查看: 6968|回复: 3
请教各位,现使用16.2 ALLGRO出现网表错误,请高手解决,谢谢!
发表于 2010-5-21 16:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
netrev 16.2 Fri May 21 15:48:01 2010
* H4 s+ h; j. \: S& ~  r. Zcadence Design Systems, Inc.2 X" x) f- V1 r0 ?8 N
------ Directives ------: [8 |" G* b9 k: f' v3 @/ {
RIPUP_ETCH FALSE;
) e2 H8 |, |' DRIPUP_SYMBOLS ALWAYS;
: n8 t, y* ?7 }8 ]4 ZMissing symbol has error FALSE;
, _" F: p3 a% q( U) k" @9 qSCHEMATIC_DIRECTORY 'I:/W/allegro';) V+ x& B0 i9 B7 g' V( c7 d( _+ V" r
BOARD_DIRECTORY '';
1 l. {' q$ {6 F9 P& i! \4 A$ COLD_BOARD_NAME 'I:/W/KT7004orKT7008-V2.0.brd';3 ~7 t) T! n) e" `$ Y1 d$ C: y: I
NEW_BOARD_NAME 'I:/W/KT7004orKT7008-V2.0.brd';9 E, R( X2 [: X0 w7 c' J2 N
CmdLine: netrev -$ -i I:/W/allegro -y 1 -z I:/W/#Taaaaaa03056.tmp/ I$ k. E6 a" x. Z% }9 b/ c! z
------ Preparing to read pst files ------6 \- w( C2 Y: T. i0 V5 N+ K9 \
Starting to read I:/W/allegro/pstchip.dat
% D; L6 e$ Y# M* F   Finished reading I:/W/allegro/pstchip.dat (00:00:00.12), D0 A9 l$ [5 W' v% k
Starting to read I:/W/allegro/pstxprt.dat
0 f$ y8 P' I* v, X) ~) \+ Z   Finished reading I:/W/allegro/pstxprt.dat (00:00:00.04)! O0 {% T0 v" u1 U. s+ p
Starting to read I:/W/allegro/pstxnet.dat . Z% ?$ B; Q( G% K  F
   Finished reading I:/W/allegro/pstxnet.dat (00:00:00.04)
9 x8 a3 ~; W- e# ^" F------ Oversights/Warnings/Errors ------) R1 [' e7 B+ t
9 y4 s5 m* k& z# `- H" a1 U#1   ERROR(SPMHNI-176): Device library error detected.: q9 M: k  ]- Z
ERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-6K985%-LT'. Package property error: 'VALUE'='RC0603-6K98±5%-LT'. Illegal character(s) present in the name or value..4 b  y# I1 i; q* p
ERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-6K985%-LT' has library errors. Unable to transfer to Allegro.$ t; W9 [& L3 W' R
#2   ERROR(SPMHNI-176): Device library error detected.
) F3 I. A( `1 c7 PERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-5.1K1%-LT'. Package property error: 'VALUE'='RC0603-5.1K±1%-LT'. Illegal character(s) present in the name or value..
; i' c# d3 J) G3 F: o  g1 oERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-5.1K1%-LT' has library errors. Unable to transfer to Allegro./ R5 o# I! P6 h! c
#3   ERROR(SPMHNI-176): Device library error detected.
( r9 x! ?" }3 t9 d4 ~2 H- ?. xERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-24K31%-LT'. Package property error: 'VALUE'='RC0603-24K3±1%-LT'. Illegal character(s) present in the name or value..
% }7 Q/ O8 X: [# M. V: l) `- a- [& g) s5 LERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-24K31%-LT' has library errors. Unable to transfer to Allegro.1 A8 {8 W. X0 H
#4   ERROR(SPMHNI-176): Device library error detected." N4 ~) e- W; M2 F' Q9 E
ERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-4K421%-LT'. Package property error: 'VALUE'='RC0603-4K42±1%-LT'. Illegal character(s) present in the name or value..0 ]; ~" O1 P- |5 ?; Q1 u1 t6 i
ERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-4K421%-LT' has library errors. Unable to transfer to Allegro.
$ q! [5 j, b3 ?#5   ERROR(SPMHNI-176): Device library error detected.: r  \: W$ L$ T/ S
ERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-4K221%-LT'. Package property error: 'VALUE'='RC0603-4K22±1%-LT'. Illegal character(s) present in the name or value.., v: G. C% K+ m$ |' r
ERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-4K221%-LT' has library errors. Unable to transfer to Allegro.$ B* H$ \. e8 w3 n) x+ q
#6   ERROR(SPMHNI-176): Device library error detected." B  L$ {* U2 b. {0 J6 ^
ERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-3K151%-NT'. Package property error: 'VALUE'='RC0603-3K15±1%-NT'. Illegal character(s) present in the name or value..
