查看: 556|回复: 2
[allegro16.6][6层]多媒体应用处理器 - 集成电纸书显示屏(EPD)IMX50EVK i.MX50评估...
发表于 2020-3-3 16:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
[allegro16.6][6层]多媒体应用处理器 - 集成电纸书显示屏(EPD)IMX50EVK i.MX50评估套件(7X5MM+1P8X3P5+CASE_P)原理图和pcb文件
文件描述:
1. 作品用途:多媒体应用处理器 - 集成电纸书显示屏(EPD)IMX50EVK i.MX50评估套件
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片:7X5MM+1P8X3P5+CASE_P
5. PCB尺寸:120*125 mm
作品截图如下:
顶层截图:
底层截图:
全层截图:
BOM:
Bill of Material Report (Condensed)
名称类型属性类别数量位号
1P8X3P5CRYSTAL_1P8X3P5_0.9 MM_230-300232.768KHZIC2QZ1; QZ2
7X5MMOSC4_SM_7X5MM_IC_1.9 MM_230-30050MHzIC1Y3
BGA206_0P8_13X13MC34708_PWRMGT_BGA_206P_BGA206_MC34708IC1U3
BGA400_8MMMCIMX50CEC_MPBGA400_BGA400_8MM_MCIMX508IC1U6
CASE1206A-03NTHS2101P_8P_CASE1206A-03_IC_1.NTHS2101PIC1Q5
CASE_PCAP_POL_CASE_P_DISCRETE_1.2MM_147uFDISCRETE1C189
CC0201CAP_NP_CC0201_DISCRETE_0.33 M_10.01UFDISCRETE28C11; C12; C44; C67; C72; C81; C88; C106; C107; C115; C116; C122; C127; C152; C154; C156; C180; C181; C182; C183; C201; C247; C248; C251; C252; C271; C276; C285
CC0201CAP_NP_CC0201_DISCRETE_0.33MM_10.1UFDISCRETE101C22; C23; C24; C25; C26; C27; C28; C36; C37; C40; C47; C48; C54; C55; C56; C58; C60; C63; C68; C74; C75; C76; C84; C91; C92; C93; C94; C96; C97; C110; C111; C112; C113; C114; C118; C119; C120; C121; C124; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C137; C138; C139; C142; C145; C146; C147; C148; C149; C155; C159; C160; C166; C167; C168; C170; C172; C173; C174; C175; C177; C178; C188; C193; C203; C204; C210; C211; C215; C216; C221; C223; C227; C231; C232; C235; C236; C237; C238; C239; C240; C241; C242; C243; C249; C255; C257; C267; C270; C274; C279; C288
CC0201CAP_NP_CC0201_DISCRETE_0.33 M_215pFDISCRETE4C61; C62; C143; C144
CC0201CAP_NP_CC0201_DISCRETE_0.33 MM_0.22UFDISCRETE28C64; C65; C66; C70; C71; C77; C78; C79; C80; C85; C86; C87; C98; C99; C100; C101; C102; C103; C104; C105; C151; C153; C260; C261; C263; C272; C282; C289
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.63520PFDISCRETE4C6; C190; C191; C192
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.59M18PFDISCRETE2C140; C141
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.6_110PFDISCRETE4C205; C206; C207; C208
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.5627 PFDISCRETE2C213; C214
CC0402_25CAP_NP_CC0402_25_DISCRETE_0.56M1000PFDISCRETE1C290
CC0603CAP_NP_CC0603_DISCRETE_0.95MM_110UFDISCRETE26C5; C7; C9; C10; C14; C21; C29; C34; C35; C73; C82; C108; C109; C117; C123; C157; C176; C179; C194; C198; C202; C222; C244; C245; C246; C250
