查看: 1805|回复: 2
pcb中导入网表错误。该如何结局
发表于 2010-4-10 15:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Missing symbol has error FALSE;+ k1 X, B3 D& P9 A% q
SCHEMATIC_DIRECTORY '.';; M( V, Z5 w/ M' c. }0 D
BOARD_DIRECTORY '';$ [: U+ W7 E6 ^8 A! ~
OLD_BOARD_NAME 'pcb.brd';6 g8 v5 J8 Y7 A9 O
NEW_BOARD_NAME 'pcb.brd';
4 ?+ `, k7 R" j
; H4 B% L0 f2 n1 L) wCmdLine: netrev -$ -i . -y 1 D:/office/#Taaaaaa02708.tmp
7 S, V: U1 F7 j" ?. u( B7 }9 W9 b/ I( j7 `+ _  D& ~. o
------ Preparing to read pst files ------
/ I+ ~$ N) K$ C$ V3 v
/ S( v" Q# \9 }
0 t9 p4 }0 X1 y/ J3 ~" \3 c8 u#1   ERROR(24) File not found) k, {( `$ d1 L4 w$ i. G+ ?
     Packager files not found1 v' Z# p7 D. E7 f
' e* {/ s4 G4 F0 H) a; G  G
#2   ERROR(102) Run stopped because errors were detected
: q: m9 n& @+ R% I9 |" G5 @4 r, Z& r' M, x
netrev run on Apr 10 15:04:34 2010
( ~# V: V4 e0 Y1 F; C# ]9 A% S; o1 W
   COMPILE 'logic'/ X: d2 s3 p) d, t' B' r3 Q: x
   CHECK_PIN_NAMES OFF+ O" O9 ^, I2 c# [. F! U* [$ J
   CROSS_REFERENCE OFF+ }. \; @- Y# Q2 I
   FEEDBACK OFF
0 h- q' J3 [, p6 M5 n   INCREMENTAL OFF
6 H3 x5 F' L- Z  F1 q# |   INTERFACE_TYPE PHYSICAL6 u( }: B5 O0 z  n, y
   MAX_ERRORS 500
: n% Q# L6 v4 s/ X   MERGE_MINIMUM 5
. D8 j9 t8 u, x- l6 ?   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
- P/ ?4 L3 z% o   NET_NAME_LENGTH 24) h, m4 N3 u) U/ @* [8 X$ }. g+ s
   OVERSIGHTS ON( Y) V% f3 _- k0 {8 A: ^$ q# Z. l
   REPLACE_CHECK OFF9 U! }1 j$ A: M/ @; l
   SINGLE_NODE_NETS ON
. v  i. G/ W' ]: B   SPLIT_MINIMUM 0& V6 T$ Z: s0 N5 j) |
   SUPPRESS   20
! H5 Y8 t) E9 Q8 m( Q& S3 D   WARNINGS ON5 I7 M* f0 Y& |. ?( v
  A; [8 Y5 f4 U* @' W0 g
  2 errors detected  l% O7 s; v$ u5 ^0 {
No oversight detected
7 O3 h- t* b2 h0 f) ~$ R8 @: A8 SNo warning detected* p& d* l. w9 j% f+ a( J
5 g+ l3 B& Y$ y$ ~5 ~1 s& lcpu time      0:00:346 t$ i6 v( V% I  W
elapsed time  0:00:00
发表于 2010-4-16 10:53 | 只看该作者
怎么解决的
发表于 2010-4-16 11:44 | 只看该作者
; a) }( h! L# K1 _+ A9 L Packager files not found
8 f; r$ _2 c. K" t/ V0 f6 ~不是写得很明白不
GMT+8, 2025-11-3 20:57 , Processed in 0.140625 second(s), 24 queries , Gzip On.