5 U. X0 f) O( O+ B5 EERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-3K151%-NT' has library errors. Unable to transfer to Allegro.
. q' d9 g9 r# i0 Q5 F- v1 f- s#7   ERROR(SPMHNI-176): Device library error detected.
+ d; N, ^  ]$ S) xERROR(SPMHNI-190): Device problem 'R-0603_R0603_RC0603-100K1%-LT'. Package property error: 'VALUE'='RC0603-100K±1%-LT'. Illegal character(s) present in the name or value..: r: c# u1 ]/ \+ X; b
ERROR(SPMHNI-170): Device 'R-0603_R0603_RC0603-100K1%-LT' has library errors. Unable to transfer to Allegro.
6 P7 N' P/ ?1 H3 G$ Y#8   ERROR(SPMHNI-176): Device library error detected.
: B6 w6 g9 Z4 r3 BERROR(SPMHNI-190): Device problem 'R_R0603_RC0603-10K1%-LT'. Package property error: 'VALUE'='RC0603-10K±1%-LT'. Illegal character(s) present in the name or value..
) g: \6 i) F: z% M# H* s1 G: n6 ]4 BERROR(SPMHNI-170): Device 'R_R0603_RC0603-10K1%-LT' has library errors. Unable to transfer to Allegro.8 D9 m7 t# x* Z4 r! R# o
#9   ERROR(SPMHNI-176): Device library error detected.9 J, d5 d' y/ \: `8 K) W1 t
ERROR(SPMHNI-190): Device problem 'INDUCTOR_L0805_RC0805-0R5-L'. Package property error: 'VALUE'='RC0805-0R±5%-LT'. Illegal character(s) present in the name or value..
4 |& G2 m- M9 v' o* Z) d- ~$ TERROR(SPMHNI-170): Device 'INDUCTOR_L0805_RC0805-0R5-L' has library errors. Unable to transfer to Allegro.
8 c) c/ g* [7 q#10  ERROR(SPMHNI-176): Device library error detected./ M. c7 W1 n9 X  a1 Z0 N# ?- i' Y% K
ERROR(SPMHNI-190): Device problem 'C0805_C0805_CT0805-X7R-4.7UF\16'. Package property error: 'VALUE'='CT0805-X7R-4.7uF\16V-20%~+80%-NT'. Illegal character(s) present in the name or value..
6 X4 [; q4 Q7 n& ~# ]ERROR(SPMHNI-170): Device 'C0805_C0805_CT0805-X7R-4.7UF\16' has library errors. Unable to transfer to Allegro.
6 {3 t! G8 F5 ^3 [4 u#11  ERROR(SPMHNI-176): Device library error detected.
+ |! [# |% V4 {$ T! JERROR(SPMHNI-190): Device problem '0805C_C0805_CT0805-X7R-2.2UF\25'. Package property error: 'VALUE'='CT0805-X7R-2.2uF\25V-20%~+80%-NT'. Illegal character(s) present in the name or value..; e* w) c: A" o' p) |
ERROR(SPMHNI-170): Device '0805C_C0805_CT0805-X7R-2.2UF\25' has library errors. Unable to transfer to Allegro.0 t& e' }7 s) h0 a
#12  ERROR(SPMHNI-176): Device library error detected.
3 b/ w( y& B  lERROR(SPMHNI-190): Device problem 'C1206_C1206_CT1206-X7R-10UF\16V'. Package property error: 'VALUE'='CT1206-X7R-10uF\16V±10%-T'. Illegal character(s) present in the name or value..# |* m2 k  [' O3 H3 v' c. q2 H& a7 K
ERROR(SPMHNI-170): Device 'C1206_C1206_CT1206-X7R-10UF\16V' has library errors. Unable to transfer to Allegro.3 f( m* ?5 a% `! \
#13  ERROR(SPMHNI-176): Device library error detected.