CC0603CAP_NP_CC0603_DISCRETE_0.95MM_2100 PFDISCRETE2C233; C234
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9MM4.7uFDISCRETE9C13; C15; C16; C17; C18; C19; C20; C197; C200
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9 M2.2UFDISCRETE10C32; C50; C51; C52; C53; C57; C59; C158; C212; C224
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.84M1uFDISCRETE11C41; C42; C43; C49; C161; C169; C171; C195; C219; C226; C228
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9650.022UFDISCRETE1C209
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.9_10.47UFDISCRETE4C217; C218; C220; C225
CC0603_OVCAP_NP_CC0603_OV_DISCRETE_0.95M10UFDISCRETE3C273; C281; C284
CC0805CAP_NP_CC0805_DISCRETE_1.45MM_122UFDISCRETE14C2; C3; C30; C31; C33; C38; C39; C45; C46; C69; C83; C89; C90; C125
CC0805_NFM21PEMIFILTER_NFM21P_CC0805_NFM21P_NFM21PC104R1E3DDISCRETE1FL1
CC1206CAP_NP_CC1206_DISCRETE_1.63MM_11000PFDISCRETE1C150
CC1210CAP_NP_CC1210_DISCRETE_2.42 MM_47uFDISCRETE1C4
CC1210CAP_NP_CC1210_DISCRETE_2.7MM_1510uFDISCRETE1C8
CC1210CAP_NP_CC1210_DISCRETE_2.2MM_1568uFDISCRETE1C95
CC3216_10CAP_POL_CC3216_10_DISCRETE_1.2M220UFDISCRETE2C229; C230
CC6032CAP_POL_CC6032_DISCRETE_2.8 MM_100UFDISCRETE4C184; C185; C186; C187
CC7343AMOT_TCAP_CC7343A_3.0MM_150-7530120UFIC2C196; C199
CON5_AUD_JACK_RA_TH_SJ-43515TSSJ-43515TS_CON5_AUD_JACK_RA_TH_AUD_5IO1JK1
CON5_MICROUSBUSB_MINI_AB_RECEPTACLE_CON5_MICMICRO USB AB 5IO1J9
CON19_SDCARD_28X16_SMCONN_SDC013_19P_CON19_SDCARD_28CONN CRD 19IO2P1; P2
CON_2X26_0P8_SMTMINI_PCI_LATCH_52P_CON_2X26_0P8CON 2X26 MINI PCI EXPRESSIO1J8
CON_4M_1MM_SM_RASM04B_CON_4M_1MM_SM_RA_IO_2.95MSM04B-SRSS-TBIO1CN1
CON_120S_QSH_SM_05PITCHQSH060_CON_120S_QSH_SM_05PITCH_QSH-060-01-L-D-AIO2J12; J13
CON_DB9S_RA_318CONN_DB9F_MTGTABS_CON_DB9S_RA_3DB9IO1J83
CON_HDMI_19F_20_SM_RACONN_HDMI_19P_TYPE_A_CON_HDMI_110029449-001RLFIC1J14
CON_PH_2M_78_THHDR_1X2_M_CON_PH_2M_78_TH_IO_6.B2B-PH-K-SIO1J1
CON_SIM_CD_2P54MMSF7W006S1A_CON_SIM_CD_2P54MM_IOCON 6 SIM CARDIO1CON1
DFN_8_0P5_3X3RT8011A_16_2_DFN_8_0P5_3X3_0.8MRT8011AIC1U30
DIP-SMT2SW_DIP-2_DIP-SMT2_IC_4.83 MM_51SW_DIP-2/SMIC1S1
DO_TSLP2DIODE_SCHOTTKY_DO_TSLP2_0.4MM_4BAS3010SIC2D14; D15
DO_VMN2DIODE_DO_VMN2_IC_0.4MM_480-7793RB521CS-30IC1D12
FBGA168_0P5_12X12MMEDB4032B1PB_FBGA168_0P5_12X12MMEDB4032B1PB-8D-FIC1U26
FBGA169_0P5_14X18SANDISK_FBGA169_0P5_14X18_IC_1.KLM4G1EEHMIC1S2
