查看: 601|回复: 1
Altium Design 单张图纸重复设计
发表于 2020-3-29 17:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1,我现在用的是AD20,界面操作可能不太一样。首先,新建一个工程,: I# K9 G# @! F6 ]: Y/ ~7 V% I9 O# S
+ A( {) d- t5 }. I. d% X
) z" M) o& q6 y, g, O4 V* X
- E# _3 y9 _0 j" h( O5 R0 A
2、然后新建一个schematic,在新建的schematic上添加sheet symbol4 z6 a7 u1 y3 {5 N- `% @
9 n; }8 I0 t: @
  X0 D6 c" r) M3 i1 v" V9 g4 f
. T2 @7 r- r* K( N2 E
# N. }! c* m& o" J3, Change file name, for example as below,
  s0 T: X/ b/ V" h, y/ v5 M+ ^6 g
( V% J4 q9 ^- J6 h3 q8 v! T) T+ l, ~$ Z* ?
4, Creat sheet from symbol.+ X. P  ]9 D1 O; x! p
: A# j6 J! e3 J6 t. {9 W( x) g
5, edit designator on sheet symbol
  ]# n$ c3 f# t4 L3 S
: X: K8 Y" A. c  s$ l  m4 J3 r; [. @& X2 H6 T5 c# i, L% k0 d
' r! j% x8 x/ I  u6 o/ L
6,Annotate designators ) d: N' N' B6 B. p5 A0 q" @( c
+ V( N( R. V+ I, z; b0 e8 f) y
* z" O+ G- u) s% k9 M# J
7 `- n5 a  S6 p2 j9 i2 y, m' _; o2 s; f. f
7, Compile your current project, and only one channel you see. so, why? here is one issue., o3 F" Y0 _  X( O, Q3 H
5 o1 i/ K5 p8 S8 O5 I% R5 d; L2 T+ V; h0 T
' d4 v& L6 p, Z/ J. [  I
  Q" g$ c( u, n; a, U/ U8,  you must place sheet entry to sheet symbol and compile.
% L7 Q$ ^( C% Q4 C. H9 @2 l. s$ Y) A7 u* l0 c
% |+ J% y6 ^2 Z% ?
1 E! K, \2 ^" x; ^
: D2 Q: D& j7 ]9, In the end, the keyword: repeat( file name  ,  first channel  , last channel), done, thanks.
) |5 m8 U& p+ W6 F8 y) Q
6 l$ ?8 K9 ^( K# r0 R. a. K) u1 |6 w1 t
# x3 S4 Q8 B5 [. ^2 W! @9 _0 o
: Q% F. I( P( \  q  p' B* \3 ^+ o
8 g. a( `8 n5 p/ f9 N( J: t0 p2 V* i) d5 j
5 o% q! m5 Q; Y' h2 V3 Y2 s- ?! G/ N* A% Y$ l; o% C
发表于 2020-3-31 18:51 | 只看该作者
此帖仅作者可见
GMT+8, 2025-11-6 03:18 , Processed in 0.500000 second(s), 23 queries , Gzip On.
