查看: 1166|回复: 7
也是出光绘问题
发表于 2010-3-2 12:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
WARNING: Shape at (209.900 792.500) contains void at (209.900 792.500)
* g" m2 m5 _, s4 P/ m which touches another shape.
. s, r8 I# {1 x4 Y  H: K9 g6 X: b            You need to manually resolve this problem., G- t. Z: \4 S4 t7 a4 Y* A
    ERROR: aborting film - artwork will not be generated!
: z& K# L: B: J9 M Error in TOP--halting output.  Artwork file not generated.
/ R7 M9 G' w) F4 ^1 K& w: d9 K' O$ ?* n* y, q& J+ U
这是什么意思?我都看了的··有谁知道,很急!
 楼主| 发表于 2010-3-2 12:05 | 只看该作者
也就L1层没有生成ART文件,其他都有!
 楼主| 发表于 2010-3-2 12:06 | 只看该作者
5 z9 c' `  b2 {* \(                                                            )
7 r; ]8 d& a* L- O) p(        ARTWORK LOG                                         )
& \/ R- _3 b+ s8 o: d(                                                            )% q! |# G5 M; E) I& N
(        Drawing          : PNX1005MIO.brd                   )4 W% d0 R2 b* B3 f; h. W
(        Software Version : unreleased                       )1 V, P& n: z0 h0 H
(        Date/Time        : Tue Mar 02 11:42:30 2010         )' b0 {4 R7 H0 a) E& ^/ c
# ]) s/ J- e4 J1 E. c' _(------------------------------------------------------------)( q  N, l9 y8 L8 _8 g  l% X6 Y; R
* r, K5 z6 a7 _( ]
; {. W: b5 g6 ?3 @" }
% A; `6 Z; j. X: F1 d' A
Results from parameter file ..., ~" H. Q. U. X( @4 k' H# j
    DEVICE-TYPE           GERBER_RS274X
: Z, z$ o# A* ]" S2 ?; J! t    OUTPUT-UNITS          INCHES, `# ], l! K6 Z% L2 Q8 W
    FILM-SIZE             2400000 1600000
9 d0 h7 j  R% m" i8 n' [  j% S9 g    FORMAT                3.5. O. O1 ?/ z! ^! }- U. K
    ABORT-ON-ERROR        NO# j$ m  O+ K; h3 n
    SCALE                 13 W# {- a& }2 f! R
    SUPPRESS-LEAD-ZEROES  YES
% f! c0 W5 d- G    SUPPRESS-TRAIL-ZEROES NO& }+ N4 w9 h; v; `9 b; Q/ p
    SUPPRESS-EQUAL        YES
/ Y( h$ ?; ]; x. n9 E: C6 C    UNDEF-APT-CONT        NO6 z& _; s! p3 L3 O6 Q8 ^* f9 a
* G7 i& \  W, S+ ]+ `  k6 r( I
1 e8 y; N* _) _+ r0 V. ]================================================================
( l5 A& G2 @# M     PROCESSING FILM < TOP >/ V6 k, h4 c( N+ x/ |, {
     TO FILE < D:/PNX1005MIO/TOP.art > ...
: ]4 Y# A6 @+ X6 b7 l: b================================================================6 L$ Z) l$ \' W/ m: ^: t
5 A) ~; ?1 q0 V3 {
  FILM PARAMETERS :' x  ^: R- \% b! I/ a* r
  ---------------------------------------------------------2 ^# ]5 Q$ m! R7 V
  Undefined line width                5.000
* \; B% X9 R" R6 Z* A  Mirror code                         NONE+ ]8 z, I! R3 a- a
  Rotate angle                        NONE; ?5 \8 n* }& U- N2 t) Q
  Offset x:                           0.000
# a9 y! q* a& [2 ?  Offset y:                           0.000+ E* z/ M7 [/ S! [
  Plot negative                       NO
9 {5 b" D0 ?% F" U6 [9 z  Suppress unconnected internal pads  NO
0 k! [' x2 U8 Z. H. x/ n  A5 B) A% V2 p( d6 G* c$ m
    WARNING: Film contains DRC error(s).