HDR101CONN_HDR_1X1_HDR101_8.38 MM_210HDR_1X1IC7TP1; TP6; TP7; TP11; TP17; TP25; TP26
HDR102HDR_SHRD_2X1_HDR102_IO_9.45MM_2HDR 1X2IO2J84; J85
HDR102CONN_HDR_2X1_HDR102_8.58MM_210-HDR 1X2IC5JP1; JP2; JP3; JP4; JP5
HDR103CONN_HDR_3X1_HDR103_8.586 MM_21HDR_1X3IC4J3; J4; J5; J15
HDR103_49MILCONN_HDR_3X1_HDR103_49MIL_4.2MMCON_1X3IC1J2
HDR210_TST_RATSW-110-05-G-D_HDR210_TST_RA_IOTST-110-05-T-D-RAIO1J7
IND_0603BLM18R_IND_0603_DISCRETE_0.95MM75 OHM@100MHZDISCRETE3FB1; FB2; FB3
IND_0603BLM18R_IND_0603_DISCRETE_0.65MM120 OHM@100MHZDISCRETE5L12; L14; L15; L16; L21
IND_0603INDUCTOR_IND_0603_DISCRETE_0.952.5KDISCRETE4L17; L18; L19; L20
IND_0804_8PIND_8P_IND_0804_8P_DISCRETE_0.690 OHM@100MHZDISCRETE1L11
IND_1210INDUCTOR_IND_1210_DISCRETE_1.7MBRL3225DISCRETE6L3; L4; L5; L6; L7; L8
IND_2220INDUCTOR_A_IND_2220_DISCRETE_5.LQH55DN2R2M03LDISCRETE1L2
IND_DLW5BS_2020DLW43_IND_DLW5BS_2020_DISCRETE_DLW5BTN142SQ2LDISCRETE1L1
IND_NR4018_4X4INDUCTOR_IND_NR4018_4X4_DISCRET2.2uHDISCRETE1L13
IND_VLF4012IND_IND_VLF4012_DISCRETE_1.2MM_2.2UHDISCRETE2L9; L10
LED2_2P1X1P5LED_LED2_2P1X1P5_IC_1.4MM_370-7REDIC1D1
LED1206LED_LED1206_IC_1.2MM_370-76404_REDIC1D4
LED1206LED_LED1206_IC_1.2MM_370-76344_GREENIC3D5; LED1; LED2
LED_0603LED_LED_0603_IC_0.9MM_370-75079REDIC1D7
MIC_WM-63PRMIC_MIC_WM-63PR_1.4MM_510-75938MICIC1P3
MLP6_2X2MM_SLUGFDMA510PZ_MLP6_2X2MM_SLUG_0.8MMFDMA510PZIC2Q6; Q7
PJ-202BDC POWER JACK_PJ-202B_IO_11MM_2CON_1_PWRIO1J6
QFN24_4X4MM_SLUGLAN8720A-QFN24_QFN24_4X4MM_SLUGLAN8720AIC1U15
QFN24_4X4MM_SLUGMAX9701_25P_QFN24_4X4MM_SLUG_ICMAX9701IC1U17
QFN32SGTL5000_QFN32_IC_0.9MM_315-779SGTL5000 32QFNIC1U16
QFN72_0P5_10X10_4P85SQSII9024ACNU_QFN72_0P5_10X10_4P8SiI9024ACNUIC1U7
RC0402_25RES_RC0402_25_0.40 MM_470-308621.8KIC1R9
RC0402_25RES_RC0402_25_DISCRETE_0.40 MM_100KDISCRETE9R10; R12; R43; R44; R80; R112; R118; R160; R398
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_410KDISCRETE119R13; R53; R66; R79; R81; R90; R102; R119; R121; R122; R123; R124; R125; R126; R128; R131; R132; R133; R134; R137; R138; R141; R143; R145; R147; R149; R150; R151; R153; R155; R157; R159; R161; R163; R165; R167; R169; R172; R174; R177; R179; R181; R184; R186; R189; R191; R193; R212; R213; R214; R215; R216; R217; R218; R219; R229; R230; R231; R233; R234; R235; R236; R237; R238; R239; R241; R242; R243; R244; R245; R246; R247; R248; R252; R253; R254; R255; R256; R257; R259; R260; R261; R263; R264; R268; R269; R270; R271; R273; R274; R275; R278; R279; R281; R282; R284; R286; R288; R312; R313; R314; R315; R316; R317; R318; R319; R322; R328; R330; R340; R376; R377; R382; R395; R399; R413; R454; R455; R498
