(---------------------------------------------------------------------)7 v$ ~% J! n' P- f' X! S+ D& @
( )8 f! c" q* U' b$ b1 o3 l
( ARTWORK LOG )
3 g5 M7 [# C7 \+ E. Z# b( )$ e% R1 e+ b* e6 w m" \, J0 _- ~
( Drawing : u-t0.brd )
7 B' K% W" j- {( Software Version : 16.6-2015S108 )
& h5 @* U' J/ ^& D$ L" n( Date/Time : Fri Mar 06 19:46:09 2020 )
7 e7 i' o8 i/ s' ^1 y. p$ r L( )& E+ i/ O! h: w. m8 u
(---------------------------------------------------------------------)" m9 I( [% a$ [
9 Q. C' ^: o/ I7 A! N
# E$ Q9 [+ F' x) m' Q ---- Photoplot outline rectangle not found; using drawing extents.
2 Q5 r1 ?2 r f2 l* \6 Z4 |0 h; k0 }( q) j# J) y2 a0 j4 y2 d
( t5 C3 r' Y+ |7 t% I Q! K
, _: N D5 c# r! f2 I: [* j
3 d3 a' w$ x6 j Can't open parameter file ... using default values:
- E0 x4 ]7 c! F) U8 f- Z1 {" q DEVICE-TYPE GERBER6X00% H1 W- ?% k6 K& n; u
G-CODES NO1 R2 {2 y# ^4 S- M" J& \
STATIONS-PER-WHEEL 24" X6 h5 @% y0 I* ~& E" c2 n
FILM-SIZE 24000 16000) V- ]/ O8 F) G6 b6 Q4 c/ @* @
COORDINATES ABSOLUTE0 m/ y4 F6 J5 m$ c
OUTPUT-UNITS INCHES
' t" G7 i6 P4 z# X8 ? FORMAT 5.3
& j* I% W) Z. ^# e5 k8 A! r. h! X ABORT-ON-ERROR abort film & continue4 ?. F* w# f" g
SUPPRESS-LEAD-ZEROES YES$ u+ ^1 d" E6 y( }: `
SUPPRESS-TRAIL-ZEROES NO
/ V P9 k) L1 R9 Z2 H4 H3 Y OPTIMIZE YES$ ~4 {" Q" h( Y2 |) |6 }
SUPPRESS-EQUAL YES
& k$ X/ _& t+ N' U) }1 ]$ ~, \ SCALE 1.0
+ y% q/ d( ?1 F$ [8 e' V+ Y' W" R# ^. ?4 x8 M; P
2 G+ n/ E" @) [ a
" R; D6 O7 a, Y) n9 S
& m7 f3 [- G w+ M2 b
7 |0 U- @' E: Y, q0 g- q0 R4 h; K' X================================================================( d3 N4 g3 H6 {' q; F5 H; u! E
PROCESSING FILM < 01-TOP >
; n- s$ {2 a6 `1 L" ]6 A1 @ TO FILE < E:/u-t-gerber/01-TOP.art > ...) G2 |8 n: \2 Y; V% y t
================================================================7 h% F6 D) V/ W
3 ?# J: y* r8 Q, V/ d }; ?
FILM PARAMETERS :( u j4 C6 ^( f6 H
---------------------------------------------------------: ?( w: |$ O$ w: G( h
Undefined line width 4.00 N1 |; Z$ w. n6 Y
Mirror code NONE
0 U- J; G9 I8 y) _% I, Q2 ?2 {4 b: B Rotate angle NONE
; r% _- L* Q! m G0 C% w) @ Offset x: 0.00* G+ e! V8 y4 _0 v% I$ \
Offset y: 0.00/ d" C. s) w, f! p; u, F
Plot negative NO
. u7 W% A$ [ D" K4 F Suppress unconnected internal pads NO
: O$ B, N: Z8 m" k3 Y% r Draw holes only NO
( h- l: \5 J. `7 N% t& V( _0 @$ e- h+ L ]0 a
WARNING: 0 width line found at (4982.56 -35.67)8 U2 p( r5 y9 F$ D: M2 v
... using undefined line width of 4.00/ j% f' p$ Z( m" C
9 m) D* C8 A5 J- h
WARNING: Multiple 0 width lines; all will be treated the sa; b: }3 V- Z# U
