根据附件中《Linux系统固化方法》将u-boot和uImage固化到SPI flash中,并且在uboot启动时设置完成环境变量。
( N' z, g$ k: a! Z3 m, U 将DM8168开发板拨码开关设置成SPI启动。
: O! n; l' M; Y7 t打印信息如下:
5 f3 Y% i5 E1 ]OMAP SD/MMC: 0
' V) Y6 `* ^$ a: d$ cCard did not respond to voltage select!
! M9 ^) n6 Z; s: y/ g5 `** Can't read from device 0 **0 H! q- C6 }- c/ Z$ l- s" r
7 {" U( V/ y& |* Y# `% b9 @3 R
+ n* ~7 d/ Z+ E
** Unable to use mmc 0:1 for fatload **
4 I9 x5 v) [5 \& ^** Can't read from device 0 **
, G6 L, \* _ i' H, A, Z
/ y& o) X+ K% i
: {" z, n; ^; S** Unable to use mmc 0:1 for fatload **
2 X% p* x* u6 N+ K# u8 w9 N4 o4 l7 uFaiLED to initialize SPI flash at 0:0
" N. z' r% v/ X0 r" q2 bBooting from network ...
4 e) n, J: s: n, F2 |*** ERROR: `serverip' not set
9 n' \# y7 g3 P: P* v+ \1 bWrong Image Format for bootm command* ?# l6 p# w2 Z& s5 k2 j
ERROR: can't get kernel image!
! ^- M% J# {! t4 ^
7 ~( [. |5 Q# ]# l. H4 _' ~6 m
% r0 q P: s. \) p. t" @请教一下大神,如何解决。
2 b$ O* N. e) H3 j& c: p |
