查看: 321|回复: 1
在MATLAB环境下图像直方图均匀化代码实现
发表于 2020-3-3 15:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
至于图像直方图均匀化的概念我就不说了,下面直接给出直方图均匀化的代码吧。
% }( s/ }4 m" T6 O
$ h9 X' j' d0 M5 I$ d+ r* E6 l
  • function om=myhisteq(im,a,b,flag)
  • % HISTOGRAM EQUALIZATION
  • % input parameters
  • % im (must): input grayscale image, can be double, uint8, uint16 and int16
  • % a,b (must): piecewise linear stretching parameters, must be a vector between [0 1],
  • % a and b must have the same length
  • % flag (optional): 1 meaning plot the result, otherwise don't plot
  • % output parameters
  • % om: output grayscale image after histogram equalization, have the same
  • % class with im
  • % example
  • % close all
  • % im=imread('darklena.gif');
  • % a=[0 0.1 0.2 1];
  • % b=[0 0.8 0.95 1];
  • % % 关于myhisteq的使用说明参见myhisteq.m内部
  • % om=myhisteq(im,a,b,1);
  • % By LaterComer of MATLAB技术论坛
  • % See also http://www.matlabsky.com
  • % Contact me matlabsky@gmail.com
  • % Modifid at 2010-10-13 12:52:53
  • % close all
  • if nargin<3
  •     error('Input parameters must have im, a, b at least!');
  • elseif nargin==3
  •     flag=0;
  • elseif nargin>4
  •     error('Too many input parameters, the function have 4 arguments at most!');
  • end
  • if flag==1
  •     figure('name','Piecewise Linear Function')
  •     plot(a,b,'o-')
  •     xlabel('Input')
  •     ylabel('Output')
  •     title('Piecewise Linear Function')
  •     saveas(gcf,'_Piecewise Linear Function.jpg')
  • end
  • dataclass=class(im);
  • switch dataclass
  •     case {'double','sigle'}
  •         if ~all(im<=1 & im>=0)
  •             error('If input image is double, then the data "im" must be between [0 1]!');
  •         end
  •     case {'uint8','uint16','int16'}
  •         vmin=double(intmin(dataclass));
  •         vmax=double(intmax(dataclass));
  •         a=a*(vmax-vmin)+vmin;
  •         b=b*(vmax-vmin)+vmin;
  • end
  • om=zeros(size(im),dataclass);
  • for i=1:length(a)-1
  •     pix = im>=a(i) & im<a(i+1);
  •     om(pix)=(b(i+1)-b(i))/(a(i+1)-a(i))*(im(pix)-a(i))+b(i);
  • end
  • if flag==1
  •     figure('name','Input Image')
  •     imshow(im)
  •     title('Input Image')
  •     imwrite(im,'_Input Image.jpg');
  •     figure('name','Histogram of Input Image')
  •     imhist(im)
  •     title('Histogram of Input Image')
  •     saveas(gcf,'_Histogram of Input Image.jpg');
  •     figure('name','Oput Image')
  •     imshow(om)
  •     title('Oput Image')
  •     imwrite(om,'_Oput Image.jpg')
  •     figure('name','Histogram of Output Image')
  •     imhist(om)
  •     title('Histogram of Output Image')
  •     saveas(gcf,'_Histogram of Output Image.jpg')
  • end
    6 O; W/ I7 e8 w% j1 I, ?/ f7 E( J
% q3 p, T4 V% r. ~" Z
7 x% |/ `# c! F4 p$ K. u% c6 f
发表于 2020-3-3 16:35 | 只看该作者
GMT+8, 2025-11-4 07:20 , Processed in 0.125000 second(s), 24 queries , Gzip On.
