6 l6 Y6 G j6 K- F0 g8 f! i
Uindex=[1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26];
' b3 ~# F: V, q) X7 j3 L( nPandR=[0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 0 0; 31.3 19.3;...
% s( ^6 A0 N4 q+ o2 S 15.2 19.3; 0 0; 0 0; 0 0; 0 0; 0 0; 155.0 27.5; 152.2 27.5; 121.4 27.5; 121.4 27.5; ...% I _" @3 |2 H# d7 \( Y, a2 _
0 0; 0 0; 0 0; 350 0; 350 0; 400 0];
( {7 b v3 E ZFullLoadAverageCost=[27.884 28.027 28.192 28.336 28.478 43.679 43.821 43.972 44.117 15.061 15.104 15.144 15.190 ...
; n4 O- f) Z4 N8 k& W$ ? 20.802 20.895 20.986 12.333 12.371 12.407 12.440 24.826 24.930 25.039 11.903 9.043 9.063];' n) _- Z! n5 Z6 v4 o$ @& e
8 t7 V1 E! V& E) @# ]# _
8 f' e6 i8 {$ t0 X) p7 w9 f8 {9 o, a
[AX,H1,H2]=plotyy(Uindex,PandR,Uindex,FullLoadAverageCost);
& d5 u' T+ V2 s) l/ l1 c! l; p
+ z2 U o4 R) P! V( pset(AX(:),'Ycolor','k')
9 E2 B( V' T, q3 a3 aset(get(AX(1),'Ylabel'),'string','Output Power, Oputput Reserve (MW)','color','k','linewidth',1.0);" J/ r- o# ], e" A
set(get(AX(2),'Ylabel'),'string','Average Cost ($/MW)','color','k','linewidth',1.0);. Y* s! _) s3 b B+ ~0 y/ K
%set(AX,'Xlim',[0.5,26.5],'xTick',[1:1:5]);) E% S( R' O8 j- u
set(AX,'Xlim',[0.5,26.5]);) R( q8 Z( g/ p
xlabel('Index of Unit');5 n) Q' M% O, c' w ]' S% c& y
set(AX(1),'Ylim',[0,500],'yTick',[0:50:500]);
9 c7 U2 R& Q6 y4 g3 L6 ]% gset(AX(2),'Ylim',[0,50],'YTick',[0:5:50]);
1 U& w" n# t) \: i. g v- _. G# T%set(H1,'LineStyle','-','Marker','s','color','k','linewidth',1.0);' E1 {8 V& f, Z, Y) ~, S
set(H2,'LineStyle','-','Marker','v','color','k','linewidth',1.0);
1 u6 X/ U, ~+ C# ]5 ulegend('Output Power','Output Reserve','Average Cost');
% Q. G. s% k) i$ T1 R/ I& V" M$ _ X M9 k/ _! x
关键是 画出来图之后,在“figure properties”里对图进行进一步设置。如设置为曲线,设置为bar,将两个bar stacked.等。. s; l c, X& W1 N$ S
/ P+ ~' M3 b# v& @& _! ~7 }) |: {3 X
, p. w0 a/ f6 x/ Z9 t( n4 `
