k; K# i& O P' Y# L*******定义2种材料*******' v7 C( t, A$ I/ e
.material die dielectric er=4.3 losstangent=0.017; u% W% E6 r: _; _) l
.material copper metal conductivity=57.6meg
8 @- {* Q9 O8 b4 [* A9 q; l) O+ A7 |' G |2 l. [0 u
*******定义走线的参数,如形状,长度,厚度*******( d: S ~/ z! r8 u k9 N4 ]) o4 ]
.shape trace rectangle width=Width height=Thickness
% g! I4 ^: B7 L/ v5 ^& ?: R
$ \4 t# A% I3 |# ]*******定义层叠, 注意层叠是从下往上的。*******
( q0 j% G- Y1 ^9 h& v4 _.layerstack stack
- z2 z- r% u; U$ \" J% @+layer=(copper,Thickness) layer=(die,dHeight) 4 i q! V& K4 M
/ ~. J Y N# u1 Q- Q*******定义仿真精度,格点,输出数据,计算类型*******
# P1 \; e% q1 ]9 i+ q$ P t.fsoptions myOption printdata=yes computeg0=yes computegd=yes computer0=yes - {+ `; a, U1 u7 P4 K
+ACCURACY = LOW GRIDFACTOR = 1% t/ {) w. N9 t, V( X* X0 T+ h% |
( x& C# U- T3 {) m7 e
*******定义扫描过程*******
; e8 u; A' g/ {. _0 @4 e* j1 Y.model strip w modeltype=fieldsolver
; v4 l5 ]- r' \0 h, i1 c' l* z+layerstack=stack
$ g8 M$ I/ { B5 h$ b: F+fsoptions=myOption
% N) o) `* |" m; P- V g+ O! v: L+rlgcfile=micro_stripline.rlgc8 c( r$ v0 m! v5 J
+outputformat=rlgcfile: v, O% O7 F/ O1 }+ e
# f/ F( w+ H. w. d2 p******把导体放置在平面上,用如下坐标定义他们的位置*********
`! O" g, Z3 h7 C1 }. D+ g1 H5 G+ X2 g+conductor=(shape=trace origin=(0mil,'dHeight+Thickness') material=copper type=signal)
4 @1 j1 R+ ^0 p$ b8 J
5 Y/ w, i+ s/ s. g9 ^* |*******分析类型*******0 f6 D1 B# L8 d8 m
.tran 0.5ns 100ns2 F8 S1 Q5 Q, r: }
. S( J% Z# s& T3 J; H2 y0 O6 e
.end
j$ A# U; X k* ^; z* y0 v, d5 f8 X----------------------------------
7 N8 s3 [9 j" d3 w3 e# ^
2 C3 t3 `# ?; k i, j# g1 B运行成功后会在当前目录下生成micro_stripline.rlgc文件,供仿真案例调用。
5 U1 \& s% F4 q2 Y0 i, T1 w6 E! f4 Z! g$ r
2.波形图. l, ~6 i. w( K% Y
' X2 _ |- m$ X' i9 Y$ f
