有一个BGA器件,按功能块分成几部分了元件.生成网络表时出现如下错误:
, q7 |* X1 y* Q+ X' v T$ Q. m9 |% ?6 }2 V: a
#178 Error [ALG0013] Conflicting values of following Component Definition properties found on different sections of U1.6 K4 O2 J [3 @) N
SWAP_INFO
" ~9 \& N( j8 P* p$ b2 Y0 S#179 Error [ALG0014] Conflicting values of part name found on different sections of "U1".7 y3 w5 N% s) }- o# b. j/ S
Conflicting values: XC3SD3400A_484P_CSG484_(S1+S2+S3+S4+S5+S6)_XC3SD3400A & XC3SD3400A_484P_CSG484_XC3SD3400A
2 O X( W2 r, P8 t1 ] Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical
6 z! x2 b2 |+ e) Y8 G/ w0 P1 j- z" L( g on all sections of the part.4 D* y, P6 k" @; Z' a
7 u% s1 N4 p" b! n3 H4 }9 z我检查了封装也没错,REFERENCE也没错.请问是什么原因呢?谢谢 |
