查看: 400|回复: 0
多节锂电同步降压充电ic
    2022-5-9 15:00
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2020-3-4 14:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    General Description   The ZCC6688 is a 3A Li-Ion battery charger. It utilizesa 500KHz synchronous buck converter topology toreduce power dissipation during charging. Low powerdissipation, an internal MOSFET allow a physicallysmall charger that can be embedded in a wide rangeof handheld applications. The ZCC6688 includescomplete charge termination circuitry, automaticrecharge and a ±1% 4.2V /8.4V /12.6V /16.8V floatvoltage. Battery charge current, charge timeout and end-of- charge indication parameters are set with externalcomponents. Additional features include shorted celldetection; temperature qualified charging andovervoltage protection. The ZCC6688 is available in alow profile ESSOP10 package. Features  Input voltage range 4V~22V Dynamic input current allocation for maximumcharging rate 3.0A Maximum Charge Current No External MOSFETs and Blocking DiodeRequired Efficiency up to 90% Constant-Current/Constant-Voltage Operationwith Thermal Regulation to Maximize ChargeRate Without Risk of Overheating Optional Battery Temperature Monitoring Beforeand During Charge Automatic Sleep Mode forLow-Power Over Current Protection Consumption Available in ESSOP10 RoHS Compliant and 100% Lead (Pb)-Free ZCC6688 V2.3.pdf (1020.45 KB, 下载次数: 0)
    GMT+8, 2025-10-9 17:52 , Processed in 0.140625 second(s), 28 queries , Gzip On.
