返回列表 发新帖
楼主: weaponwp_wang
6mil线宽和5mil线距可以叠出100ohm差分阻抗吗?
16#
发表于 2010-4-12 15:12 | 只看该作者
1. 4层板,PCB排版结构
' x# R& Z& H. m5 R5 ^( j- BL1(TOPLAYER) 1.9mil* J; T# p4 Q( F) f7 I! k
1080+2116 7.3mil
# C- ~% M: u- W" C9 ^! ZL2(GND) 1.2mil
0 l' w+ e2 d" [Core 28mil, @/ x2 Q( c2 X1 c7 G
L3(VCC) 1.2mil
- W6 D9 E* n5 e$ X1080+2116 7.3mil' w: b, l5 S. l* h  z9 a4 {8 H! X
L4(BOTTOMLAYER) 1.9mil
# p) Q1 L% {- }说明:L1、L4为信号层,L2、L3为电源层;
* H9 D. l8 P8 {( X5 B. c4 ?, k! J总厚度:48.8*0.0254=1.2mm
- b4 b! ~( U1 s- t单端线12mil,阻抗值50欧姆;差分线宽8mil,9mil间距,阻抗值100欧姆;
& Y; `- w+ U6 x, D----------------------------------------------------------------------------------------------------------------------" W3 L. Q/ _4 L' L: w
. L1(TOPLAYER) 1.9mil
9 {" p, {6 P% Y4 F9 q2116 4.5mil+ {6 c' s# k! s0 E) N3 @( K
L2(GND) 1.2mil1 c, I/ r$ B: b: t4 p+ t! y
Core 44.5 mil+ H( I7 o6 ~. H% o# Y4 ?- f
L3(VCC) 1.2mil% l9 a& V. i8 k: e' G# N4 C
2116 4.5mil" N+ x) Q9 T5 f) c
1 {$ j' I0 t& P4 p总厚度:60*0.0254=1.5mm
. x  h0 ^# a2 X+ w) G5 @顶层、底层单端线7mil,阻抗值50欧姆;
& j- J. e9 h5 I5 p) X差分线宽5mil,8mil间距,阻抗值100欧姆;
4 r6 ]8 N( b8 G+ h4 D" Z--------------------------------------------------------------------------------------------------------------------- ]' [/ |" G$ ~
1. L1(TOPLAYER) 1.9mil' i- L) X4 K4 C! N
1080+2116 7.3mil) {" h8 ]& ?& U) Z$ s2 z
L2(GND) 1.2mil7 C) R8 u( @. u# U9 W
Core 44.5mil5 U) e6 O# a: a0 h; c
L3(VCC) 1.2mil
) `/ ^: f' c3 l- n$ k1080+2116 7.3mil
4 \8 l" l( r; K  V& iL4(BOTTOMLAYER) 1.9mil: C9 p! `- S" Q
总厚度:65*0.0254=1.6mm
, T: O( _/ g5 c4 P顶层、底层单端线12mil,阻抗值50欧姆;差分线宽8mil,9mil间距,阻抗值100欧姆;
17#
发表于 2010-4-12 15:19 | 只看该作者
Standard PCB Layer Stack Up – 4 to 12 Layer
& {' `' A# |. v4 s) A& `: sPre‐Preg Thickness ‐ 1080 = 3.04 mil ‐ 2116 = 4.67 mil ‐ 7628 = 7.68 mil& r/ D- ?0 P0 {0 s; p& O4 y2 J- a
4 LAYER
' W" [6 b) I6 x( l0 f, i5 R/ q# oTop Layer ‐ 18um Copper Foil (plated to 35um+)
* V5 o- ?3 p5 v* r  G' @Pre‐Preg ‐ 1 x 1080 + 1 x 7628  D5 a( d( m& b& q% y
Layer 2 & 3 ‐ 1.0mm Fr‐4 Core with 35um/35um Copper
( `! N; C1 P" W: s. A  [Pre‐Preg ‐ 1 x 1080 + 1 x 7628$ A3 O/ U- k2 U8 Z  D  q* [+ H: L; M
