我是cadence菜鸟,问的问题总是很白痴,所以帖子总是没人回答,希望这次能有人帮帮我~~~~
6 a& x, p5 H+ `我画了一个原理图,后来在做用PCB editor生成PCB板时发现原理图有错误,然后我重新打开原理图用DRC检查,发现好多错误,有一些我已经纠正了,但是还有一部分错误我确不知道原因,如下:
: t/ p5 }: Z+ D7 WChecking Electrical Rules ; ^/ C6 k& o' y8 v2 ~* c; j
WARNING [DRC0007] Net has no driving source N07686: SCHEMATIC1, PAGE1 (3.50, 5.20)
4 A+ v/ h) q, r) a" L: zChecking For Single Node Nets/ D6 x0 j! y3 d# e
WARNING [DRC0006] Net has fewer than two connections PA6: SCHEMATIC1, PAGE1 (8.80, 9.30) 7 N8 ^ e% H! |" P5 x
WARNING [DRC0006] Net has fewer than two connections N18638: SCHEMATIC1, PAGE1 (9.80, 4.00)
! _' m! y; e0 g4 |8 S' LWARNING [DRC0006] Net has fewer than two connections PC5: SCHEMATIC1, PAGE1 (14.30, 5.70)
- \. O- e3 a4 zWARNING [DRC0006] Net has fewer than two connections PC1: SCHEMATIC1, PAGE1 (10.20, 8.70)
2 z6 u0 w# n4 ]9 vWARNING [DRC0006] Net has fewer than two connections N07293: SCHEMATIC1, PAGE1 (1.50, 5.10)
F( E, K T( A: p. l" wWARNING [DRC0006] Net has fewer than two connections PA7: SCHEMATIC1, PAGE1 (10.20, 6.20) : J w3 h3 Y" q4 A% }; W0 ]* M
WARNING [DRC0006] Net has fewer than two connections PD4/AREF: SCHEMATIC1, PAGE1 (14.30, 7.20) $ @% ^! j, w, `2 L3 \
WARNING [DRC0006] Net has fewer than two connections PA3: SCHEMATIC1, PAGE1 (8.80, 7.80) 5 i" [( g, b! [0 e3 t- P( D% o/ t
WARNING [DRC0006] Net has fewer than two connections PC2: SCHEMATIC1, PAGE1 (10.20, 9.30) / }" v( p8 p; O/ i: u+ D
WARNING [DRC0006] Net has fewer than two connections N09742: SCHEMATIC1, PAGE1 (2.90, 7.30)
) k7 e: n8 y+ K. R, kWARNING [DRC0006] Net has fewer than two connections PB1: SCHEMATIC1, PAGE1 (10.20, 7.20)
5 C$ F# P5 V9 @# iWARNING [DRC0006] Net has fewer than two connections N07297: SCHEMATIC1, PAGE1 (1.50, 5.20) 6 Z8 _( m* ~) E. {) w8 V
WARNING [DRC0006] Net has fewer than two connections TDX: SCHEMATIC1, PAGE1 (11.80, 1.50) , {$ w' A0 W4 k5 J# x1 {2 G
WARNING [DRC0006] Net has fewer than two connections N07686: SCHEMATIC1, PAGE1 (3.50, 5.20) , }2 F( k8 I- {# |) f" T& l; ^' }
WARNING [DRC0006] Net has fewer than two connections RF_SIGNAL: SCHEMATIC1, PAGE1 (12.60, 5.40)
9 s7 K* i; G4 kWARNING [DRC0006] Net has fewer than two connections PD5/PWMOUT: SCHEMATIC1, PAGE1 (14.30, 7.80)
; n6 M7 U! K, m' g9 BWARNING [DRC0006] Net has fewer than two connections PC6: SCHEMATIC1, PAGE1 (14.30, 6.20)
|7 J ~3 Y2 B4 w/ GWARNING [DRC0006] Net has fewer than two connections PA4: SCHEMATIC1, PAGE1 (8.80, 8.30) ! q: n& N2 E4 h. S
WARNING [DRC0006] Net has fewer than two connections RDX: SCHEMATIC1, PAGE1 (11.80, 1.70)
9 \! m" l( T: f( RWARNING [DRC0006] Net has fewer than two connections PC3: SCHEMATIC1, PAGE1 (11.60, 8.30) ' G! J' p. D" ?' ]8 [. }/ l; K' a
WARNING [DRC0006] Net has fewer than two connections PA1: SCHEMATIC1, PAGE1 (8.80, 6.70) 2 m: U6 h3 a$ G& h1 ^' B* u
WARNING [DRC0006] Net has fewer than two connections LNA_ON_1: SCHEMATIC1, PAGE1 (7.60, 2.60)
i- H& W8 G% R5 qWARNING [DRC0006] Net has fewer than two connections PB3: SCHEMATIC1, PAGE1 (10.20, 7.70)
% @$ p; v/ v" ^+ \$ K: g4 vWARNING [DRC0006] Net has fewer than two connections PA5: SCHEMATIC1, PAGE1 (8.80, 8.80)
! @3 x& v1 f' S5 SWARNING [DRC0006] Net has fewer than two connections PC7: SCHEMATIC1, PAGE1 (14.30, 6.70)
* n/ d, f+ o4 _( tWARNING [DRC0006] Net has fewer than two connections PC4: SCHEMATIC1, PAGE1 (11.60, 7.70) $ B8 G* K9 z3 p" {0 Y( r
WARNING [DRC0006] Net has fewer than two connections PC0: SCHEMATIC1, PAGE1 (10.20, 8.20) ) w) f) w; I/ t# @' W' d
WARNING [DRC0006] Net has fewer than two connections PB0: SCHEMATIC1, PAGE1 (10.20, 6.70) 6 G- o3 Z- ~) y/ T; j7 f! M$ d
WARNING [DRC0006] Net has fewer than two connections GND_POWER: SCHEMATIC1, PAGE1 (0.60, 2.00)
# [. g3 G# y }0 bChecking For Unconnected Bus Nets
6 j. ~* h- k; w, g' r希望大虾们能帮帮我~~~~ |