4 _* J- M) n$ m4 H! n, f7 QERROR(SPMHNI-190): Device problem 'CAP6_CAP6_CDP6.35.5-47UF\16V'. Package property error: 'VALUE'='CDP6.3×5.5-47uF\16V±20%-T'. Illegal character(s) present in the name or value..# ~* Z7 M4 Q+ m( b7 [' O# \$ i- x( f- N
ERROR(SPMHNI-170): Device 'CAP6_CAP6_CDP6.35.5-47UF\16V' has library errors. Unable to transfer to Allegro.
# h0 T6 N4 ?+ b" r#14  ERROR(SPMHNI-176): Device library error detected.
' l: H7 o/ C+ HERROR(SPMHNI-190): Device problem 'C_C0603_CT0603-Y5V-2.2UF\10V2'. Package property error: 'VALUE'='CT0603-Y5V-2.2uF\10V-20%~+80%-NT'. Illegal character(s) present in the name or value..6 U! R# n* s; S
ERROR(SPMHNI-170): Device 'C_C0603_CT0603-Y5V-2.2UF\10V2' has library errors. Unable to transfer to Allegro.( R0 s+ a' S7 U
#15  ERROR(SPMHNI-176): Device library error detected.
5 a# ^  o9 }. t3 c; jERROR(SPMHNI-190): Device problem 'CAP6_CAP6_CDP6.35.5-100UF\16V'. Package property error: 'VALUE'='CDP6.3×5.5-100uF\16V±20%-T'. Illegal character(s) present in the name or value..
) Q) |# s. e* r% o' U$ cERROR(SPMHNI-170): Device 'CAP6_CAP6_CDP6.35.5-100UF\16V' has library errors. Unable to transfer to Allegro.
7 f! G* \% [$ M------ Summary Statistics ------
! n$ C4 w" A) b8 ?& X3 o( _% S; D$ Y5 Q" v, p
#16  Run stopped because errors were detected; f8 J. J* A- \5 |5 k
netrev run on May 21 15:48:01 2010
7 k+ f* [6 Q2 j& K/ h5 R5 X   DESIGN NAME : 'KT7004ORKT7008-V2'. H6 B2 F! x! H: u$ @; S
   PACKAGING ON Jan 13 2009 22:23:036 d2 F& H* G! u2 Y* L4 ~; W
   COMPILE 'logic'
7 v* {: q# b" |: d( q   CHECK_PIN_NAMES OFF$ l" k! z: ?) L: ?
   CROSS_REFERENCE OFF
; a9 A1 |& \  Q2 Z: p   FEEDBACK OFF
) l2 N3 F5 n& p: T4 ~) t  }4 g( u   INCREMENTAL OFF3 b) `# u, ?5 k" Q' `
   INTERFACE_TYPE PHYSICAL; ?% s$ r8 f3 x9 y8 n2 f1 \
   MAX_ERRORS 500
8 }- ^# n5 F7 ?. B   MERGE_MINIMUM 5% l, H' m% p" J% }& Z
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'+ k) J/ d9 \2 F) b* ?
   NET_NAME_LENGTH 242 m2 m; A; J2 R! K# e6 c
   OVERSIGHTS ON
7 e6 W# R' r! O3 t7 \3 @4 I   REPLACE_CHECK OFF
; U- k+ L2 p5 J) }0 L# r$ K   SINGLE_NODE_NETS ON
; d' v* {1 F- \# w/ D   SPLIT_MINIMUM 04 \5 s/ H$ r+ i' H- D0 ^
   SUPPRESS   20  O& I$ T" i" }/ W  {# W
   WARNINGS ON' p5 H! o0 e* d/ {  }6 k/ o3 L
16 errors detected
! c+ T( P; j* G2 c. V No oversight detected9 j5 P7 z- U" d9 K2 ~1 x0 J
No warning detected
. q, [( [5 q$ F- u* T" ?1 jcpu time      0:01:46% A* _5 i  U2 I, V7 m9 q0 \- L- X
elapsed time  0:00:00
发表于 2010-5-22 09:47 | 只看该作者
第一条:Device library error detected.莫非是元件库路径设置出问题;
7 u( |1 K4 o* y第二条:Illegal character(s) present in the name or value.莫非是包装属性中的名称或value值中出现了allegro不允许的非法字符。
7 f/ V' \  N. I( q/ |逐个排除之。我是个外行,全靠自学的,不对的话请勿拍砖。嘻嘻。
 楼主| 发表于 2010-5-22 11:29 | 只看该作者
非常感谢分析:
发表于 2010-5-22 14:06 | 只看该作者
基本是确定
GMT+8, 2025-8-19 20:47 , Processed in 0.125000 second(s), 24 queries , Gzip On.
