查看: 1420|回复: 3
请教cadence原理图导入到board的报错,新手第一画
发表于 2010-5-5 14:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
. K" N1 D% C; b! {8 t" C4 g% `, ~9 ~4 p: U- [1 }  `* F
请教各位大虾,第一次用cadence做设计,原理图画好了,pacage自认为也弄好的,原理图export physical以后再board里面import logic后board里什么也没有,还出现了错误,错误如下:3 f" H" W" z! ~/ p
------ Directives ------
# K: i& S  b$ N; A( C7 ORIPUP_ETCH FALSE;- y) n1 u/ {/ N' i
RIPUP_SYMBOLS ALWAYS;3 M7 D0 E" C/ |
MISSING SYMBOL AS ERROR FALSE;& V* d" W6 p( `9 h2 D, D+ h
SCHEMATIC_DIRECTORY 'F:/design/station speaker/board';) _8 o/ v0 Y4 C: G+ c. D3 f% q
BOARD_DIRECTORY '';8 S* `: |" Y0 U, Y
OLD_BOARD_NAME 'F:/design/station speaker/board/board.brd';$ e- @: J5 e7 n- g# R8 D
NEW_BOARD_NAME 'F:/design/station speaker/board/board.brd';9 S- Y8 y. \" _
CmdLine: netrev -$ -5 -i F:/design/station speaker/board -l -y 1 F:/design/station speaker/board/#Taaaaaa03732.tmp$ j' o! @6 V" }: N5 i; j5 G
------ Preparing to read pst files ------
  p1 l. ~( J1 ?; J! S9 k8 T) m# n) U1 X9 V; s
#1   ERROR(24) File not found! y5 V6 ^' q/ m0 ?# S( H
     Packager files not found+ {* j8 ?: H8 O  P0 P) J* `# r
#2   ERROR(102) Run stopped because errors were detected
8 g6 b1 Q7 v  u3 @netrev run on May 5 14:46:58 2010
. c7 Y4 @, E8 `; _; e   COMPILE 'logic'
" E! K- f. h2 |* j% M/ V% E   CHECK_PIN_NAMES OFF
, w: h* z9 s8 \) f& l) Z   CROSS_REFERENCE OFF5 s( a- J% m( `* i
   FEEDBACK OFF
. e* f! w- c& j+ p/ x( P1 v* Y/ O, X   INCREMENTAL OFF6 f# ^5 u4 {/ {9 b' }
   INTERFACE_TYPE PHYSICAL
+ P. C, c- H) j  B! U   MAX_ERRORS 500
0 s7 n( U! p1 ?   MERGE_MINIMUM 5
1 Q2 d; E/ X# A- `$ a   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
- D9 C1 y& D( b6 i9 S6 C% N9 M  A# Q   NET_NAME_LENGTH 24. M% k" g7 p; N; {( A- g- _
   OVERSIGHTS ON- x$ a( |5 {& i& F: V
   REPLACE_CHECK OFF( ^! e: f! C4 I, Y' ~
   SINGLE_NODE_NETS ON
0 M' d- D* g' e) U   SPLIT_MINIMUM 0( [  x1 x1 l9 D9 f, l9 F
   SUPPRESS   20  D, A. n& q* n! b+ }4 \
   WARNINGS ON
7 M. ~& Q6 V7 p2 ~- c  2 errors detected. S. h4 `0 _" m5 U
No oversight detected
) l6 n( Q8 d& {3 m# d& u No warning detected
+ {0 J& d! q& ~5 ^: A: ]5 s$ f) @cpu time      0:00:42% _$ d5 R( U! ^: N
elapsed time  0:00:00. s6 x3 p% E3 L# ?- O1 V) I
8 T# X( y! i: i2 t7 c+ O2 }1 i
请大家帮忙,我不知道为啥了
发表于 2010-5-6 13:09 | 只看该作者
8 K* Z, B) r6 R你在package和板子对好库没?
发表于 2010-5-6 13:17 | 只看该作者
封装没找到,在allegro里封装名称要对应且要设置好路径
 楼主| 发表于 2010-5-6 21:54 | 只看该作者
回复 3# chenweicn
4 K( q  D& Y6 C) b) n- F4 k& Q1 M( H& Q  J, f  B
! f4 \5 T4 j$ v; L3 U    恩,可以了,谢谢
GMT+8, 2025-8-18 10:12 , Processed in 0.109375 second(s), 24 queries , Gzip On.
