查看: 2327|回复: 6
[Cadence Sigrity] IBIS无法转DML,warning 求助
发表于 2010-4-3 02:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Results of the most recent parse:. p3 H6 x$ E( W1 R" S
IBISCHK4 V4.1.1+ U8 d4 ]0 B/ y" F
6 Z4 ~* o2 ^! ^; h2 F6 uChecking D:\ibis\stratix.ibs for IBIS 4.1 Compatibility...
0 }/ g' h( q4 ~: o. U
" P$ ?5 D1 k. mWARNING - Model '3p3_rio_nstatus': TYP VI curves cannot drive through Vmeas=1.5675V
6 I* e: M7 R& n          given load Rref=1e+007 Ohms to Vref=0V3 H& f6 c/ o; x) a
WARNING - Model '3p3_ro_initdone': TYP VI curves cannot drive through Vmeas=1.5675V+ k9 o0 R4 [7 J; O2 T' Q( ^
          given load Rref=1e+007 Ohms to Vref=0V, N) L1 F3 [6 [. [% B5 g
WARNING - Model '3p3_ro_initdone': MIN VI curves cannot drive through Vmeas=1.5675V
7 U0 t0 P$ a& i% s6 u- }: D          given load Rref=1e+007 Ohms to Vref=0V
& u% F0 z4 B7 N2 p8 ^# M$ ], R+ MWARNING - Model '3p3_ro_initdone': MAX VI curves cannot drive through Vmeas=1.5675V
) d. M0 \2 d( ~          given load Rref=1e+007 Ohms to Vref=0V
- n1 n" m0 _9 G+ E: SWARNING - Model '3p3_ro_crcerror': TYP VI curves cannot drive through Vmeas=1.5675V& \$ X% P/ ~: m
  ?. R( G3 R1 v" fWARNING - Model '3p3_ro_crcerror': MIN VI curves cannot drive through Vmeas=1.5675V
  f2 p$ H( k) d. A0 J% N5 e# a  d          given load Rref=1e+007 Ohms to Vref=0V- J( S2 x6 {4 M3 h4 I* o0 A
WARNING - Model '3p3_ro_crcerror': MAX VI curves cannot drive through Vmeas=1.5675V
0 T) e2 P7 u4 m% Z$ H4 d' A. R! a* ^, Q          given load Rref=1e+007 Ohms to Vref=0V' Q/ O- q: A9 q. m) R+ ]+ s$ K8 ^
WARNING - Model '3p3_rio_condone': TYP VI curves cannot drive through Vmeas=1.5675V
7 k% v) ]2 _6 G          given load Rref=1e+007 Ohms to Vref=0V6 K/ g! V" G' y0 ~9 t5 Y) b
WARNING - Model '3p0_rio_nstatus': TYP VI curves cannot drive through Vmeas=1.425V6 I8 z: b/ D6 V$ E
          given load Rref=1e+007 Ohms to Vref=0V# Y( K; j6 p0 |4 {
WARNING - Model '3p0_ro_initdone': TYP VI curves cannot drive through Vmeas=1.425V
; I; V8 d* D  m) B& n          given load Rref=1e+007 Ohms to Vref=0V$ h( L4 h9 F7 m4 \, }) Q
WARNING - Model '3p0_ro_initdone': MIN VI curves cannot drive through Vmeas=1.425V# t+ @, w% K7 c" H: a
+ H5 z2 R& W( y$ e' r, iWARNING - Model '3p0_ro_initdone': MAX VI curves cannot drive through Vmeas=1.425V
0 _, ?1 u  v6 w' s, g/ Z          given load Rref=1e+007 Ohms to Vref=0V- L8 o: ^% ^  a2 _
WARNING - Model '3p0_ro_crcerror': TYP VI curves cannot drive through Vmeas=1.425V+ a: z. {+ {% ~8 S: d3 x1 f
' t- ]/ [6 P5 HWARNING - Model '3p0_ro_crcerror': MIN VI curves cannot drive through Vmeas=1.425V
+ l4 o; j3 N, h          given load Rref=1e+007 Ohms to Vref=0V! Q  d! \! _( a& U
WARNING - Model '3p0_ro_crcerror': MAX VI curves cannot drive through Vmeas=1.425V
' b/ K- z  ^7 }* ?& m5 [. _9 ]          given load Rref=1e+007 Ohms to Vref=0V
# q7 z: h# P$ Z% S! e8 B' KWARNING - Model '3p0_rio_condone': TYP VI curves cannot drive through Vmeas=1.425V
! i4 {  D" |4 y) m          given load Rref=1e+007 Ohms to Vref=0V! w( p* \7 u0 }4 Z  H/ ~4 k
WARNING - Model '2p5_rio_nstatus': TYP VI curves cannot drive through Vmeas=1.1875V
6 g3 l& M, D- R5 j! L          given load Rref=1e+007 Ohms to Vref=0V$ P  X+ [# Z8 v! V
