看一下,我的也是这样,可能是15.2和16.2切换造成的,下次注意一下。& n* d q2 ~; q4 n0 X0 J, x- L8 c/ O
在安装目录下,找到这个文件:prefprop.txt! }; a9 R1 f @- w' l& C
打开它,看一下格式是不是和下面的一样,我的是少了一个括号
, }/ e; _, b( p(PropertyFilters
3 i3 s+ n! W0 _% a4 d9 B (Orcad-Capture$ l- `6 _3 H# Z5 s
(Parts "" "" "" 0
: S2 U0 W' ~6 v3 L; j4 J1 I4 F- c (Value show)0 {7 \" x% R) {
(Reference show)" h9 F$ P7 C$ h: L5 a( |9 _
(Designator show)
* n6 q6 Z$ S. Y. O. u ("PCB Footprint" show)5 h8 T. }+ a+ b- J. P% r
("Power Pins Visible" show)8 Y! O3 i" m- c2 j' y7 H+ R
(Primitive show)0 V* }; ~+ k; @. U9 Y
("Source Library" show)* z( @4 t" F" y. U
("Implementation Type" show)" ^) u4 E5 e" ]2 {
(Implementation show)
5 u* ^! S4 J3 v3 t# _8 B, V ("Implementation Path" show)
' o, Y* s, b, Q' {& R ("Part Reference" hide)). q" x; I6 b& F5 u8 Q* |8 g
("Schematic Nets" "" "" "" 0' a% |4 ]2 o. M0 W2 u
(ID show)
2 G- @, z4 [; C% T. L! s- N; V (Name show))
2 h1 J3 E5 S' J% g0 Y8 L (Pins "" "" "" 0! A! j4 b- \+ W9 G
(Name show)
+ h' Y% B' C% a$ ?9 Q8 Y5 J; d (Number show)
: E7 c3 X0 i( V ("Net Name" show)5 c! k8 W" L3 ^4 l
(Type show); E8 M. v, t) Q" X% W4 l4 J& I
("Is No Connect" show)): Z& d5 ~1 x$ n* M5 m( m3 m. I
("Title Blocks" "" "" 0% N* A. g" M3 k5 n6 I' b
(Title show)
9 a% @# w" s1 x* ?/ U" B. n (Document show)3 V% g' o6 |! T
(OrgName show)" {# v$ {" N6 I# \# [
(OrgAddr1 show)* Y& T2 R# U* r, K, Q7 x' w
(OrgAddr2 show). }" X% O' W2 s& V5 Q
(OrgAddr3 show)6 i! w8 U6 L$ @$ Q- f, q3 _
(OrgAddr4 show)+ t2 u3 y3 Z% V$ e
("Cage Code" optional)
! z3 N: T" Z* W5 n (RevCode show) j j) p% X5 D8 d. h
("Page Number" show)
% {+ d9 p5 d1 U9 z ("Page Count" show)
0 H4 v; v9 g$ S4 x: P9 { ("Page Create Date" show)
4 V) V s, P* d9 x' p8 r ("Page Modify Date" show)
* [* D) o; D: l9 _5 D) ` | ("Schematic Name" show)
2 Q0 s! F! S! [2 @ ("Source Library" show)7 I# m6 Z8 h* Q* V: L6 |+ ^
("Source Symbol" show))
2 q! o: X0 v. A# m& n$ ~& K7 U ("Displayed Properties" "" "" 0
( y" o) ?) y3 i: z0 D( U* T ("Property Name" show)8 b' _; c* o, q% R3 F' l
(Value show))
% D: m* z$ S6 O0 k; B (Ports "" "" "" 0! X- P9 B% q! E4 P
(Name show)' @4 {5 k/ A+ G% T* q2 W
(Type show)5 E9 K# d# ?0 n
("Connected Net name" show)
$ u- E1 {1 p3 N' Q ("Source Library" show)
) ^+ y2 k' ^+ N l* n2 {, } ("Source Symbol" show))4 N# W" Q0 N7 t5 S c
(Aliases "" "" 1
x3 ]8 U: d( Y' G# K# d9 S& O7 K- M (Name show))
# \3 ?( _3 Z r+ R- l0 K) w/ P (Globals "" "" 1
5 J$ s+ @; a# ?9 g2 f (Name show))) |
