查看: 1004|回复: 0
What's Good About Allegro PCB Editor Groups? Look to SPB16.3 and See!
发表于 2010-4-21 22:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
cadence网站上关于介绍16.3中建立和拆除Groups的文章。
2 e; t' f  b& A: I7 Ihttp://www.cadence.com/Community/blogs/pcb/archive/2010/04/14/what-s-good-about-allegro-pcb-editor-groups-look-to-spb16-3-and-see.aspx?postID=61297
, p6 \8 z" K- f8 L6 @6 vWhat's Good About allegro PCB Editor Groups? Look to SPB16.3 and See!) X2 e; J6 M% \
By Gerald "Jerry" Grzenia on April 14, 2010Comments(0)Filed under: PCB designWith the Allegro PCB Editor SPB16.3 release, you can now allow groups to have elements added or removed.
* c* i8 }; a" v( _' Y4 o+ m- r$ d. i% j* t' T1 r
The construction and disbandment of groups is now supported in both the General and Placement application modes. Groups are easily created in the working canvas by first pre-selecting multiple elements followed by the selection of the "Add to Group" command located in the context sensitive right mouse button "Add to Group" menu item.
6 D  M! `" z. W4 p0 C
# R; L, K8 c% k4 Q" ]- FGroups can also be disbanded (removed) using the context sensitive right mouse button menu "Disband Group" menu item.
3 T. R) d# R$ [( ~
3 N% B3 M  r4 F4 e8 OFor more details, read below...
5 c$ S3 J3 y# m& t
$ a" t! F2 L1 U) a4 T; e7 g, QTo add or disband groups, use the following flow:: {1 E/ D# y# R1 g! [) A
' ]) I) @' _/ M
1. When in Placement edit or General edit application modes, select the elements you want to add to the group and then using the right mouse button select "Add to Group".
/ u6 A1 I! z( o6 C. D5 f/ X
/ R2 e4 D. n* Q: G" ~. H 4 j& g8 m/ ?; S" Q
. ?8 }$ S# U$ P, Q2. Enter a name for the group in the popup form and select "OK".! }; z: N% q$ ~
6 G" h( G( ]$ M
* C/ p: Z) N, H1 W
9 _5 ^1 K# l$ G- B% g% U  _
% w% y+ k3 C) E( f4 M0 G7 R! K3. To add elements to the group or overwrite the existing group, select the new elements and use the right mouse button "Add to Group".: D: [! ~* q; u+ O
- m. E& h! B% l) K) e; I* J! R
. U0 s7 @, v; s" ]$ I' z. W+ A( Y4 n! g# a% G/ _
4. The "Add to Group" GUI appears - select the group name. If you select "Overwrite existing group", the previous elements will be removed from the group and the newly selected elements will be placed in the group. If you do not select "Overwrite existing group", the newly selected elements will be added to the previously selected elements.0 q: Y/ D! L( l5 p
8 ^" Z+ q  G" h+ o1 C: K7 e! a; R; u/ t9 ^8 G( L
8 B6 H. m: ?4 {# u+ O5. Moving the group can now be accomplished by a single mouse click if the super filter setting is set to "Group".
( ]6 T( ^3 S, b3 q* ~7 d6 }6 q- }  q- h0 H
6. To disband the group, hover over the group and select with the right mouse button "Disband group".: c$ K  z0 C" {5 V
  s/ q' S' M# n- [: d/ L5 @$ N1 V: q* b+ t" @
* I9 X4 u$ }; \6 C% [* d1 \& E: y1 Z" C% Q! g
Please provide any suggestions or questions you may have9 I* {! \& X1 h! @) m) w; O  [' G4 t1 E) h
( t' e" d, @6 GJerry "GenPart" Grzenia
GMT+8, 2025-8-19 08:55 , Processed in 0.109375 second(s), 24 queries , Gzip On.