WARNING - Model '2p5_ro_initdone': TYP VI curves cannot drive through Vmeas=1.1875V3 a6 P! W7 u) W' O4 h0 c
          given load Rref=1e+007 Ohms to Vref=0V+ `2 ^) Q5 n  h% i% n# X: Z
WARNING - Model '2p5_ro_initdone': MIN VI curves cannot drive through Vmeas=1.1875V' o) `8 ~& l4 a# p3 y1 ]: {
          given load Rref=1e+007 Ohms to Vref=0V1 h) ]! r+ y. H
WARNING - Model '2p5_ro_initdone': MAX VI curves cannot drive through Vmeas=1.1875V4 [/ I( s. j/ {6 A: x
* R# U, M! R% L5 M/ l, o  y+ T9 dWARNING - Model '2p5_ro_crcerror': TYP VI curves cannot drive through Vmeas=1.1875V
0 c( b" ]1 p) T4 y% n          given load Rref=1e+007 Ohms to Vref=0V; ?9 ]& k( x( l1 m
WARNING - Model '2p5_ro_crcerror': MIN VI curves cannot drive through Vmeas=1.1875V1 J! v( e4 K) q3 T' ]) [
          given load Rref=1e+007 Ohms to Vref=0V3 i# ]2 J( }. H7 D/ z
WARNING - Model '2p5_ro_crcerror': MAX VI curves cannot drive through Vmeas=1.1875V9 ~# U$ }9 {' u6 {- k
/ \' L# m) v1 p  c8 y5 ]- TWARNING - Model '2p5_rio_condone': TYP VI curves cannot drive through Vmeas=1.1875V, p, C; O- W8 w: _& u7 A
          given load Rref=1e+007 Ohms to Vref=0V7 v( F5 S. F7 O6 q* _- h5 B
WARNING - Model '1p8_rio_nstatus': TYP VI curves cannot drive through Vmeas=0.855V
+ Y, v6 ]7 a  ]2 n  L          given load Rref=1e+007 Ohms to Vref=0V2 R% E3 }# ~. {, G5 R
WARNING - Model '1p8_ro_initdone': TYP VI curves cannot drive through Vmeas=0.855V4 m( ]/ V4 ^; Y- H( y" }' O
$ l: u- D! x8 ~% e; h1 IWARNING - Model '1p8_ro_initdone': MIN VI curves cannot drive through Vmeas=0.855V
! W4 F5 q9 y/ ]: U; [          given load Rref=1e+007 Ohms to Vref=0V
) `; E3 T, v; s; A  dWARNING - Model '1p8_ro_initdone': MAX VI curves cannot drive through Vmeas=0.855V, M1 F. h& d& E. H. K; U. ]* p
* c5 ^& z0 v+ g3 H( LWARNING - Model '1p8_ro_crcerror': TYP VI curves cannot drive through Vmeas=0.855V" U! Y' N. p6 ]
          given load Rref=1e+007 Ohms to Vref=0V( S9 n3 Z3 k5 ~1 i' g
WARNING - Model '1p8_ro_crcerror': MIN VI curves cannot drive through Vmeas=0.855V
) a; F5 \9 ?) Q2 E0 b          given load Rref=1e+007 Ohms to Vref=0V
$ s0 B1 L; h  ]- CWARNING - Model '1p8_ro_crcerror': MAX VI curves cannot drive through Vmeas=0.855V* ~9 d, l. o; o# N
          given load Rref=1e+007 Ohms to Vref=0V* n8 T% m) }9 D
WARNING - Model '1p8_rio_condone': TYP VI curves cannot drive through Vmeas=0.855V. O& Y- q8 M8 X* E0 k  y
          given load Rref=1e+007 Ohms to Vref=0V9 O6 c& v3 [$ d8 f9 ~6 e
- G& ~' n& c0 Y/ KErrors  : 0! z9 ]) H3 ~! N) C/ X3 \/ m* t2 I
Warnings: 32
8 E- r2 d. e: _$ w' P! T3 g; D+ r+ ?* M* D2 I
File Passed
发表于 2010-4-3 10:45 | 只看该作者
最好把ibs model发上来才有人试着帮你搞定
 楼主| 发表于 2010-4-3 16:48 | 只看该作者
由于附件比较大,传不上来,只能提供下载地址了。9 v7 ^1 J$ P  x+ Y
谢谢诸位啦!% z3 e% y% z; f. z) h* T* g( {
IBIS下载地址:; O% ~/ X* {7 f- q
http://www.altera.com/patches/ibis/stratix3/stratix3.zip
发表于 2010-4-29 13:35 | 只看该作者
用16.2的4.2 checker是可以转的,你是在specctraquest里面转还是model integrity?
发表于 2010-5-18 15:27 | 只看该作者
请问楼主问题解决了吗?我也碰到相同的问题了
发表于 2010-5-18 15:29 | 只看该作者
用model integrity转的时候就会出现这个warning,我也是用的altera的FPGA
发表于 2010-8-10 17:41 | 只看该作者
請問如何解決?) j+ P2 {& \* s! q9 ]8 K2 Y1 |
請分享一下吧!!
GMT+8, 2025-10-25 08:45 , Processed in 0.156250 second(s), 24 queries , Gzip On.
