查看: 995|回复: 0
ALLEGRO 导入网表问题,帮忙看看
发表于 2010-5-26 17:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
------ Directives ------3 k3 Z: J& n# L' d
RIPUP_ETCH TRUE;
2 z* z5 b" D- K) O+ M4 MRIPUP_SYMBOLS ALWAYS;' i) b/ W' U8 l5 K2 N9 i& ^
Missing symbol has error FALSE;
* ?8 x0 @1 ^" O' s/ W8 zSCHEMATIC_DIRECTORY 'E:/DM355PIII/allegro';
: R8 G( ~: N& FBOARD_DIRECTORY '';
. C+ j4 C, U9 W1 sOLD_BOARD_NAME 'E:/DM355PIII/DM355.brd';5 n# Y8 N3 X& j
NEW_BOARD_NAME 'E:/DM355PIII/DM355.brd';6 K8 O7 e& E+ s/ E
CmdLine: netrev -$ -i E:/DM355PIII/allegro -x -u -t -y 1 -z E:/DM355PIII/#Taaaaaa01532.tmp6 l# W$ O* w! p) q. B
------ Preparing to read pst files ------4 h1 J# i& E* |: x
Starting to read E:/DM355PIII/allegro/pstchip.dat % s( D# K: W: ~2 S6 Y. `' Y
   Finished reading E:/DM355PIII/allegro/pstchip.dat (00:00:00.32)
( X' Z! U4 K6 Y2 hStarting to read E:/DM355PIII/allegro/pstxprt.dat
" Z7 n0 ]0 T' [# H   Finished reading E:/DM355PIII/allegro/pstxprt.dat (00:00:00.04)
0 Q! d# [! N) X4 w/ I1 G8 t% f1 `Starting to read E:/DM355PIII/allegro/pstxnet.dat
& N  {0 O; h* ?: I6 S3 t9 v   Finished reading E:/DM355PIII/allegro/pstxnet.dat (00:00:00.04)
$ S  y  t# I" R! t3 G0 z------ Oversights/Warnings/Errors ------
1 j' \2 m/ v' a* p( i" U
  @& W. ?6 H: N9 i#1   Run stopped because errors were detected
! m& ?6 S+ G8 W! r9 W( Cnetrev run on May 26 17:28:24 2010
1 e( u" g) a; B   DESIGN NAME : 'DM355-PI'8 D3 o: n! D' b3 b0 U; Z6 j8 [# |& x
   PACKAGING ON Sep 28 2008 21:55:15
+ w7 j% f( P8 Y% e* b   COMPILE 'logic'
( e+ W# }+ N7 |7 D   CHECK_PIN_NAMES OFF
8 k* o; P0 x, f8 ?( H" R. M) s   CROSS_REFERENCE OFF5 k3 n. I  z/ m" _0 c0 x
   FEEDBACK OFF
! Q0 {7 c+ t  A, s9 k3 c   INCREMENTAL OFF
$ \' O- S8 O$ c6 M8 j7 S, N   INTERFACE_TYPE PHYSICAL
9 v3 P/ M/ f6 `   MAX_ERRORS 500
7 b, R9 x4 O$ J, }4 e8 K+ N% P   MERGE_MINIMUM 59 Y, }0 H) p9 b1 _# C/ u: C1 [' o
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
- v% S  t9 r; q3 p- ~5 i$ c" H   NET_NAME_LENGTH 24
7 X, s) [: V0 e3 V8 T! B   OVERSIGHTS ON. J6 ]4 D% `- i2 h
   REPLACE_CHECK OFF1 X* h9 B6 t' m  s! y% U& p: A
   SINGLE_NODE_NETS ON/ m& R/ L$ z8 S6 v% X, n  Y% Y2 a7 B
   SPLIT_MINIMUM 0
2 v3 m5 v  s  \# R. o) ]! ^" J   SUPPRESS   20
9 s2 Z. H( t) g' t0 h( I6 ^   WARNINGS ON  j5 ?+ G8 P" p+ u( Q- C) g
  1 errors detected8 Q( Y  I4 L3 Z6 \
No oversight detected
4 s) [: h+ T) W* i# g No warning detected
1 D4 j# R! P7 R' Z' A8 h& Kcpu time      0:15:21
) ]2 O4 l, Z. _/ W' Belapsed time  0:00:08
GMT+8, 2025-8-19 17:20 , Processed in 0.125000 second(s), 24 queries , Gzip On.