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_12.2KDISCRETE5R17; R329; R334; R417; R418
RC0402_25RES_RC0402_25_DISCRETE_0.4MM_471.0KDISCRETE4R25; R26; R198; R200
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_522KDISCRETE1R42
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_44.7KDISCRETE34R54; R105; R106; R107; R108; R178; R180; R182; R185; R187; R190; R192; R194; R265; R294; R406; R407; R408; R409; R410; R482; R483; R484; R485; R486; R487; R488; R489; R490; R491; R492; R493; R494; R495
RC0402_25RES_RC0402_25_DISCRETE_0.4MM__168KDISCRETE7R68; R69; R276; R277; R333; R342; R396
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_4100DISCRETE4R127; R293; R338; R339
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_11KDISCRETE3R129; R135; R136
RC0402_25RES_RC0402_25_DISCRETE_0.45MM_11.0MDISCRETE3R130; R320; R480
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_2330DISCRETE4R142; R290; R299; R393
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_1240DISCRETE3R195; R196; R470
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_322KDISCRETE3R225; R258; R272
RC0402_25RES_RC0402_25_DISCRETE_0.41MM_533DISCRETE31R228; R386; R387; R426; R427; R428; R429; R430; R431; R432; R433; R434; R435; R436; R437; R438; R439; R440; R441; R442; R443; R444; R445; R446; R447; R448; R449; R450; R451; R452; R453
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_2470DISCRETE4R283; R285; R287; R291
RC0402_25RES_RC0402_25_DISCRETE_0.4 MM_31.5KDISCRETE2R308; R309
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_212.1KDISCRETE1R323
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_347KDISCRETE2R411; R458
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_44.3KDISCRETE1R415
RC0402_25RES_RC0402_25_DISCRETE_470-309513KDISCRETE1R474
RC0402_25RES_RC0402_25_DISCRETE_0.40 M_6150KDISCRETE1R481
RC0603RES_RC0603_DISCRETE_470-75534_2294KDISCRETE1R2
RC0603RES_RC0603_DISCRETE_470-75424_1100KDISCRETE1R3
RC0603RES_RC0603_DISCRETE_0.55MM_47_242.2KDISCRETE1R4
RC0603RES_RC0603_DISCRETE_0.55MM_47_317.4KDISCRETE1R7
RC0603RES_RC0603_DISCRETE_0.55MM_470-0.1DISCRETE2R14; R15
RC0603RES_RC0603_DISCRETE_0.55 MM_4_1470KDISCRETE1R16
RC0603RES_RC0603_DISCRETE_0.55 MM_4706.04KDISCRETE2R111; R117
RC0603RES_RC0603_DISCRETE_0.55 MM_4_249.9DISCRETE4R303; R304; R305; R306