Bottom Layer ‐ 18um Copper Foil (plated to 35um+)4 F% Y3 W( @$ r' N& }% U/ k
1.6mm +/‐ 10%' M! u/ ^% h1 z
6 LAYER
0 A' r3 ~% |# F3 q4 n9 A2 h/ G3 iTop Layer ‐ 18um Copper Foil (plated to 35um+)8 p: u- y, c/ I- E, z% G9 ?
Pre‐Preg ‐ 1 x 1080 + 1 x 76284 V+ l  C( P4 f" Z$ G, X
Layer 2 & 3 ‐ 0.36mm Fr‐4 Core with 35um/35um Copper
( ]# X  O6 X$ n( k5 \- S& v3 W! gPre‐Preg ‐ 1 x 7628
4 o, v  s& r. R8 {1 k& CLayer 4 & 5 ‐ 0.36mm Fr‐4 Core with 35um/35um Copper9 c$ i3 @  c0 x+ G7 _* r  z# K9 i
Pre‐Preg ‐ 1 x 1080 + 1 x 7628; {) @0 e0 S. N. J3 w- k: Y
6 C' g  \- P8 c0 \; F4 x  K1.6mm +/‐ 10%
' B0 C, V/ U3 G9 ^3 i- d3 `8 LAYER7 Y. Q7 X. L7 O: a7 I
Top Layer ‐ 18um Copper Foil (plated to 35um+)1 v& e0 a$ s; l/ {0 B
Pre‐Preg ‐ 2 x 2116
* ?' w2 n3 ~4 ELayer 2 & 3 ‐ 0.15mm Fr‐4 Core with 35um/35um Copper
8 a& q5 c( F  W  ^7 H1 A) cPre‐Preg ‐ 2 x 2116) r! l2 U; o  M! ?9 R; m7 b
Layer 4 & 5 ‐ 0.15mm Fr‐4 Core with 35um/35um Copper
# e" \( L: ?3 APre‐Preg ‐ 2 x 2116
& b* @& F/ w$ A& U6 nLayer 6 & 7 ‐ 0.15mm Fr‐4 Core with 35um/35um Copper2 v3 ^& ^& x9 J  v7 f& e
Pre‐Preg ‐ 2 x 2116, X1 v; P, l, z
Bottom Layer ‐ 18um Copper Foil (plated to 35um+)/ C$ H$ V) H* V5 E" K* P8 P1 }) P+ c
1.6mm +/‐ 10%4 f8 _8 P& S' Q- b( i: y
10 LAYER
  h2 _6 r, g0 ]( }- iTop Layer ‐ 18um Copper Foil (plated to 35um+)
. {' X* G+ D9 M4 }& A( ~Pre‐Preg ‐ 1 x 2116. p7 t/ g7 r2 h7 f! h# n! y
Layer 2 & 3 ‐ 0.18mm Fr‐4 Core with 35um/35um Copper
3 u& j; I' M1 ]Pre‐Preg ‐ 1 x 2116" {/ k1 p0 C( ]" K5 j* ]
Layer 4 & 5 ‐ 0.21mm Fr‐4 Core with 35um/35um Copper
7 ?7 X( r" M; V9 d, @9 q0 _8 ~8 [# bPre‐Preg ‐ 1 x 21166 s7 y) X9 d  L$ H9 h- K3 ^, v
Layer 6 & 7 ‐ 0.21mm Fr‐4 Core with 35um/35um Copper
4 f- G* [. }; a6 n$ V3 l+ _8 v8 |1 qPre‐Preg ‐ 1 x 2116
% ]/ Z5 H' @  i5 Q8 A* O. iLayer 8 & 9 ‐ 0.18mm Fr‐4 Core with 35um/35um Copper
8 h3 V7 i3 \/ X/ {9 N, M5 pPre‐Preg ‐ 1 x 2116
; A3 h8 {) g4 H8 _8 j! q- A9 \Bottom Layer ‐ 18um Copper Foil (plated to 35um+)
( H  t- w" {8 t: n' [# ^  I. p1.6mm +/‐ 10%: p- @" v/ T; }
12 LAYER) h' U- D$ m9 `7 `
6 _+ i5 |2 M( ]0 @9 bPre‐Preg ‐ 1 x 2116
* Y) s$ i" A5 Y8 hLayer 2 & 3 ‐ 0.13mm Fr‐4 Core with 35um/35um Copper; j- L& u$ w9 u2 J
Pre‐Preg ‐ 1 x 2116
( ?; j* E% T0 C1 M* H  FLayer 4 & 5 ‐ 0.13mm Fr‐4 Core with 35um/35um Copper
; a3 K7 s! t% n" b5 zPre‐Preg ‐ 1 x 2116
! p& y9 c2 Q0 G$ HLayer 6 & 7 ‐ 0.13mm Fr‐4 Core with 35um/35um Copper+ h  }( d, G5 @) ]
Pre‐Preg ‐ 1 x 2116
6 V! e2 D5 W# F$ Q: m: k9 MLayer 8 & 9 ‐ 0.13mm Fr‐4 Core with 35um/35um Copper# N* H# n' E/ T2 W* t
Pre‐Preg ‐ 1 x 21160 [# m/ z, Z8 |5 ?% Y# e; e; }9 q
Layer 10 & 11 ‐ 0.13mm Fr‐4 Core with 35um/35um Copper0 O2 b( c1 m# D; y: b
Pre‐Preg ‐ 1 x 2116' z, s: i7 I5 @# q% j/ v! S- J3 Y0 k' Z
Bottom Layer ‐ 18um Copper Foil (plated to 35um+); J, C3 O- w7 @+ X$ d, W
1.6mm +/‐ 10%
GMT+8, 2025-8-11 13:44 , Processed in 0.093750 second(s), 20 queries , Gzip On.
