查看: 569|回复: 0
SI4463-B1B-FMR 无线射频芯片
发表于 2020-4-10 14:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
品牌:SiliconLa
" M8 ?+ Z7 M. m) s批号:20+
封装:QFN20
* Q/ _# A" s# Y8 r4 \6 v9 B
/ C/ Q# N6 O. K( l2 D: N
  • 频率范围 = 119–1050 MHz
  • 接收度= –126 dBm
  • 支持模式
    * m" q  w; {! F7 t) f
    • (G)FSK and 4(G)FSK
    • OOK and ASK
      * l. J  m7 T$ e) J: R
  • **输出功率
    , n5 r! l8 ]% A7 Z
    • +20 dBm (Si4464/63)
    • +16 dBm (Si4461)
    • +13 dBm (Si4460)
      - n) g/ R# V  o* v# x9 C2 Q
  • PA 支持  +27 dBm
  • 低功耗支持
    7 Q8 e7 n2 g6 l2 ]; X
    • 10/13 mA RX
    • 19 mA TX at +10 dBm (Si4460)
      ; b% E  }( N& p9 E$ i. o
  • Ultra low current powerdown modes
    " I) \4 S& E( A. ~, m3 p
    • 30 nA shutdown, 50 nA standby
      ' T5 O$ N6 K) O% q/ C+ u
  • Data rate = 0.123 kbps to 1Mbps
  • Fast wake and hop times
  • Power supply = 1.8 to 3.6 V
  • Excellent selectivity peRFormance
    8 t3 U2 Y  Q; t/ K- M! E
    • 60 dB adjacent channel
      , k% @9 b7 F( g0 L5 \
  • > 73 dB blocking at 1 MHz
  • Antenna diversity and T/R switch control
  • Highly configurable packet handler
  • TX and RX 64 byte FIFOs
  • Auto frequency control (AFC)
  • Automatic gain control (AGC)
  • Low BOM
  • Low Battery Detector
  • Temperature Sensor
  • 20-pin QFN package
  • IEEE 802.15.4g compliant
  • FCC Part 90 Mask D
  • 5 X2 }2 {2 \" e% F1 @* w2 }2 s
/ j  X5 h% Z" C! U% {3 q- M. s
GMT+8, 2025-10-9 21:11 , Processed in 0.156250 second(s), 28 queries , Gzip On.