RC0603RES_RC0603_DISCRETE_0.55MM_47_1270DISCRETE2R310; R311
RC0603RES_RC0603_DISCRETE_0.55 MM_4_31DISCRETE1R467
RC0603RES_RC0603_DISCRETE_470-75536_3332KDISCRETE1R475
RC0603_OVRES_RC0603_OV_DISCRETE_0.6MM_470DISCRETE218R1; R8; R18; R19; R20; R21; R22; R23; R27; R28; R29; R30; R31; R32; R34; R35; R36; R37; R38; R39; R40; R41; R45; R46; R48; R49; R50; R51; R52; R55; R56; R57; R58; R59; R60; R61; R62; R63; R64; R65; R67; R70; R71; R72; R73; R74; R75; R76; R77; R78; R82; R83; R84; R85; R86; R87; R88; R89; R92; R93; R95; R98; R99; R100; R101; R103; R104; R109; R110; R113; R114; R115; R116; R120; R139; R140; R144; R146; R148; R152; R154; R156; R158; R171; R176; R183; R188; R197; R199; R201; R202; R203; R204; R205; R206; R207; R208; R209; R210; R211; R220; R221; R222; R223; R224; R226; R227; R232; R240; R249; R250; R251; R262; R266; R267; R280; R289; R292; R295; R296; R297; R298; R300; R301; R302; R307; R321; R324; R325; R326; R327; R331; R332; R335; R336; R337; R341; R343; R344; R345; R346; R347; R348; R349; R350; R351; R352; R353; R354; R355; R356; R357; R358; R359; R360; R361; R362; R363; R364; R365; R366; R370; R371; R372; R373; R374; R375; R378; R379; R380; R381; R383; R384; R385; R388; R389; R390; R391; R392; R397; R400; R401; R402; R403; R404; R405; R412; R414; R416; R419; R420; R421; R422; R423; R424; R425; R456; R457; R459; R460; R461; R462; R463; R464; R465; R466; R468; R469; R471; R472; R473; R476; R477; R478; R479; R496; R497; R499
RC0603_OVRES_RC0603_OV_DISCRETE_470-7578200KDISCRETE1R47
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_42.7KDISCRETE1R11
RC0805_OVRES_RC0805_OV_DISCRETE_0.65MM_10.02DISCRETE4R24; R367; R369; R394
RC1206_OVRES_RC1206_OV_DISCRETE_0.8MM_470.001DISCRETE6R33; R91; R94; R96; R97; R368
RJ45_8_MAGJACK_THRJ45_MAG_LED_SI-50170-F_RJ45_8_RJ45 8IO1J11
SC70-5_A1G125_SC70-5_A_IC_1.1MM_312-301NC7SP125P5XIC2U5; U20
SC70_3MOSFET_N_SC70_3_IC_1.0MM_480-76NTS4001NT1GIC1Q3
SH0603RES_SHORT-2_SH0603_DISCRETE_0.10DISCRETE28SH1; SH8; SH10; SH12; SH14; SH19; SH20; SH21; SH22; SH23; SH24; SH28; SH29; SH30; SH31; SH32; SH35; SH36; SH37; SH40; SH42; SH43; SH44; SH45; SH46; SH47; SH48; SH53
SKT_BATT_4X8BATTERY_SKT_3V_SKT_BATT_4X8_1.72994TRIC1BT1
SLP1616P6RCCLAMP_SLP1616P6_IC_0.65MM_312RCLAMP0504P.TCTIC2U13; U14
SO8MIC2526_8P_SO8_IC_1.73MM_312-75MIC2026-1YMIC1U12
SO8WSTM25P32_SO8WST_IC_2.5MM_334-7733M25P32-VMW6TGIC1U21
