查看: 1252|回复: 0
编译不了???
发表于 2010-3-9 20:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
LIBRARY IEEE;* H" B9 ?1 u$ t# R" E5 z
USE  IEEE.STD_LOGIC_1164.ALL;
, `, W- E# W" {6 U+ qENTITY  tri_s  IS3 e' j7 o* o3 K1 g- a9 i& i
  PORT( enable : IN STD_LOGIC;
5 M0 i& M5 R3 _* V+ r+ M     datain : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
! t& ~0 l# y  ]9 ?' ?     dataout: OUT STD_LOGIC_VECTOR(7 DOWNTO 0) );/ J1 I6 T5 a0 w  Z2 Z8 Y) w9 [- j
END     tri_s;# ^0 T" }% B$ J9 b' o
ARCHITECTURE  bhv OF tri_s IS
( q/ h8 ?6 A% uBEGIN" y. L: H# E3 ]2 F$ [
PROCESS(enable,datain)
2 X% [* V- U0 g- P* y+ W2 l. j       BEGIN
- F& h& _$ L' @; _( P7 E       IF enable ='1' THEN dataout <= datain;1 M* c$ Q' j1 Q" l8 w: Z2 ?* T
          else dataout <= "ZZZZZZZ"; END IF;8 v9 \0 [8 A2 t6 r+ N$ a" \0 }& }
END    PROCESS;5 k2 j9 u4 |! `' ^$ J7 U
END    bhv;1 K( Z! V2 y- _: g
: [- s2 n4 k: H' V7 x
编译提示:
0 Y1 w9 i+ ?- x  ~# O- B% T" {2 tError: Top-level design entity "div" is undefined
: g* O3 n5 e  C" b6 i( d* B
+ R  {/ W+ ?5 b4 ^% b( S3 F是什么原因,求救!!!!!!
GMT+8, 2025-10-10 06:29 , Processed in 0.125000 second(s), 24 queries , Gzip On.