( C8 m3 X) \+ `( z! g% @: W) _    WARNING: 0 width line found at (-98.525 -0.200)2 R) n# N' Q5 m# S" x
           ... using undefined line width of 5.000( n, ^5 \+ j" O* t# l6 Z; }' ~
1 c$ r# y: a; {2 }    WARNING: Multiple 0 width lines; all will be treated the same as the first." O7 S+ y. F# N, v9 y7 I
5 b$ ]  v5 d1 d5 g2 f, `* {- a. g" G$ ]) }, R, f  a
# }6 w' }9 Y+ I$ e        which touches another shape.
* i4 ?1 c2 b7 n+ d4 u                   You need to manually resolve this problem.
  P6 i: i& ^0 Y1 f7 h* Y
' x3 g2 z& {0 A2 ]3 l5 A    ERROR: aborting film - artwork will not be generated!
. a! B, I2 o9 a# W+ M/ r8 Q; S+ j. v Error in TOP--halting output.  Artwork file not generated.& y: F+ k6 V% X7 j. `" k3 H3 U0 e+ y
*** ERROR with TOP' O7 U$ T4 v1 H9 Z% C1 J8 G
7 Y0 M; u( ^1 L  [- C  q3 e7 o( t' s
1 e  k# t$ O* m+ Y7 U5 G
! B, I+ Y7 F4 v" }4 k  G) a- p: e  C) @5 h+ [
------------------------------------------------------: t3 G/ q1 L% p7 r) e7 x6 G
SUMMARY:
5 ~. w3 r/ G+ _( d6 O( z    *** ERROR with TOP( Q+ L9 q  o. H: Q( L
% F. v1 H! g) j* v! I
ARTWORK Error
发表于 2010-3-2 13:37 | 只看该作者
allegro就是有这个问题4 B( D2 X7 w' b9 D4 c" L6 _
1,run database check& N1 H# I0 R, H# r# x
2,把问题附近的过孔和线移一下,最好不要选gridless。平时最好不要在gridless5 e5 L3 z$ B9 B/ |* d9 H  J
    的状态下选shove vias,pcb数据容易出错。
" P/ d4 [2 P: P' K4 D2 q3,还不行,把问题附近的铜片挖掉。
发表于 2010-3-2 13:38 | 只看该作者
allegro就是有这个问题. t: S% q4 z$ D4 p2 i+ N
7 j, S2 z0 a( T2,把问题附近的过孔和线移一下,最好不要选gridless。平时最好不要在gridless
: [2 W2 N) @- ]0 M6 U. X5 Y. m1 O, `2 R    的状态下选shove vias,pcb数据容易出错。
7 @' x' U6 \, d3,还不行,把问题附近的铜片挖掉。
发表于 2010-3-2 15:56 | 只看该作者
209.900 792.500" ^  f6 u- t, P! U3 `
检查一下这个坐标的铜皮。
发表于 2010-3-3 15:26 | 只看该作者
修改一下209.900 792.500坐标下的铜皮应该就OK了。
: y. n$ W" ^% ?9 uallegro经常有这种问题的。
    奋斗
    2022-7-27 15:32
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    发表于 2010-3-3 17:49 | 只看该作者
    修改一下209.900 792.500坐标下的铜皮应该就OK了。- U4 Y8 a. K& r" ]: n( d$ F" B
    allegro经常有这种问题的。
    ) F- B. c: k8 x1 k8 h: gxuhy 发表于 2010-3-3 15:26
    , _2 F( y, t/ w/ Y" r9 U
    ! o) H9 W. ?8 K; z  g
    7 H/ b" e/ s& L    支持
    GMT+8, 2025-8-4 11:25 , Processed in 0.109375 second(s), 24 queries , Gzip On.