SO8_PAKFDMS6681Z_SO8_PAK_IC_1.10MM_480FDMS6681ZIC1Q2
SOD123DIODE_ZENER21_SOD123_IC_1.35MM_MMSZ5231BT1GIC1D2
SOD123DIODE_SCHTKY_SOD123_IC_1.0MM_48MBR120LSFT1GIC1D6
SOD-923DIODE_TVS_SOD-923_IC_0.40MM_480ESD9L5.0ST5GIC3D3; D8; D9
SOD-923DIODE_TVS_BIDIR_SOD-923_IC_0.4MESD9B3.3ST5GIC2D10; D11
SOT23DUALDIODE_CA_SOT23_SOT23_IC_1.1BAT54A-7-FIC1D13
SOT23NPN_SOT23_IC_1.12MM_480-75757_MMMBT3904IC4Q14; Q17; Q22; Q24
SOT363PNP_DUAL_SOT363_IC_1.1MM_480-77MBT3906DW1T1IC2Q4; Q16
SOT-23MOSFET_P_SOT-23_IC_1.12MM_480-7IRLML6401IC2Q13; Q19
SOT-23MOSFET_N_SOT-23_IC_1.12MM_480-7SI2312BDSIC1Q23
SOT-563PNP_1_SOT-563_IC_0.60MM_480-766NSS12100XV6T1GIC3Q8; Q9; Q10
SPACER_150TSPACER_SPACER_150T_IC_16.13MM_2.635" LONGIC4H1; H2; H3; H4
SW3_SLIDE_THSW3_SPDT_SLIDE_SW3_SLIDE_TH_IC_SPDT_PWR_SWITCHIC1SW14
SW4_PB_ESW_SM_P177SW_PB_ESW_SW4_PB_ESW_SM_P177_ICSPST PBIC10SW1; SW2; SW6; SW7; SW8; SW9; SW10; SW11; SW12; SW13
SW_DIP16_8POS_SMSW_DIP_8_SW_DIP16_8POS_SM_IC_2.SW DIP-8IC3SW3; SW4; SW5
TESTPOINT_39MILTEST PAD_TESTPOINT_39MIL_DISCRE1 mmDISCRETE26TP27; TP28; TP29; TP30; TP31; TP32; TP33; TP34; TP35; TP36; TP37; TP38; TP39; TP40; TP41; TP42; TP43; TP44; TP45; TP46; TP47; TP48; TP49; TP50; TP52; TP54
TEST_LOOPTESTLOOP_TEST_LOOP_IC_4.8 MM_21TEST POINT WHITEIC4TP12; TP13; TP14; TP15
TO-263-5TPS786XX_5P_TO-263-5_IC_190MIL_TPS78601IC1U2
TPAD_020TESTLOOP_TPAD_020_IO_0.1MM_211-TPAD_020IO9TP51; TP53; TP55; TP56; TP60; TP61; TP62; TP63; TP64
TQFN12_0P4_2P3X1P7MMPI3USB10MZK_TQFN12_0P4_2P3X1P7MPI3USB10MZKEIC1U31
TSOP48_SKTNANDFLASHSOCKET_TSOP48_SKT_5.33980020-48-P2IC1U9
TSSOP8AT24CXX_TSSOP8_IC_1.2MM_334-760AT24C512B-TH-BIC1U11
TSSOP16IDT74CBTLV3257Q_TSSOP16_IC_1.2MIDT74CBTLV3257PGGIC2U18; U19
TSSOP20MAX3222_TSSOP20_IC_1.2MM_312-79MAX3222IC1U8
TSSOP2074-244_20P_TSSOP20_IC_1.1MM_31274LVT244APWIC2U28; U29
ULLGA6_1P45X1_0P5MMNLSV1T34_ULLGA6_1P45X1_0P5MM_ICNLSV1T34IC1U4
USB_AUSB_A_USB_A_IO_7.01MM_210-30008USB_TYPE_AIO1J10
XTL4_2P5X2MM_SMO4-0_XTL4_2P5X2MM_SM_IC_0.9MM_222.5792MHZIC1Y1
XTLOSC4_3P2X2P5MM_SMCRYSTAL_JXS63_XTLOSC4_3P2X2P5MM24MHZIC1Y2
XTLOSC4_CB3_SMOSC3_XTLOSC4_CB3_SM_1.8MM_230-712.288MHzIC1Y5
XTLOSC4_JXS75_SMXTAL_13Y_A_XTLOSC4_JXS75_SM_1.025MHZIC1Y4
附件:
原理图和pcb文件
游客,如果您要查看本帖隐藏内容请回复
& ~  a7 W( J' S
发表于 2021-8-15 11:15 | 只看该作者
我来看看是什么宝贝' [1 C4 u, z: Y, H: n3 Z) E
    无聊
    2023-12-15 15:00
  • 签到天数: 380 天
    [LV.9]以坛为家II
    发表于 2023-1-11 13:36 | 只看该作者
    感谢分享,学习学习
    GMT+8, 2025-10-12 21:19 , Processed in 0.171875 second(s), 27 queries , Gzip On.
